Re: Cam/Lifter Failures [Re: CYACOP] #3266755
10/27/24 09:06 PM
10/27/24 09:06 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted by CYACOP
Originally Posted by B1MAXX
Are these stock heads? they are 1.85 installed. Those springs are too stiff at that height.
Stock heads yes. I agree with you but that was what they recommended.
Check the pressure of those springs to verify they match the spec for that part number. Just because it says 911 on the box, doesn't guarantee the spring in the box is 911.
As my late machinist used to say, "if it comes out of a box, it's fk'd up".
Kevin
Re: Cam/Lifter Failures [Re: Cab_Burge] #3266780
10/27/24 10:19 PM
10/27/24 10:19 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Originally Posted by Cab_Burge
Save yourself some money and future frustration by converting to a roller cam and lifters now up twocents work
I agree! They're not without their own issues but in today's market it's the thing to do. 10 yrs ago I built a 470" solid flat tappet with Comp stuff. Lost the cam in 800 miles(yes...I did all the break in bs with the correct oil, etc. Not my 1st engine build by any means) I bit the bullet and switched to a solid roller( all Comp stuff) and have been cruising for the last 10 years. It's due for springs but it's a switch I'll never regret.......it runs WAY better with the roller(specs were very similar) and I no longer worry about flat tappet cam syndrome. twocents
Re: Cam/Lifter Failures [Re: Dcuda69] #3266800
10/28/24 06:03 AM
10/28/24 06:03 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
I am just trying to build a decent running street car that will never see the track. If you guys have any recommendations on a reliable hydraulic roller setup let me know.
I am going to go ahead and start cleaning out all the metal shavings and order all of the lower end parts I need to get the bottom end assembly process going and research my options for the valve train.
Thanks for all your help.
Re: Cam/Lifter Failures [Re: CYACOP] #3266811
10/28/24 08:08 AM
10/28/24 08:08 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Why not use the purple shaft with the correct springs.and save yourself 1500 bucks.
You lost the cam due to the springs used.
Re: Cam/Lifter Failures [Re: B1MAXX] #3266927
10/28/24 06:26 PM
10/28/24 06:26 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
I think so too.
Re: Cam/Lifter Failures [Re: B1MAXX] #3267017
10/29/24 08:35 AM
10/29/24 08:35 AM
an8sec70cuda Offline
Not trying to argue, just stating my experience...I've built 3 BB Mopars in the past few years using hyd. flat tappet cams. All using the Comp 911 springs on stock heads w/ 1.88" installed height. All have been fine.
One was an old MP 509/292 cam.
One was a custom nitrided grind from Dwayne Porter.
One was the Summit 6401 cam.
I don't know what the answer is to a lot of these cam and lifter failures. I've seen them fail when everything was done "right".
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: Cam/Lifter Failures [Re: CYACOP] #3267025
10/29/24 09:02 AM
10/29/24 09:02 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
A street performance hyd. flat tappet should be 100-110 seat 280-290 over the nose.
Re: Cam/Lifter Failures [Re: CYACOP] #3267099
10/29/24 04:31 PM
10/29/24 04:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
My last solid flat cam was a Howards nitrided of the shelf cam with EDM lifters. I switched to a smaller solid roller from Isky and sold the flat cam to another member here It is still in use as far as I know in another big block. I only use Gibbs Driven BR series oil.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Cam/Lifter Failures [Re: fourgearsavoy] #3267206
10/30/24 10:59 AM
10/30/24 10:59 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
back in the day these cars were new, we swapped cams and lifters all the time, never paying too much attention to what lifter went where, or even if the lifters used belonged to the cam being swapped.
never seemed to have any problems with wiped lobes, but maybe the material of the components were better, or we were just "luckier than a cat scratchin' turds"........[as my old man used to say] who knows ? shruggy
beer
Re: Cam/Lifter Failures [Re: moparx] #3267215
10/30/24 11:42 AM
10/30/24 11:42 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
It's a combination of today's materials being used and today's spec low zinc oils that causes the issues with f.t. cams and lifters. The last several f.t. cams engines that I have built I always break in with the outer springs only. After break in, I add the inner/damper springs. Never any issues thus far. One engine has 54,000 miles on it and another six pack engine in my car has over 65,000 on it. Paying for the extra nitride process on the cam helps also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1970 Challenger R/T S.E. 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic 5.7L
Re: Cam/Lifter Failures [Re: 6PKRTSE] #3267223
10/30/24 12:10 PM
10/30/24 12:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
GM engineers thoughts on the zinc in the oil thing.
https://www.nonlintec.com/sprite/oil_myths.pdf
Re: Cam/Lifter Failures [Re: Neil] #3267311
10/30/24 08:55 PM
10/30/24 08:55 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Interesting read. However there is no date on it so is it possible that GM engineer was covering their butt over the large amount of cam failures in the mid-80's? Wish I had a buck for every cam I put in GM stuff back then.
Re: Cam/Lifter Failures [Re: Dcuda69] #3267318
10/30/24 09:11 PM
10/30/24 09:11 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Synthetic oil that he talks about in there went mainstream in the 90's if you Google it. This article is not new for sure, but I suspect it's past the 80's at least based on content? Also I recall the starburst symbol on the oil bottles being an early to mid 2000's thing? It was around the time when regular oil was said to not be good enough for older cars due to reduced zinc so everyone switched over to Rotella and other diesel oils.
Re: Cam/Lifter Failures [Re: Neil] #3268167
11/04/24 09:21 PM
11/04/24 09:21 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
I'm looking into installing the 6401 Summit warranty cam. The cam has .466 intake lift and .488 exhaust lift. I had previously installed the Comp Cam 911 springs that were rated at 373 lbs/in which I think is too high and has been causing my failures. I'm running stock cast iron heads and stock rockers.
Any recommendations on valve springs?
Re: Cam/Lifter Failures [Re: CYACOP] #3268171
11/04/24 09:37 PM
11/04/24 09:37 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Do you have a cam card? That can be taken to any one of the spring manufactures and they should be able to assist you. They may want an installed height for the springs as well in case they don't have info on what that number is.
Make sure your cam has CMC cast into it. Lifters? I would buy the Hylift ones myself even if they were more money as I think your odds are better with those than some of the others in circulation. Having oem lifters touched up is also a good alternative if you have some stock ones that are in ok shape.
Also on the Hylift site they mentioned not pre-soaking the lifters in oil before using them. They want you to pressurize them dry and let them fill up on their own. I'd do that with the intake off one time thru so you can watch the oil move down the line.
Re: Cam/Lifter Failures [Re: Neil] #3268178
11/04/24 10:05 PM
11/04/24 10:05 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
I was looking at these lifters.
Re: Cam/Lifter Failures [Re: CYACOP] #3268187
11/04/24 11:06 PM
11/04/24 11:06 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
vs-430
Re: Cam/Lifter Failures [Re: B1MAXX] #3268188
11/04/24 11:08 PM
11/04/24 11:08 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I wouldn't run a high bleed lifter.
Re: Cam/Lifter Failures [Re: CYACOP] #3268191
11/04/24 11:09 PM
11/04/24 11:09 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Hughes sells Hylift, and has for many years. Hughes is going to sell you on specific oils to use as well, but since you are not using their cam they may not warranty anything? I know Hylift sells direct too if you wanted to go that route and talk to them on the phone about your issue and concerns as well. If you read the Hylift pdf online they talk about different internal spring rate options for their lifters as well. I have no idea when those stiffer lifter springs apply as far as cam specs, but it is interesting that they offer that when nobody else appears to.
UPDATE Re: Cam/Lifter Failures [Re: Neil] #3300265
04/11/25 07:55 PM
04/11/25 07:55 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Just a follow up from 5 months ago and a big thanks for all of your responses.
We ended up putting it all back together for the 3rd with a Hugh's cam and hydraulic roller lifters and we never looked back. Car is still under construction with no front sheet metal but has proven itself not to fail running it up and down the street. Starts and idles perfect every time in the garage so we (me and my son) feel pretty confident it will stay together. this time. It runs strong.
Thanks for everyone's input. No more flat tappet cams for me.
