What could cause 5.7 truck to die at low speed cruise?
#3211512
02/07/24 02:14 PM
02/07/24 02:14 PM
Posts: 2,170 God's Country - Etowah, TN.
A34
Gents,
My '04 Hemi Ram died twice yesterday driving through parking lots at about 5 mph. What could cause it to stall out at a low speed like that? In the past year it has had all the O2 sensor's replaced, egr valve, coil packs replaced, spark plugs replaced and fuel pump replaced. It has around 250K miles on it. Showing No Codes.
Thanks in advance !!
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: What could cause 5.7 truck to die at low speed cruise?
[Re: A34]
#3211523
02/07/24 02:39 PM
02/07/24 02:39 PM
Posts: 10,303 Someplace you aren't
SomeCarGuy
Does it have an IAC like Fords do? I’ve replaced that part on probably 8 fords in the family. One was even at the dealer and they couldn’t figure out the dirt common problem because they don’t throw a code when the part fails. They just die. I don’t know of mopar uses one or not.
I want my fair share
[Re: SomeCarGuy]
#3211525
02/07/24 02:48 PM
02/07/24 02:48 PM
A34
Does it have an IAC like Fords do? I’ve replaced that part on probably 8 fords in the family. One was even at the dealer and they couldn’t figure out the dirt common problem because they don’t throw a code when the part fails. They just die. I don’t know of mopar uses one or not. Thanks, great suggestion! From what I could find online, it doesn't look like Dodge uses one. I've sprayed some throttle body cleaner in the throttle body back when I replaced the ignition parts, but I guess after 250K miles, maybe it needs replacing. Not sure how long they last.
DEO VINDICE
[Re: A34]
#3211539
02/07/24 03:13 PM
02/07/24 03:13 PM
Posts: 13,690 md
mopars4ever
md
Did you check the battery? Had that happen to me years ago. BTW, I have a good used 06 5.7 ram throttle if you want to try it.
[Re: Sniper]
#3211585
02/07/24 05:06 PM
02/07/24 05:06 PM
A34
How about starting with puling the codes, if any. Forgot to put no codes showing.
DEO VINDICE
[Re: 360view]
#3211890
02/08/24 10:35 AM
02/08/24 10:35 AM
Posts: 10,943 North Dakota
6PakBee
North Dakota
Those cold solder joints are “The Devil’s Plaything” and are mostly due to government mandated lead free solder. The first generation Neons were famous (infamous?) for cold solder joints on the instrument cluster. I had a '97 and a '98 and they both had the problem.
[Re: mopars4ever]
#3211956
02/08/24 01:08 PM
02/08/24 01:08 PM
A34
Did you check the battery? Had that happen to me years ago. BTW, I have a good used 06 5.7 ram throttle if you want to try it. Thanks! I appreciate the offer! If I narrow it down to that, I'll let you know. I think the battery is fairly new, but I need to double check!
DEO VINDICE
[Re: jcastle1]
#3211957
02/08/24 01:11 PM
02/08/24 01:11 PM
A34
Crank sensor bad. Replace cam sensor while you're at it. Thanks, I've owned this truck since new and don't think I've ever replaced those.
DEO VINDICE
[Re: A12]
#3212173
02/09/24 11:38 AM
02/09/24 11:38 AM
A34
Don't know if you mentioned that when it stalls does that mean you have to restart the truck or it hesitates and keeps running? It dies completely. But, restarts fine.
DEO VINDICE
