Re: Intake manifold question
[Re: JohnRR]
#3281833
01/10/25 10:54 AM
01/10/25 10:54 AM
Posts: 10,160 MI, usa
dvw
MI, usa
Not sure on the AC. The by pass hose needs a 45 degree fittting with a cut down hose. This is a swapa I did for a cutomer. 360 Magnum with a Performer RPM THe front dress is from the doner1968 318. Used the 5 bolt valve covers from the 318 as well. Doug
[Re: volaredon]
#3281885
01/10/25 02:14 PM
01/10/25 02:14 PM
dvw
MI, usa
My newest post ain't showing. The compressor i want to use is much like the OEM magnum one from 92-03 only with v belt drive not serpentine. Definitely not the big old cast iron RV2. The aluminum one that was "in between". Would the magnum water pump work for an LA front cover? (I'm thinking "not") Or if not was there ever a magnum engine timing cover that had the provision for a mechanical fuel pump? From MP, or aftermarket? I have a couple of the factory magnum accessory brackets and I think I have the brackets for an 80s LA also. This was what I was hoping for. The Magnum waterpump pump rotates the opposite direction of the LA pump. Doug
