Variable speed AC compressor #3255803
09/04/24 02:30 PM
09/04/24 02:30 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Just ran into another problem and needing some help. 2019 5.7 out of a cop car. Ordered AC compressor fittings from Bouchillon. Won’t fit. Paper work from Bouchillon says will not work on variable speed compressors. Compressor has a plug on bottom rear so I’m assuming I have a variable speed. Is there a none variable speed compressor that is a direct replacement. Don’t want to have to modify the mount points. Or are there fittings that will work on this compressor that will accept #8 and #10 fittings. If so can this compressor be run without using the variable speed.
Re: Variable speed AC compressor [Re: Dabee] #3255850
09/04/24 07:12 PM
09/04/24 07:12 PM
BDW Offline
BDW  Offline
This is the compressor sold by MP for the crate swaps.
I crossed the number on RockAuto, memory is foggy, but I think it’s from a 2016 Jeep.
Re: Variable speed AC compressor [Re: BDW] #3255862
09/04/24 08:39 PM
09/04/24 08:39 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Thanks I’ll check that out. From what I’m seeing it looks like the variable speed compressor was introduced in 2014. So I’m assuming a 2013 or earlier will work. Have a local salvage yard nearby that has a ton of late model Mopar’s. Going to take the variable seed comp there in the morning and see if I can find a compatible non variable speed comp.
Re: Variable speed AC compressor [Re: BDW] #3255886
09/05/24 12:02 AM
09/05/24 12:02 AM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
BDW
Just did a search on Rock Auto. 2014 Jeep compressor matches the photo you posted. Thanks for pointing me in the right direction. up
