Page 2 of 3 1 2 3
Re: surgung issue persists 340 4bbl [Re: dOoC] #325595
05/23/09 08:11 AM
05/23/09 08:11 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
As already stated, if it's surging at steady cruise, it's to lean in the cruise mode. Find out what metering rods are in it and go 1 step richer in the cruise mode and your problem will dissapear.
Re: surgung issue persists 340 4bbl [Re: Mopar73340] #325596
05/23/09 09:27 AM
05/23/09 09:27 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Sounds to me like it might be lean, or it might be the vacuum pod adjustment. There is no reason to unplug the vacuum advance on this car except ignorance... So lets fix that. The vacuum advance only works at light throttle and cruise conditions. It add advance to the engine at these times because it gets much better milage and more power with less throttle. But, it's "tuned" for a certain level of vacuum. The cam change affected that. So now you need to adjust it. I believe what is happening is the timing is getting advanced too much at cruise. There should be a small allen wrend that will just fit inside the vacuum hose nipple on the vacuum advance dashpot on the distributor. Something like 11/32. In any event, unplug the hose, take that allen wrench and stick it into the nipple... It will go in and engage a screw in there. Turning clockwise will lower the vacuum required to advance. Counterclockwise will raise it. I go two full turns as one adjustment. Drive the car with the hose connected, disconnect and go two turns counterclockwise, reconnect and drive agin. When the surge is gone it's done. No reason to lose it entirely. Also, you may find that tuning the rest of the ignition curves will help it run better too.
Re: surgung issue persists 340 4bbl [Re: moper] #325597
05/23/09 10:46 AM
05/23/09 10:46 AM
Ashburn, Virginia
ashburnmike Offline OP
Ashburn, Virginia
Here is an update.
The vacuum hose remedy isn't working.
I moved the timing from 5 btdc to 10 btdc to see if that had any effect - it did not.
I'm going to try the vacuum pod idea and see what happends.
Hang in with me here guys. I really appreciate all these suggestions.
Mike
Re: surgung issue persists 340 4bbl [Re: ashburnmike] #325598
05/23/09 12:39 PM
05/23/09 12:39 PM
Mike
I have more time than money
Re: surgung issue persists 340 4bbl [Re: RapidRobert] #325599
05/23/09 01:01 PM
05/23/09 01:01 PM
Ashburn, Virginia
Ashburn, Virginia
hahaha...Don't we all Robert.
I tried moper's suggestion about the vacuum advance pod. The hex key would turn counter clockwise @ will but was apparently maxed out clockwise as it wouldn't turn in that direction at all.
I made 2, 4 and 6 turn adjustments counter clockwise, road tested it each time and there was no difference. the problem is still there.
I drafted a '70 Chevy Z-28 guy from up the street and asked him to drive it and he felt the pulse/surge also with a steady petal...so I'm not imagining things.
It looks as though I need to attack the jets and rods next.
Any other suggestions to try before I pull the carb off the car?
Mike
Re: surgung issue persists 340 4bbl [Re: ashburnmike] #325600
05/23/09 01:33 PM
05/23/09 01:33 PM
Any other suggestions to try before I pull the carb off the car? Mike
yes , dont need to take the carb off just change these rods on top
Re: surgung issue persists 340 4bbl [Re: RapidRobert] #325601
05/23/09 02:01 PM
05/23/09 02:01 PM
Ashburn, Virginia
Ashburn, Virginia
Thanks Robert, Paul Fancsali, in an earlier post, recommends going to a .120 needle and jet the primary to 101.
I'm not sure where all this stuff is inside my carb but we will soon find out.
Now the hunt is on to find someone locally who may have the parts.
Mike
Re: surgung issue persists 340 4bbl [Re: ashburnmike] #325602
05/23/09 10:05 PM
05/23/09 10:05 PM
ohio
B5 GTX Offline
B5 GTX  Offline
ohio
What is the total timing and at what rpm does it come in at? I would bet it is to much or it is to much coming in to fast. Put a light on it and see how much it has at 2000 rpm them 3000 rpm. I never bother with initial timing on a performance motor, you are much better off setting the total timing.
good luck
scott
Re: surgung issue persists 340 4bbl [Re: B5 GTX] #325603
05/23/09 10:50 PM
05/23/09 10:50 PM
Ashburn, Virginia
Ashburn, Virginia
good luck
scott
I moved the timing to about 12 btdc @ 2500rpm.
This didn't have much effect by itself...however...since there were many suggestions that I was too lean...I backed the A/F screws out as far as they would go without coming out of the carb.
This has reduced the surging alot but it still does it.
we are getting closer.
Re: surgung issue persists 340 4bbl [Re: ashburnmike] #325604
05/23/09 11:09 PM
05/23/09 11:09 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Obviously you shouldn't have to have the A/F screws out that far to make a difference. But at least you have found an improvement!
Carter AVS strip kits (metering rods, jets and springs) are scare and costly if you can find them at all.
It may be time to consider modifying your Carter AVS to Edelbrock AVS specs. The Edelbrock AVS uses Carter AFB style metering rods and jets, which are still available as an Edelbrock AVS strip kit. Edelbrock has their carb manuals all online in PDF format, complete with tuning graphs.
To change to the Eddy AVS style, you'll need to get (or fabricate) flat Carter AFB style metering rod covers instead of the "humped" Carter AVS metering rod covers you have now. Then buy a Edelbrock AVS strip kit, and swap your Carter AVS metering rods and jets for the Edelbrock AVS equivalents. This is not nearly as hard as it sounds. The AVS is a very user friendly carb, well suited for beginners. You can do it!
BTW, while you have the carb off, you would be wise to install a 1/2" phenolic 4 hole spacer between the carb and the intake. The AVS carbs are well known for boiling all the fuel out of the bowl on hot days when you shut the motor down... the 1/2" spacer will cure the dreaded hot start problems...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: surgung issue persists 340 4bbl [Re: GO_Fish] #325605
05/23/09 11:35 PM
05/23/09 11:35 PM
Mike promise me you wont take the carb off(or the top off) until you put the richest pair("cruise" step) of rods in there(4 minutes) that are in the strip kit & take the car out for a spin
Re: surgung issue persists 340 4bbl [Re: RapidRobert] #325606
05/24/09 09:17 AM
05/24/09 09:17 AM
Ashburn, Virginia
Ashburn, Virginia
I'm trying really hard to avoid getting into the guts of my carb with my limited experience.
I did take one of the humpback plates off carefully (you'd think I was defusing an landmine)
and familiarized myself with the step-up piston, step-up spring and the metering rod. Now I see what you are referring to.
I will search the internet for a vendor for the rods you recommend,Robert and also the phenolic spacer Scott recommended.
In my frustration last evening, I was looking at the Edelbrock site and considered taking this carb off and replacing it. Then study the one I have. I still have no idea where the jets are (lol)
If I can find the rods and it solves the issue...that was certainly be more cost effective
The '70 Z-28 guy up the street said to toss the Carter and get a Holley. "A real man's carburator".
I told him once this issue is squared away, my Moparts partners and I are going to take this little Dart to track and blow the doors off his little Holley fed, white striped, orange car.
Mike
EDELBROCK PERFORMER SERIES 600 CFM, ELECTRIC CHOKE CARBURETORS
CALIBRATED FOR FUEL ECONOMY
Designed for small-block and small displacement big-block engines, these carbs are recommended only for stock to Performer level applications. They are not recommended for use on RPM or Torker II intake manifolds. Match with an Edelbrock Performer or Performer EPS manifold and other brands of similar design. Calibrated 2% leaner than #1405. Includes both timed and full vacuum ports for ignition advance. Comes with: Metering Jets - Primary .098, Secondary .095; Metering Rods - .075 x .047; Step-Up Spring - yellow (4" Hg). Use our Carb Stud Kits #8008 or #8024 if needed, see Installation Items. For auto trans throttle lever adapters and more, see Tuning Accessories.
Re: surgung issue persists 340 4bbl [Re: ashburnmike] #325607
05/24/09 09:39 AM
05/24/09 09:39 AM
The '70 Z-28 guy up the street said to toss the Carter and get a Holley. "A real man's carburator".I told him once this issue is squared away, my Moparts partners and I are going to take this little Dart to track and blow the doors off his little Holley fed, white striped, orange car.
Mike
Here's a pic of a strip kit $42.79 at O'reillys(they ordered it-2 days) though w your carb the kit # will be different. Only caveat is when you drop the rod assembly on top of the spring that you then wiggle it slightly till it finds its hole rather than forcing it. Sounds like your neighbor DOES need an attitude adjustment
Re: surgung issue persists 340 4bbl [Re: RapidRobert] #325608
05/24/09 09:53 AM
05/24/09 09:53 AM
Ashburn, Virginia
Ashburn, Virginia
haha...he's a good guy and has helped me tremendously getting this car going..if fact when we come to a questionable area he always advises to get on "my board" and see "what do your guys say"
I'll order the appropriate strip kit for this carb with the rods you advise.
I see in my diagrams that the main jet is at the bottom of the hole where the rod goes down and the secondary jet seems to be at the bottom of the float chamber. Am I reading the picture correctly?
I assume you have to take the carb apart to get access.
Re: surgung issue persists 340 4bbl [Re: ashburnmike] #325609
05/24/09 10:06 AM
05/24/09 10:06 AM
(1) yes (2) yes but just slapping the richest rod in there real quick will tell you if you are on the right track which way richening the idle mix screws is already pointing to. then you will need an innovate LM-2 A/F ratio meter to mix/match the correct combo of rods/jets to get your mixtures correct in all areas, idle, cruise,part throttle, power and then you will need....
Re: surgung issue persists 340 4bbl [Re: RapidRobert] #325610
05/24/09 10:26 AM
05/24/09 10:26 AM
Ashburn, Virginia
Ashburn, Virginia
....yes....and those series of questions will be forthcoming....I assues you.
I'll report back with a different post when the strip kit arrives and I put them in.
Thanks to everyone who has taken me this far solving this issue with your comments and suggestions.
Have a great Memorial Day weekend.
Let us all take a minute to remember our fallen comrades who allow us the freedom to mess with these old cars in the first place.
Mike
Re: surgung issue persists 340 4bbl [Re: RapidRobert] #325611
05/24/09 12:20 PM
05/24/09 12:20 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
That I know of, nobody sells strip kits for the Carter AVS (occassionally you see a 30 year old used kit on Ebag). The kit above is designed for the Edelbrock AVS which uses Carter AFB style metering rods and jets. You cannot just install Eddy AVS metering rods in a Carter AVS without going inside the carb and changing the jets and metering rod covers also (so that everything is AFB style). The Carter AVS uses a longer 3 step metering rod, where the Eddy AVS uses shorter AFB 2 step rods.
Re: surgung issue persists 340 4bbl [Re: GO_Fish] #325612
05/24/09 04:12 PM
05/24/09 04:12 PM
Ashburn, Virginia
Ashburn, Virginia
That is a bummer but good to know now.
I think my best option at this point is to invest in a new replacement carb, enjoy driving the car, and get the proper conversion parts for my old AVS.
I will look for a similar carb @ the Carlisle show and see if I can find one to practice on.
I will call Edelbrock Tuesday and get the recommendation, but what are your thoughts on which unit to go with.
Mike
Re: surgung issue persists 340 4bbl [Re: ashburnmike] #325613
05/24/09 04:23 PM
05/24/09 04:23 PM
When he said AVS I thought he had an eddie AVS not an orig one but all is not lost. Just invest ~40 some dollars in a strip kit & cut a pair of metering rod covers out of a bean can lid(flat),drill a small hole in them & drop in the richest set of rods(the cruise step) in it & replace the domed covers w your new flat ones & take her out for a spin. You dont need a new carb & no need (for now) to even take the top off
Re: surgung issue persists 340 4bbl [Re: RapidRobert] #325614
05/24/09 08:47 PM
05/24/09 08:47 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Now you are on the right track!
As long as you change everything to AFB jets and metering rods (and flat cover), then you are good to buy the Edelbrock strip kit (actually, everything you need to swap ((except the flat metering rod covers))is in the Eddy kit). Just swap the new jets and rods in and put your Carter parts you remove on the shelf. Pretty simple conversion, then you have essentially an Eddy AVS. Edelbrock won't want to speak to you about converting your Carter, they are in business to sell you a new Eddy $$$$$. But the main difference between the Eddy AVS and the Carter AVS you have is AFB metering rods, jets and flat metering rod cover. It's not a hard swap, you can do it in an hour (even if you've not done it before). Check the Eddy AVS PDF's on their website, it will be a big help in dialing the carb in.
Page 2 of 3 1 2 3
