Re: Whats the best cruising gear?
[Re: Dartman75]
#320895
05/19/09 09:38 PM
05/19/09 09:38 PM
Posts: 571 Western NC
68Bullit
Western NC
Besides on the highway, when you need to accelerate up a hill like you're on the level, just down shift because second gear on a tall rear is probably about where drive is on a 4.10 geared car, and having that extra drive gear ready won't limit your top speed for rounding that top attempting to lauching into near earth orbit
[Re: 70RT Charger]
#320899
05/20/09 11:46 AM
05/20/09 11:46 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
How tall of a tire? 26" tall or less, I'd probably go 2.76. 27-29" tall, 2.94, 30-32" tall, probably 3.23's
I had 3.55's and 27" tall tires and HATED it on the interstate (speed limit 70). was buzzing along at 3000-3300 RPM. I'd get a headache after about a half hour from the noise. I kept them but put in an A500 OD, and dropped it to an effective 2.45....
another option would be to use an A833OD (.73 OD) or a Passon OD (.8 OD). would turn your 3.91's into 2.85's or 3.13's effectively....
[Re: sthemi]
#320900
11/23/09 06:36 PM
11/23/09 06:36 PM
hey i have a 77 dodge d100 im putting a 318 in it with 400hp and 400tq with a 727 torqe flight and 9 1/4 rear end and im just using it for street put i also want it to be fast so what would the best gear ratio be for me? thanks for eny of the repliys
[Re: dirtybee]
#320905
11/24/09 12:48 AM
11/24/09 12:48 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
just a thought but if you run an 8 3/4, what i do is cruise with my 2.76 and throw in the 3.91's for the track. after a few times it only takes about an hour, and by the way my car came withe 3.91 which i love, but when i put the 2.76 in for a road trip, i also loved them..... awesome, i'm gonna get one of everything, or at least a 4.10 or 4.30 or 4.56 with a spool with my spare housing.
FWIW I do the same thing & to make it easier I added a drain plug to the axle housing... And I keep the correct speedo gear in the same box with 3rd member...
[Re: 1_WILD_RT]
#320906
11/24/09 01:20 AM
11/24/09 01:20 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Let me add ...... I don't think I would ever stick a steep-gear in my 62 ever again. The car is a 12-flat car now ...with the 2.76 gear .....and is an absolute BALL to drive on the street. The last time I drove to the track... 60 miles(120 miles RT) .... I stuffed a couple of Stangs, a Vette and Crumb-aro in the weeds. As was said in Dirty Mary/Crazy Larry .... the top-end is uNlimited !
[Re: dOrk !]
#320907
11/24/09 02:42 AM
11/24/09 02:42 AM
Posts: 2,112 New Jersey, US of A
PlumCrazy73Dodge
New Jersey, US of A
All depends on what YOU are looking for out of your car while cruising...
Just to cruise and enjoy yourself with the occasional stomp - 3.23's
Cruising more locally with more stomping - 3.73's
The choice is yours I have had 4.56 in my challenger...that did not last that long....I was tached out at like 50 mph
I run 2.76's now and it just dogs too much, but on the highway it keeps going and going and going...which is nice to drop the hammer and hit trip digits
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
[Re: PlumCrazy73Dodge]
#320908
11/24/09 03:03 AM
11/24/09 03:03 AM
dOrk !
Florida STAYcation
You need a BIG TORQUE motor to pull that gear.
When driving it real REAL easy on the street ...I can start-off in 3rd gear ...from a stop-light. ..... ......
[Re: nz383man]
#320911
11/24/09 10:56 AM
11/24/09 10:56 AM
patrick
Grand Haven, MI
point of reference, that there's more to it than just gear ratio...all calculations assuming no converter slip.
at 70 mph, a 2.76 rear with a 26" tall tire is turning 2500 RPM
the same tire (26") with a 3.23 is turning 2900 RPM
the same gear (3.23) with a 28" tall tire is turning 2700, and with a 30.5" tall tire is turning 2500 RPM at 70, the same as a 2.76 with a short tire....
[Re: DaytonaTurbo]
#320912
11/24/09 11:01 AM
11/24/09 11:01 AM
the overdrive in my ride w/4.30 gears makes it act like a 3.01 gear. also running 295/50/15 BFG drag radial. the 3+:1 first gear makes it a killer on the street lol. cruises like a dream @ 80mph on the open road.
#320913
11/24/09 11:06 AM
11/24/09 11:06 AM
what kind of overdrive unit are you using ? I know that when I buy my dart it will have 3.90 or 4.11 gears but I want to also use and overdrive cause I drive to shows.
#320914
11/24/09 11:17 AM
11/24/09 11:17 AM
GM700R4. cheapest/easiest/most reliable way to put an automatic OD in a MoPar. jmo.
