Page 6 of 8 1 2 3 4 5 6 7 8
Re: Looking For Mr. Six Pack Cam Information [Re: ArcticCuda] #32618
04/25/12 10:26 AM
04/25/12 10:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Blast from the past...
Are these cams still available?
They should be, I'm thinking of ordering one myself .
Re: Looking For Mr. Six Pack Cam Information [Re: JohnRR] #32619
04/25/12 11:04 AM
04/25/12 11:04 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
So when using Bobs cam you run basically stock 906 heads and exhaust manifolds? What does he recommend for compression? I really want to give his cam a try. I need to go through my 70 440 6 pack motor and was curious what needs to be done per Bobs recommendations. Thanks
Re: Looking For Mr. Six Pack Cam Information [Re: 70VcodeCoronetRT] #32620
04/25/12 11:11 AM
04/25/12 11:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bob's cam is basically a stock replacement that will pass tech for the Pure Stock drags, but it's a little different than stock. Build your engine to Pure Stock spec , either stock compression ratio as advertised by the factory or +1.5 as allowed by the current rules , though the PS guys would rather people build to factory spec.
Re: Looking For Mr. Six Pack Cam Information [Re: JohnRR] #32621
04/26/12 08:05 AM
04/26/12 08:05 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Specs are 497 horse , 520 lb ft torque
On dyno last summer in 95deg 110 % humid
Room.
5o5 stroker , 1.6 rockers , 20" vacuum
Dyno operator chuckled and told me
400 horse , he can tell by idle.
His hand flew off the throttle when the outboards
Opened.
It REAlly idles like a 318 stationwagon
Re: Looking For Mr. Six Pack Cam Information [Re: sogtx] #32622
04/26/12 08:33 AM
04/26/12 08:33 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
Re: Looking For Mr. Six Pack Cam Information [Re: macmic87] #32623
04/26/12 11:35 AM
04/26/12 11:35 AM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
I recently installed his cam in my car, which is a stock 440 with 800 cfm Edelbrock AVS, repro Accurate Limited exhaust.
My engine builder was initially skeptical of the cam and tried to get me to do not only a different cam, but the typical headers, aluminum intake, holley route. On this particular car, it wasn't what I was going for. So, the only mods to the engine were internal, .020 over, slight bowl work, adjustable rockers and the carb mentioned. I only have around 100 miles on it so far, but the engine builder was pretty impressed with how it pulled. It's a 69 Charger 4spd with 3.54 gears and both the builder and I are way over 200lbs.
Once I get a few more miles on it, and tune on the carb a little more, play with the timing a little, I'll dyno test it and maybe get a 1/4 mile run in at a local track.
Unfortunately, there's no telling when that will be. I just don't get much quality time with the car anymore.
Here's a short video of it idling.
http://www.youtube.com/watch?v=g9mMUUexhAw&feature=channel&list=UL
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Looking For Mr. Six Pack Cam Information [Re: Dixie] #32624
04/26/12 11:52 AM
04/26/12 11:52 AM
Nebraska
Nebraska
What are you guys running for ets with the Mr six pack cam? Also whats the combo? Thanks
Re: Looking For Mr. Six Pack Cam Information [Re: Dixie] #32625
04/26/12 12:01 PM
04/26/12 12:01 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Mine runs good too;
http://www.youtube.com/watch?v=Ofma0go-jJk&feature=g-upl
440, stock "6-pack " rods, Ross NHRA legal replacement pistons in .030, 10.75:1, unported 906's w. comp cams #911-16 springs, Mopar performance 4006767 lifters (preload set at 0.010", crane adjustable roller rockers, Bob's cam installed straight up, stock manifolds (with heat crossover flapper removed), 2.5" TTI exhaust with Dynomax Ultraflows, 727 with stock converter and "Hemi" internals plus a good shift kit, 4.10 clutch type SG 8 3/4. Carbs rebuilt by Bill O. with jetting and springs as per Bob K. and Jim S.
the engine is very strong, wish I would have put it on an engine dyno before putting it in the car but there wasn't one locally...oh well, should be on the track this summer and timeslips don't lie.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Looking For Mr. Six Pack Cam Information [Re: 70VcodeCoronetRT] #32626
04/26/12 12:06 PM
04/26/12 12:06 PM
DPelletier Offline
DPelletier  Offline
My combo is as per the preceeding thread and is all as per my discussions with the PS guys including several with Bob. I haven't run mine yet, but there are many PS cars out there running his cam; times are basically 12.0 flat and up depending on the usual factors. You can expect mid to high 12's depending on how close you want to get to the extent of the PS rules as well as car set up, etc. etc. My personal goal was to duplicate the 69.5 RR Ronnie Sox test time of 12.91.
Re: Looking For Mr. Six Pack Cam Information [Re: ArcticCuda] #32627
04/26/12 02:10 PM
04/26/12 02:10 PM
Up in the North and Far Away
AutoEngineer Offline
Pepe, it's not so long time ago when I sent you a pic of Bob's cam package after I had bought one.
I don't find any reason why they would not be available at the moment.
Call to Bob, he's a great guy and purchase the cam from him
Re: Looking For Mr. Six Pack Cam Information [Re: AutoEngineer] #32628
04/26/12 04:37 PM
04/26/12 04:37 PM
Nebraska
Nebraska
DPelltier, Awesome video love it. Hope to have the same setup in the R/T. Please post your times when you get to the track. Take care.
Re: Looking For Mr. Six Pack Cam Information [Re: 70VcodeCoronetRT] #32629
04/26/12 06:24 PM
04/26/12 06:24 PM
DPelletier Offline
DPelletier  Offline
Thanks and will do.
Re: Looking For Mr. Six Pack Cam Information [Re: DPelletier] #32630
04/26/12 11:28 PM
04/26/12 11:28 PM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
Anyone in the upper 12s with a stock 440 on pump gas?
Stand behind your word
Re: Looking For Mr. Six Pack Cam Information [Re: Dodge] #32631
04/26/12 11:34 PM
04/26/12 11:34 PM
Vancouver, WA
Cuda Cody Offline
Cuda Cody  Offline
Vancouver, WA
I just order a cam from him.... going to pull the motor in Cindy and make the change. (383 Stroker (438) with everything else stock.) I dyno'd the motor with the cam the engine builder selected and it was good, but it just didn't idle as smooth as I wanted it to. You can come over and hear it / drive it when the new cam is in.
1970 Challenger T/A 4-Speed
1970 Challenger T/A Auto
1970 Challenger R/T Auto
1970 Challenger Auto
1970 Challenger RT 440+6 4-Speed
1970 Hemi Challenger 4-Speed
1970 Hemi Cuda 4-Speed
1971 Cuda Auto
1971 Cuda 4-Speed
LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: Looking For Mr. Six Pack Cam Information [Re: Cuda Cody] #32632
04/27/12 08:45 AM
04/27/12 08:45 AM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
Will come check it out Cody. I have a cam sitting here. Just not sure on which route to build an engine. All the A12 running low 12s are on race fuel.
Re: Looking For Mr. Six Pack Cam Information [Re: Dodge] #32633
04/27/12 11:40 AM
04/27/12 11:40 AM
DPelletier Offline
DPelletier  Offline
...depends what you mean by "stock". If you mean "as rolled off the assy line" then I'm gonna say no. Certainly the low 12 sec. cars are running too much compression (combined with the cam's high cranking pressures as well as the detonation prone stock cast 906 heads) to run on pump gas. The general consensus of the Ronnie Sox A12 RR test was that the car was "tweeked". The fact that none of the other 440-6 road tests from "back in the day" are in the 12's would seem to support this contention.
According to "them in the know" it would be possible to run a lower compression, Pure Stock legal, 440-6 that should break into the 12's and run on pump gas, but you are definitely not going to run with the top dogs in PS at that compression level.
Re: Looking For Mr. Six Pack Cam Information [Re: DPelletier] #32634
05/19/12 11:17 PM
05/19/12 11:17 PM
Vancouver, WA
Cuda Cody Offline
Cuda Cody  Offline
Vancouver, WA
Broke in the 383 cam I got from Mr. Six pack two days ago on the engine stand and put the motor back in the car today.
Let me back up and say that my engine builder came highly recommended and with everything else on the build he did great, but he had his "connection" cam company custom grid a custom cam for my motor and after 100 miles I knew it had to come out. It just wasn't right and wasn't running good. Spoke with Bob (Mr. Six Pack) and had him send me one of his grinds to see if it was better. Let me tell you I could not be any happier! The car runs fantastically and is really responsive. I'm running stock stuff (stock intake, heads, exhaust manifolds, carb) and the car feels so much stronger with Mr. Six Packs grind compared to the grind my engine builder put in. Plus it idles and runs so much better.
I would STRONGLY recommend Bob (Mr. Six Pack) to anyone who is looking for a cam grind.
Has anyone used his 340 six pack grind?
1971 Cuda Auto
1971 Cuda 4-Speed
Re: Looking For Mr. Six Pack Cam Information [Re: Dodge] #32635
05/20/12 03:03 AM
05/20/12 03:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's because they are/were built to NHRA spec which puts the compression over what it actually rolled off the assembly line with.
Re: Looking For Mr. Six Pack Cam Information [Re: JohnRR] #32636
05/21/12 12:51 AM
05/21/12 12:51 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I've got one of Bob's cams going into my 383 Road Runner.
It sure is fun watching the Mr. 6Pack powered A12 cars tearing up the 1/4 mile - http://youtu.be/OFaPlDt2jt4
Re: Looking For Mr. Six Pack Cam Information [Re: CompSyn] #32637
05/21/12 11:12 AM
05/21/12 11:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'll be talking to Bob this week for a cam for the Dart .
