6-Pack Carb Base Gasket #3248186
07/29/24 04:16 PM
07/29/24 04:16 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Does anyone have an NOS Part # 2946531 6-Pack Carb base gasket to measure the correct thickness for me please.
What color was the factory Line installed ones with REAR stamped on them
Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 6-Pack Carb Base Gasket [Re: VCODE] #3248336
07/30/24 08:16 AM
07/30/24 08:16 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ll look through my collection of gaskets. However, I read an old hot rod magazines article about base gaskets. They claimed the factory ones were too thick and people tended to tighten then down too much and warp the base. They cut some out of thinner material after they milled/replaced the warp base with better results. I’ve prob got some old ones but I use the thinner ones supplied in my Chicago carbs kits with no problem. I do remember the ones with REAR stamped on them. I think they were grey. I may have some. I doubt I’ve got any in oem packaging, though. I’ll look for you.
Re: 6-Pack Carb Base Gasket [Re: fastmark] #3248395
07/30/24 12:00 PM
07/30/24 12:00 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Thanks for the info. I am just getting some info on what came factory installed. I seem to remember almost a cardboard material.
I always use factory torque specs to tighten them. About 200 inch pounds, not much
Re: 6-Pack Carb Base Gasket [Re: VCODE] #3248419
07/30/24 01:34 PM
07/30/24 01:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have one here, but my calipers are not to be found.....
They are tan in color & textured.
I can mail it to you if you like Bob?
Re: 6-Pack Carb Base Gasket [Re: Alaskan_TA] #3248428
07/30/24 02:38 PM
07/30/24 02:38 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
That's what I remember from the old days at Chrysler.
Yes please, you have my address
Thank you very much
Bob
Re: 6-Pack Carb Base Gasket [Re: VCODE] #3248598
07/31/24 12:57 PM
07/31/24 12:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Be on the lookout for an FJ5 envelope.
Re: 6-Pack Carb Base Gasket [Re: Alaskan_TA] #3248601
07/31/24 01:05 PM
07/31/24 01:05 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Will be.
Thanks Bob
Re: 6-Pack Carb Base Gasket [Re: VCODE] #3248662
07/31/24 06:32 PM
07/31/24 06:32 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Here’s what I found. Probably came from Bill Overcash stash I bought after he passed. About .070. It won’t let me post a picture from my iPhone
Re: 6-Pack Carb Base Gasket [Re: fastmark] #3248750
08/01/24 10:03 AM
08/01/24 10:03 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Never liked the OEM-style gaskets since I think they're so thick and don't seal well... IMO
The thin aftermarket style that I've used has no room for variation in surface contact between the cast carb bases and the intake mounting surface. "Old style" cast throttle plates do warp and crack, unfortunately.
I don't recall if I tried this approach w/ either of my old 6-BBL setups, but the thin gaskets coated with a light layer of grease could be a way to both reducing the warpage tendency and sealing the surfaces a bit better. I'd certainly give that a shot if I still had a Six Pack work
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 6-Pack Carb Base Gasket [Re: fastmark] #3248807
08/01/24 01:59 PM
08/01/24 01:59 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Wow, .070 pretty thick I would say
Re: 6-Pack Carb Base Gasket [Re: VCODE] #3248884
08/01/24 09:21 PM
08/01/24 09:21 PM
I've used both types of carb gasket on different six packs, cast iron and aluminum manifolds, as long as the base plates our flat and square to the manifolds they both have work fine up work shruggy
Re: 6-Pack Carb Base Gasket [Re: Alaskan_TA] #3250094
08/07/24 04:32 PM
08/07/24 04:32 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Thanks to Barry, the NOS one measures .034 thick
Re: 6-Pack Carb Base Gasket [Re: VCODE] #3250222
08/08/24 01:12 PM
08/08/24 01:12 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
Barry is a good egg ! up
beer
Re: 6-Pack Carb Base Gasket [Re: VCODE] #3250708
08/11/24 08:14 AM
08/11/24 08:14 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Thanks for measuring it, I scanned it before it left so I could add the thickness to a reference image.
Re: 6-Pack Carb Base Gasket [Re: Alaskan_TA] #3250783
08/11/24 03:25 PM
08/11/24 03:25 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Great picture. Thanks for doing that
Re: 6-Pack Carb Base Gasket [Re: VCODE] #3250802
08/11/24 04:25 PM
08/11/24 04:25 PM
A727Tflite Offline
A727Tflite  Offline
I have some left lose and in factory packaging if anyone needs them. PM me if needed.
