4150 carb max airflow #3273027
11/28/24 07:14 PM
11/28/24 07:14 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Does there exist a 4150 Holley that flows a true 1000 CFM ? And with 1.75" butterflies ?
Maybe I should also specify the 4150 bolt pattern.
Or do you need to go with a Dominator with 2" throttles ?
To my knowledge, a downleg booster "850" has about the biggest combination of venturi and throttle bore,
and I think even those will not reach 900 CFM.
I kind of want to rule out a fuel injection throttle body, just a conventional carb.
Re: 4150 carb max airflow [Re: hemienvy] #3273031
11/28/24 07:52 PM
11/28/24 07:52 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Holley sells a 4150 that they call 1000 cfm. And maybe a few people claim a little higher. I wouldn't know how much they really flow.
2011 Drag Pak Challenger
Re: 4150 carb max airflow [Re: rickseeman] #3273033
11/28/24 08:34 PM
11/28/24 08:34 PM
Washington
skrews Offline
skrews  Offline
Washington
If you use a 1.45" venturi HP main body along with a 1.75 base plate with slab sided shafts, it will flow over 1000 cfm.
Re: 4150 carb max airflow [Re: hemienvy] #3273035
11/28/24 08:44 PM
11/28/24 08:44 PM
AndyF Offline
AndyF  Offline
Sure, you can get 1000+ CFM 4150 carbs. The least expensive is probably the QF 1050. I don't think the Holley 1000 is available anymore. BLP makes a bunch of big 4150 main bodies and I'm sure other carb tuners have big options. I've used a QF 1050 for years on the dyno. Really nice carb that makes good power.
Re: 4150 carb max airflow [Re: hemienvy] #3273036
11/28/24 08:47 PM
11/28/24 08:47 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Don’t know for sure, but I would suspect the 1.59 venturi 4150 would be real close.
Re: 4150 carb max airflow [Re: BSB67] #3273048
11/28/24 10:58 PM
11/28/24 10:58 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Well here's why I'm asking about actual flow.
Quick Fuel has a Dom with 2" butterflies and 1.71" venturis that they are also calling a "1050".
Same flow as the 4150 "1050" ?
I don't think so.
