Re: NGK Spark plug gap to 13.5 compression BB
[Re: Sammy]
#3232077
05/10/24 03:54 PM
05/10/24 03:54 PM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
I'm running a ngk 5672A-8 #7173 sparkplug and need the gap size. Indy 440-1 aluminum heads. N.A. I would set them at .035 which OOTB is what they should be close to.
Brian Hafliger
[Re: Brian Hafliger]
#3232089
05/10/24 05:32 PM
05/10/24 05:32 PM
Posts: 10,088 Frostbitefalls MN (Rocky&Bullw...
gregsdart
[quote=Sammy]I'm running a ngk 5672A-8 #7173 sparkplug and need the gap size. Indy 440-1 aluminum heads. N.A. I would set them at .035 which OOTB is what they should be close to. [/quote ]me too
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Sammy]
#3232130
05/11/24 02:38 AM
05/11/24 02:38 AM
Posts: 43,741 Bend,OR USA
Cab_Burge
It depends on which ignition and plug wires as far as how much gap I would use as well as how much compression ratio and fuel used Post yours please
[Re: Cab_Burge]
#3232348
05/12/24 04:24 PM
05/12/24 04:24 PM
gregsdart
It depends on which ignition and plug wires as far as how much gap I would use as well as how much compression ratio and fuel used Post ours please Good point. At 15.25/1 and methanol i run em tighter, .024
[Re: Sammy]
#3232465
05/13/24 09:08 AM
05/13/24 09:08 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
I ran R5671A-8 NGK plugs gapped .030"-.035" on a 14:1 compression Indy headed 440 w/ C12 fuel.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
