Fast ratio pitman arms #3252743
08/20/24 08:00 PM
08/20/24 08:00 PM
Los Angeles, CA
JF_Moparts Offline OP
Los Angeles, CA
Hey everyone, I have fast ratio steering on two of my 71 b-bodies and we've been having an issue with getting the sector gear aligned properly so that the steering wheel is straight. These are the aftermarket pitmans which do not have the master spline/key. I'm wondering - has anyone else run into this problem? On the surface it seems like we should be able to get it close and then adjust with the tie rods, but in reality it hasn't been that easy. Any tips or tricks?
Thank you.
Re: Fast ratio pitman arms [Re: JF_Moparts] #3253067
08/22/24 11:14 AM
08/22/24 11:14 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
why not just file in a master spline in the replacement pitman arm to match the original ? shruggy
beer
