Re: M1 or TUNNELRAM
[Re: HardcoreB]
#3260836
09/30/24 07:41 AM
09/30/24 07:41 AM
Posts: 10,254 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I'll go out on a limb and say...NO WAY. Rather, no way I'd run a conventional cast tunnelram with a single 4. The distribution is awful! Now put another holley on the TR and it'll likely pick-up a tenth or so depending on the model. The only way i would use one would be with direct port injection of some sort and a good flowing throttle body. Then match the cam and converter to that manifolds rpm window, and maybe work on the runner sizes if they are small for your motor/head combo.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: M1 or TUNNELRAM
[Re: A/MP]
#3261133
10/01/24 06:57 AM
10/01/24 06:57 AM
gregsdart
A much better option. My thoughts are how are vacuum secondary carbs going to function when they have a lot of flow capacity to cubic inch. Maybe a call to Holley tech might help, or someone may have done some research on a dyno to give you a starting point. How big are the carbs?
