Sealant on blue Felpro waterpump gasket ?? #3245011
07/16/24 12:54 PM
07/16/24 12:54 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Should sealant be used on the blue Felpro w/p gasket - big block pump to pump housing ??
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245017
07/16/24 01:30 PM
07/16/24 01:30 PM
I use Gasket Cinch sealer adhesive on them when I use them up wrench scope
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245021
07/16/24 01:43 PM
07/16/24 01:43 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Usually they tell you in the instructions if included to use or not use sealant.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245026
07/16/24 02:10 PM
07/16/24 02:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
No
64 Plymouth Savoy
Dana 60
Re: Sealant on blue Felpro waterpump gasket ?? [Re: fourgearsavoy] #3245029
07/16/24 02:15 PM
07/16/24 02:15 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: Sealant on blue Felpro waterpump gasket ?? [Re: fourgearsavoy] #3245030
07/16/24 02:20 PM
07/16/24 02:20 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Says here (*point 2) to use RTV with a fiber water pump gasket I just replaced not too long ago on son's car?
Oops I just re-read the instructions and it says to use RTV with a fiber gasket?
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Neil] #3245033
07/16/24 02:24 PM
07/16/24 02:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Take a good look at your sealing surfaces - after all these years, they may not be minty flat & smooth.
I'll generally use a light smear of wheel bearing grease, or Permatex #2, depending on the situation & fluids.
If I glue a gasket on - usually due to fussy installation or location - I'll glue it to the removable part.
That way, any subsequent cleaning or removal doesn't have junk falling into the engine.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: A12] #3245034
07/16/24 02:25 PM
07/16/24 02:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I remember now I did use "International Gray" sealant and no leaks, no issues.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: A12] #3245045
07/16/24 03:22 PM
07/16/24 03:22 PM
5thAve Offline
5thAve  Offline
I always use the stinky gasket sealer.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245050
07/16/24 03:58 PM
07/16/24 03:58 PM
IMGTX Offline
IMGTX  Offline
Silicone/Rubber gaskets get nothing unless the instructions say to.
I use RTV on fiber gaskets to make removal easier later and for sealing. Just a thin smear. Just enough to hold it to the part and coat the surface.
Exceptions are Tranny gaskets get coated with trans fluid.
And
Cork/thick fiber Valve covers get RTV on the valve cover side and oil on the cylinder head side.
Served me well for many years.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245092
07/16/24 07:57 PM
07/16/24 07:57 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
Master, again and still
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245112
07/16/24 10:07 PM
07/16/24 10:07 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
"This is what Permatex recommends:
www.permatex.com/products/gasketing...ermostat-rtv-silicone-gasket-maker-5-oz/"
I didn't read "big block Mopar" anywhere there.
Anyhow, I don't want to "make" a gasket, I just want to coat/seal the gasket.
Personally I don't think RTV and a cardboard gasket are meant to go hand in hand. I'm leaning towards the Permatex red stuff in the spray can. Wouldn't have even asked the question if I'd had the thing in my hand at the time.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245115
07/16/24 10:46 PM
07/16/24 10:46 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Put it together dry. (With that gasket of course)
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245118
07/16/24 10:56 PM
07/16/24 10:56 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I use permatex Ultra black on most everything twocents
Re: Sealant on blue Felpro waterpump gasket ?? [Re: TJP] #3245121
07/16/24 11:06 PM
07/16/24 11:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The Permatex stuff both Dave and I posted is literally the best one they offer designed specifically to go up against glycol. You can make your own 'gasket' with it, or use it as a dressing on a gasket per #5 on the list on the webpage. Yes, you can use other substances, but they may or may not work as well as this one does in the long term.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Neil] #3245127
07/17/24 12:42 AM
07/17/24 12:42 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Paper gaskets go on dry, with a thin smear around any areas adjacent to water that may show corrosion or pitting.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: TJP] #3245159
07/17/24 06:50 AM
07/17/24 06:50 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
Same here.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245178
07/17/24 08:51 AM
07/17/24 08:51 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I use the above Permatex Blue on everything that touches coolant (intake, thermostat housing, water pump/housing, hoses, etc.). It's kind of hard to find it anymore in stores in the larger tube, so I usually buy the smaller tubes and have them on hand.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: YO7_A66] #3245194
07/17/24 09:43 AM
07/17/24 09:43 AM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
Shouldn't WHAT fluid the gasket and sealant are sealing against be considered?
Personally, I never put any gasket on dry anymore. If nothing else, I use Permatex's version of Hylomar. But never dry. If you have good luck with gaskets sealing dry, then by all means keep doing it. But I got broke of that a long time ago. twocents
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245295
07/17/24 03:14 PM
07/17/24 03:14 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Originally Posted by DaveRS23
...I use Permatex's version of Hylomar. twocents
Whoa, hold on
Permatex dropped that license years ago. Did they restart again?
I had to order a tube from England, but it is worth every penny.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: A990] #3245305
07/17/24 04:04 PM
07/17/24 04:04 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
with flat paper / fiber gaskets. I'll use KW coppercoat or brushable Permatex ( the purple stuff )
Enjoy life today, It has an expiration date
Re: Sealant on blue Felpro waterpump gasket ?? [Re: A990] #3245351
07/17/24 07:31 PM
07/17/24 07:31 PM
Torq37 Offline
Torq37  Offline
Whoa, hold on
Permatex Permashield in an orange tube. Has been available on Amazon for at least a couple years that I know of.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: A990] #3245367
07/17/24 08:11 PM
07/17/24 08:11 PM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
Whoa, hold on
Here ya go:
www.amazon.com/Permatex-85420-Perma...LBVA3aOuaLzIb7pIzUoVlT2CsQvu8fQct-MBURO-
www.amazon.com/Permatex-PermaShield...LBVA3aOuaLzIb7pIzUoVlT2CsQvu8fQct-MBURO-
Same stuff just different source and price.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245372
07/17/24 08:55 PM
07/17/24 08:55 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Thanks.
Thats my mostly used sealant anymore.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245385
07/17/24 09:44 PM
07/17/24 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
no offense but they'd probably like to sell you a special sealant for everything 🙄🤣 beer
Re: Sealant on blue Felpro waterpump gasket ?? [Re: TJP] #3245411
07/17/24 11:40 PM
07/17/24 11:40 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
So in my travels to the auto parts stores I noticed that some of the application specific stuff Permatex sells comes in smaller sized tubes. That means you get enough for the task at hand, and don't get stuck with a 3/4 full tube of leftovers after a repair project that just sits on the shelf and dries up. When looked at it that way it's less money wasted unless your replacing multiple water pumps every month as a tech. Then the bigger tubes are what you'd want to have around.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Neil] #3245485
07/18/24 10:50 AM
07/18/24 10:50 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
i have heard that storing tubes of sealant and glues in a refrigerator keeps them from going bad.
any truth to that ?
if so, i would be worried smells from them would permeate food items. would keeping that kind of stuff in a tupperware type container prevent that from happening ?
beer
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245487
07/18/24 10:56 AM
07/18/24 10:56 AM
an8sec70cuda Offline
I always use a light coat of ultra grey silicone on them.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: Sealant on blue Felpro waterpump gasket ?? [Re: TJP] #3245523
07/18/24 02:47 PM
07/18/24 02:47 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
A lot of those sealants are more readily available because of the ISO (i.e., 9001 etc.,) and MIL specs standards. At work we had to use Loctite Gasket Eliminator and make sure we used the correct one for the correct application of either LGE 515, 518 or 5188 and several other types in case of an ISO audit. Just saying why there are so many variations now. They call it "International Grey" sealant for a reason. wink
Re: Sealant on blue Felpro waterpump gasket ?? [Re: DaveRS23] #3245550
07/18/24 05:58 PM
07/18/24 05:58 PM
I use that on thermostat housing with the stock composition gaskets, works good, last a long time wrench up scope twocents
Re: Sealant on blue Felpro waterpump gasket ?? [Re: Stanton] #3245681
07/19/24 09:37 AM
07/19/24 09:37 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Haven't seen that stuff since I last built motors at my uncle's machine shop. I can smell it now. What I still use from those days is Permatex Aviation Form A Gasket on paper gaskets. I just remember that red stuff getting on everything after a while. The Aviation stuff brushes on, and it's impossible to use too much. I can't stand silicone, and I've seen many motors with chunks of that [censored] plugging passages. I remember pulling a crank out, and there was a chunk of that crap right in the main bearing oil hole.
Re: Sealant on blue Felpro waterpump gasket ?? [Re: 375inStroke] #3245683
07/19/24 09:42 AM
07/19/24 09:42 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
The red Permatex stuff in both spray and brush is still on the shelves.
I really like that stuff for almost all apps.
Spray or brush it on, let it tack-up for a minute.
Excellent for machined surfaces, gas, oil or water.
Joe
Re: Sealant on blue Felpro waterpump gasket ?? [Re: jlatessa] #3245721
07/19/24 12:55 PM
07/19/24 12:55 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Indian Head Shellac?
Re: Sealant on blue Felpro waterpump gasket ?? [Re: moparx] #3245812
07/19/24 08:29 PM
07/19/24 08:29 PM
IMGTX Offline
IMGTX  Offline
any truth to that ?
beer
Cold will slow most chemical & biological reactions so it should help but exposure to air/moisture is the real kicker on these sealants.
I just keep the tubes capped and if the end hardens stick a screwdriver through the end to get the soft stuff. When that stops working I find a soft spot and poke though the side.
Pretty much what every body i know does..
I toss out less than an1/8th of a tube a year and I don't look back.
I would loose mine in the fridge.
