1971 D100 factory fc7 #3261257
10/01/24 03:16 PM
10/01/24 03:16 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
I just drug in a 1971 Dodge D100 Adventurer that appears to be
an original fc7 from the factory. Did they actually paint these trucks
fc7 in 1971? I have never seen one before. TIA
Re: 1971 D100 factory fc7 [Re: GTS440] #3261275
10/01/24 04:39 PM
10/01/24 04:39 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Re: 1971 D100 factory fc7 [Re: Fat_Mike] #3261281
10/01/24 05:10 PM
10/01/24 05:10 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
This one does not appear to be a Dude.
Re: 1971 D100 factory fc7 [Re: GTS440] #3261290
10/01/24 05:39 PM
10/01/24 05:39 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
FC7 for a 71 dodge truck is Dark Green.
Plum Crazy is C7
https://paintref.com/cgi-bin/colorcodedisplay.cgi?model=Dodge&year=1971&con=yo
My Monster are real!
Living within your means makes life pretty easy.
Re: 1971 D100 factory fc7 [Re: 67vertman] #3261343
10/01/24 09:11 PM
10/01/24 09:11 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
There is no paint code on the truck. I guess I'm just used to car fender tags.
Re: 1971 D100 factory fc7 [Re: GTS440] #3261466
10/02/24 03:11 PM
10/02/24 03:11 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
Sometimes there is a small paint code tag riveted to firewall above master cylinder area. You might look there.
Re: 1971 D100 factory fc7 [Re: 67R/T4speeder] #3261481
10/02/24 04:21 PM
10/02/24 04:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When did they put the info tag on the inside of the glovebox door?
Re: 1971 D100 factory fc7 [Re: 67vertman] #3261656
10/03/24 11:44 AM
10/03/24 11:44 AM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
Plum Crazy is C7
That's for cars, click on truck to see the available truck colors.
https://paintref.com/cgi-bin/colorc...odge&model=Dodge%20Truck&rows=50
Re: 1971 D100 factory fc7 [Re: John_Kunkel] #3261998
10/04/24 04:39 PM
10/04/24 04:39 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
There are several 70-71 Plum Crazy trucks known that were not Dudes. I do not believe it was even a factory available color on trucks, but a special order. The tag that appears on the firewall of some trucks is not a paint code, but a number that corresponds to a number on the build sheet and there should also be a tag on the front of the bed.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 1971 D100 factory fc7 [Re: Soopernaut] #3262184
10/05/24 04:12 PM
10/05/24 04:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Color code FC7 breaks down like this:
Model year offered F (1970)
Plum Crazy/ In Violet C7
Therefore, FC7, if you include model year designator.
Re: 1971 D100 factory fc7 [Re: GTS440] #3264011
10/14/24 10:20 AM
10/14/24 10:20 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
pictures would be a big help.
Spring special color
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
