trans sheild ? #327112
05/24/09 02:11 PM
05/24/09 02:11 PM
Port Mcneill,B.C.Canada
I
Islandcuda Offline OP
I
Hi all, do you have to have the bottom peice of the trans sheild or is it okay to just have the top peice on? The reason being the bottom peice of the tci sheild is a [Edited by Moparts - Keep it clean] to line up, Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: trans sheild ? [Re: Islandcuda] #327113
05/24/09 04:26 PM
05/24/09 04:26 PM
Ma
Voluster Offline
Voluster  Offline
Ma
well I run a blanket
But the way I see it.
Would you only wear half your seatbelt?
never skimp on safety
Re: trans sheild ? [Re: Voluster] #327114
05/24/09 11:51 PM
05/24/09 11:51 PM
I
I
lol yah i hear ya, thoughts were though that upper part of the sheild has the cert sticker on not the bottom
Re: trans sheild ? [Re: Islandcuda] #327115
05/25/09 12:01 AM
05/25/09 12:01 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I dont think you'll pass tech. If you blow your trans it may not protect you like it would other wise.I still cuss mine every time I go on or off with it but after a few times I've gotten better.
