M1 or TUNNELRAM #3260514
09/28/24 12:37 AM
09/28/24 12:37 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Found a single carb tunnel ram in back of shop. My present combo is 408 with M1, 750 Holley, R/T head with mods, .557 Mopar cam, 8" converter/ 4.30 gear. Turns 10.50's-60's/124 in good air. Will I get anything extra with the swap?
Re: M1 or TUNNELRAM [Re: A/MP] #3260832
09/30/24 07:17 AM
09/30/24 07:17 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'll go out on a limb and say...NO WAY. Rather, no way I'd run a conventional cast tunnelram with a single 4. The distribution is awful! Now put another holley on the TR and it'll likely pick-up a tenth or so depending on the model.
Re: M1 or TUNNELRAM [Re: HardcoreB] #3260836
09/30/24 07:41 AM
09/30/24 07:41 AM
gregsdart Offline
gregsdart  Offline
The only way i would use one would be with direct port injection of some sort and a good flowing throttle body. Then match the cam and converter to that manifolds rpm window, and maybe work on the runner sizes if they are small for your motor/head combo.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: M1 or TUNNELRAM [Re: gregsdart] #3261057
09/30/24 09:10 PM
09/30/24 09:10 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Over the weekend, I found the dual quad top and what I think are the correct Holleys with the vacuum secondaries.
Re: M1 or TUNNELRAM [Re: A/MP] #3261133
10/01/24 06:57 AM
10/01/24 06:57 AM
gregsdart Offline
gregsdart  Offline
A much better option. My thoughts are how are vacuum secondary carbs going to function when they have a lot of flow capacity to cubic inch. Maybe a call to Holley tech might help, or someone may have done some research on a dyno to give you a starting point. How big are the carbs?
Re: M1 or TUNNELRAM [Re: A/MP] #3261249
10/01/24 02:49 PM
10/01/24 02:49 PM
You need to tie the two vacuum pods together when using them on a tunnel ram take scope thumbs wrench up
