Brake Problems- Pedal Gets Pulled to floor #326422
05/23/09 02:56 PM
05/23/09 02:56 PM
Long Island, NY
Jstern Offline OP
Jstern  Offline OP
Long Island, NY
Hi,
I just changed the booster in my 71 GTX.
When I start the car, the brake pedal gets sucked to the floor immediately. Any ideas what I'm doing wrong?
This is my second booster and it's getting frustrating.
Re: Brake Problems- Pedal Gets Pulled to floor [Re: Jstern] #326423
05/23/09 03:28 PM
05/23/09 03:28 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Sounds like the booster is bad even though its new.The vacuum should assist.Sounds like vacuum is puiilin it down.You do have the master on dont you?Rocky
Chrysler Firepower
Re: Brake Problems- Pedal Gets Pulled to floor [Re: therocks] #326424
05/23/09 04:39 PM
05/23/09 04:39 PM
reuse old check valve on this booster? ALL the way to the floor or to the end of the pedal reserve(roughly several inches from floor)? what Rocky said, M/C on or off & were the brakes(M/C then wheels) bled out?.
Re: Brake Problems- Pedal Gets Pulled to floor [Re: RapidRobert] #326425
05/23/09 08:52 PM
05/23/09 08:52 PM
Long Island, NY
Jstern Offline OP
Jstern  Offline OP
Long Island, NY
The m/c is on, the brakes were bled and I tried two check valves. It must be the booster. I can't wait to crawl under and swap it out again! Thx for the responses.
