For Sale/ Wanted - Big Block Engine - 1st Quarter
#3279402
12/31/24 07:56 PM
12/31/24 07:56 PM
Posts: 15,686 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale/ Wanted - Big Block Engine - 1st Quarter
[Re: moparts]
#3279568
01/01/25 11:36 AM
01/01/25 11:36 AM
Posts: 5,833 Detroit area
6PAX
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
New Mopar Performance chrome big block distributor hold down. $20
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $125
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $550
Prices do not include shipping.
gt340 @ yahoo.com
[Re: budman1965]
#3280064
01/02/25 08:46 PM
01/02/25 08:46 PM
Posts: 2,883 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm wanting a 4500 M1 intake for a low block. If you can help me out with one of these let me know, thanks. Rick Seeman 501-519-742five
2011 Drag Pak Challenger
[Re: moparts]
#3280086
01/02/25 09:42 PM
01/02/25 09:42 PM
6PAX
Detroit area
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand but it never was run and is essentially new. $375 + shipping. I also have a new set of Comp Cams 973-16 inner valve springs I was going to use with this cam and Edelbrock RPM heads that I am asking $40 for. https://www.summitracing.com/parts/HRS-CL722322-08https://www.summitracing.com/parts/cca-973-16gt340 at yahoo.com
Re: Wanted - Big Block Engine - 1st Quarter
[Re: dsd70bee]
#3281881
01/10/25 03:05 PM
01/10/25 03:05 PM
Posts: 44,393 Bend,OR USA
Cab_Burge
I need and want to buy a stock AVS intake and carb for a 1970 375 HP 440 manifold, casting date from 04-1968 to 10-1968. I need a stock single or dual point distributor also if you have one. PM me on here or E mail me at cabburge@wans.net, let me know your price with the shipping to me in zip code 97702 which is Bend, OR Thanks: Cab
Throttle cable brkt
[Re: moparts]
#3281901
01/10/25 04:06 PM
01/10/25 04:06 PM
Posts: 870 In the Middle
roadntrack
In the Middle
Throttle cable bracket for auto trans Came off a 1969 440 $40 plus shipping PM me for info please
Remember when cars were FUN?
Alt brkt
[Re: Cab_Burge]
#3281902
01/10/25 04:09 PM
01/10/25 04:09 PM
roadntrack
In the Middle
Alternator bracket from a 1969 440 $20 plus ship PM me for info please
HOLLEY 37-921
[Re: moparts]
#3281944
01/10/25 06:29 PM
01/10/25 06:29 PM
roadntrack
In the Middle
HOLLEY Trick Kit 37-921 It has been opened, not sure if anything is missing as this kit seems to be no longer available $45 plus shipping PM me for info please
HOLLEY 3-396
[Re: moparts]
#3281946
01/10/25 06:50 PM
01/10/25 06:50 PM
roadntrack
In the Middle
HOLLEY 3-396 gasket pkg for HOLLEY 2300 2bbl It has been opened. Not sure what is missing as the kit seems to be discontinued $20 plus shipping PM me for info please
P4007671 6bbl tune kit
[Re: roadntrack]
#3281960
01/10/25 07:38 PM
01/10/25 07:38 PM
roadntrack
In the Middle
DIRECT CONNECTION MOPAR PERFORMANCE P4007671 Tuning pkg for 1969 440-6bbl $185 plus shipping PM me for info please
water pump housing
[Re: moparts]
#3281969
01/10/25 08:14 PM
01/10/25 08:14 PM
roadntrack
In the Middle
High flow Water pump housing from a 440 motorhome. casting 3751216 $50 plus shipping PM me for info please
Meter plates
[Re: roadntrack]
#3281975
01/10/25 08:41 PM
01/10/25 08:41 PM
roadntrack
In the Middle
Holley metering plates from 1970 440-6bbl Stamped 34 and 35 SOLD
*** SOLD *** Iskenderian 1623 PushRods
[Re: moparts]
#3282233
01/12/25 01:55 PM
01/12/25 01:55 PM
Posts: 1,072 NJ
EV2RTSE
NJ
Isky 1623 Chromemoly Tubular Pushrods for RB / 413 / 426w / 440 set of 16, new in box, they had some light surface rust from storage, I gave them a quick soak in Evaporust and cleaned them up these are the ball and cup type for adjustable rockers specs- https://iskycams.com/shop/index.php...p;zenid=8e92b69ec0b78f22185564f7cea1c96elist for $286.99 at places like JEGS & Summit *** SOLD ***
Big Block Distributor Hold Down Clamp
[Re: Memongo]
#3283343
01/18/25 04:15 AM
01/18/25 04:15 AM
Posts: 4,764 Fenton, MI
Memongo
Parts peddler
Parts peddler
Fenton, MI
Big Block Distributor Hold Down Clamp. Used, $15 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only! Call Steve 810-629-1097
7186 Edelbrock Performer RPM
[Re: Memongo]
#3283759
01/20/25 02:45 PM
01/20/25 02:45 PM
Posts: 1,408 Out of the State of Confusion
blue_stocker
Looking for a new or lightly used 7186 Edelbrock Peformer RPM intake with no modifications. PM me here if you have something within 300 miles of Savannah,Tenn...THANKS!
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
440 RPM intake #7193 for sale
[Re: blue_stocker]
#3283783
01/20/25 04:21 PM
01/20/25 04:21 PM
Posts: 878 lancaster,california
johnnycuda
Selling a Edelbrock #7193 RPM intake for 413-426W-440 RB, $275 shipped to lower 48, located in Lancaster, Ca. PM me here if interested, I use PayPal
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
383 AVS Carb
[Re: moparts]
#3285453
01/27/25 11:22 PM
01/27/25 11:22 PM
Posts: 3,560 Syracuse,NY
CompWedgeEngines
Syracuse,NY
1970 Carter AVS carb for a 383 AUTO
As is not rebuilt, see pics for condition . What you see in the pictures is what you get.
$150 plus shipping ( USPS from Syracuse NY I am guessing it will fit fine in the $17 USPS Flat Rate box.
Payment - Pay Pal only. Parts under $100 I'll cover the PayPal fee, anything over, please add 3%. I dont check Moparts everyday, so please be aware of that.
RIP Monte Smith
BBM Fan CLutch
[Re: moparts]
#3285456
01/27/25 11:27 PM
01/27/25 11:27 PM
CompWedgeEngines
Syracuse,NY
As noted in picture. I believe, this was never used, Maybe bolt on, but as I recall, it was sitting in torn open plastic for years. As is, take note of pictures. If it was used, it was very minimal.
Part # 4095853 $40 plus shipping from Syracuse NY
Payment- PayPal Only Items under $100 I'll cover the PayPal fees. Items over $100, please add 3% All items shipped USPS Flat Rate when possible.
RIP Monte Smith
Carter AVS 4429S 440 HP
[Re: moparts]
#3285459
01/27/25 11:36 PM
01/27/25 11:36 PM
CompWedgeEngines
Syracuse,NY
I have a Carter AVS #4429S for a 68 440 HP. Its not a rebuilt carb its as is, will need to be dis-assembled rebuilt and cleaned I should have pics up in a day or two. $250.00
Payment: PayPal only plus 3% fee.
Shipping will be USPS Flat Rate and should fit in the $17 flat rate box from Syracuse NY
RIP Monte Smith
[Re: moparts]
#3286464
02/01/25 05:24 PM
02/01/25 05:24 PM
Posts: 2,407 Lee Co. Fla.
5carguy
Lee Co. Fla.
Looking for an origional new or reman Mopar 1970 big block waterpump.Must have arrow Top and hartzog emblem. PM here or Rtroyer1@comcast.net Thanks for the add Moparts
Fuel Vapor Separator for 440 and 426 Engines 1968 - 1971 MOP
[Re: 5carguy]
#3286927
02/03/25 04:59 PM
02/03/25 04:59 PM
Posts: 7,973 Witness Protection Program
Kudakidd
SOLD
Fuel Vapor Separator for 440 and 426 Engines 1968 - 1971. BRAND NEW! PN on box 2131-269-66 Look at the weld, it's definitely made in the USA. Just kidding. $20. plus $8.00 for shipping Paypal accepted (Friends and Family). Contact me at 'kudakidd@hotmail.com'
Complete RB Ignition Set up
[Re: Kudakidd]
#3286940
02/03/25 06:36 PM
02/03/25 06:36 PM
Kudakidd
This package includes the following: Distributor Distributor cap ECU Coil Ballast Resistor Wiring harness Instruction sheet
All are BRAND NEW. Never mounted any part on the engine or in the engine bay. Decided to go w/ stock point dizzy on my '70 440 Cuda. First $125. takes it. Shipping is $25. via USPS. Paypal accepted (Friends and Family). Contact me at 'kudakidd@hotmail.com'
Milondon 7 quart oil pan
[Re: moparts]
#3288873
02/11/25 08:07 PM
02/11/25 08:07 PM
Posts: 647 southern conn
1969gtx
southern conn
7 qt. Oil pan with pick up tube 3/8 prat # 30930 $150 plus shipping Can be delivered to Indy swap meet contact 860 388 6838 Bill
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
Cal-custom value covers
[Re: moparts]
#3288875
02/11/25 08:11 PM
02/11/25 08:11 PM
1969gtx
southern conn
Nice set of Cal-custom value covers need cleaning $200 plus shipping. Can be delivered to Indy swap meet
Mopar 337 Intake
[Re: moparts]
#3290456
02/19/25 03:17 PM
02/19/25 03:17 PM
Posts: 8,800 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I am looking for the elusive Mopar 337 M1 Intake. Max Wedge port, not the one for the Stage 6 heads. Any leads are appreciated.
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
413 short ram manifolds
[Re: moparts]
#3290943
02/22/25 12:51 PM
02/22/25 12:51 PM
Posts: 240 mi
RATPATROL
mi
1964 Chrysler shortram intake and high performance exhaust manifolds dated 6-63 complete with linkage, crossover tube, block offs, heat tubes and gaskets excellent condition no broken flanges or stripped threads $5500
[Re: moparts]
#3291360
02/24/25 04:15 PM
02/24/25 04:15 PM
Posts: 2,649 GA
Boosted
GA
I am looking for 2 std bore 383 stock pistons. Please send me a total shipped to 31820 GA paying via Paypal
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Summit 750 DP Carburetor
[Re: Boosted]
#3291575
02/25/25 10:58 PM
02/25/25 10:58 PM
Posts: 3,040 Sac, CA
mopowers
Sac, CA
Lightly used Summit 750 cfm mechanical secondary carburetor (part #M08750MS): https://www.summitracing.com/parts/sum-m08750msIt has Holley 50cc accelerator pumps installed w/ yellow pump cams. Unfortunately I do not have the stock 30cc accelerator pumps. I can swap out the yellow pump cams for pink cams though if you'd rather have the stock accelerator pump shot. Should just bolt on an go (after some tuning), but I'd probably take the top off and give it a cleaning just to make sure. Comes with feed line. $225 plus shipping from 95691. Check, mail order, or PP friends and family. Will ship promptly after payment clears. Local pick up works too. Thank you!
440 For sale
[Re: 68roadrunner]
#3292873
03/05/25 03:35 PM
03/05/25 03:35 PM
Posts: 946 White House,TN
stroked470
White House,TN
I’ve got a .040 440 I just finished up for sale. 1975 or 76 model block. Standard steel crank. Resized rods with ARP bolts. Speed Pro L2355F forged pistons. Moly rings. Felpro gaskets. Edelbrock E-Street heads. Performer RPM intake. Crane ductile rockers. Comp cams 292 cam and lifters made in early 2000’s just setting on the shelf. $6500 located just outside Nashville Tn.
