Page 19 of 74 1 2 17 18 19 20 21 73 74
Re: Engine and Trans Lost & Found [Re: daniel_depetro] #3204
08/02/08 01:57 PM
08/02/08 01:57 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
Found:
1970 F 440 HP2 440 six pack engine.
Engine VIN pad # 0A166949
All original and never changed around. It looks very, very much like new on the inside. It is complete from air cleaner assembly to oil pan. Only items missing were the exhaust manifolds (probably ran headers) & it had M/T aluminum valve covers instead of the correct 1970 only HP units it was born with. Right after I got the engine home I re-installed the correct 1970 only HP valve covers and a set of HP exhaust manifolds back in place.
I bought it 3 years ago in Pittston, PA which is half way between Wilkes-Barre & Scranton.
The seller told me it was a 1969 six pack engine and came out of a Roadrunner that was his buddies car. They both raced it and it ran low 13's. It is obviously a 1970 engine, but I do not doubt the rest of his claims due to the missing manifolds & changed valve covers.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: Engine and Trans Lost & Found [Re: daniel_depetro] #3205
08/02/08 04:10 PM
08/02/08 04:10 PM
FOUND:
1970 F 440 HP2 "six pack" block & main caps.
Engine VIN pad # 0G219932
I bought this block & caps in Racine, WI. The previous owner pulled it down and had it hot tanked and discovered a couple of casting lines that he thought were cracks. He decided to just get another block and kept all the original six pack stuff and sold the empty block to me. I bought it thinking it was cracked, but planned on just using it as a 'dummy' engine to have set-up on a stand. We finally made our way down there to pick it up and my father said it doesn't look cracked to him, more like an odd casting marks. My father kept saying it would be a shame to have that block just lay around if it was a good block and convinced me to at least have it checked out. I decided to get it fixed (if it could be) so I brought it to my welder so he could work his magic. He mag'd it and used his mirrors and magnifying glasses to check everything out and said it wasn't cracked at all, they were indeed just casting markes that were not that good looking. He said he could cover them if I wanted but said it would be a waste as just painting the block would make them disappear.
Re: Engine and Trans Lost & Found [Re: cudagee] #3206
08/10/08 09:02 AM
08/10/08 09:02 AM
Ohio
moparrjm Offline
super gas
moparrjm  Offline
super gas
Ohio
Lost: Auto Trans 1A155603 please help me find it. It may be in the San Jose, Cal. area, Thanks. Pm me through here or cmtsrjm@columbus.rr.com
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #3207
08/10/08 08:55 PM
08/10/08 08:55 PM
New York
N
NYAL23 Offline
NYAL23  Offline
N
New York
Still looking for hemi and 4speed trans #156187 alexfutter@yahoo.com
Re: Engine and Trans Lost & Found [Re: NYAL23] #3208
08/19/08 10:30 PM
08/19/08 10:30 PM
Missouri
3
3_RTs Offline
3_RTs  Offline
Missouri
I'm still looking for my hemi engine VIN # 0G141214.
Thanks,
Jerry
jaleake@stjoelive.com
Looking for 727 Trans 1B365372 [Re: 3_RTs] #3209
08/29/08 01:45 PM
08/29/08 01:45 PM
Car Country
TripleTX9 Offline
John with a "G"
TripleTX9  Offline
John with a "G"
Car Country
Looking for my original Transmission for my 1971 R/T Challenger. I know this is the same as looking for a needle in a haystack, but I would really like to find it since I have the matching motor. From what I can tell of the history of the car, it lived its life as a race car in the E Freetown, MA area. The car was born a factory triple black, stripe delete 71 Challenger R/T. My 727 Transmission number would be as follow:
Transmission #: 1B365372
If you have any info on the trans or may have known of or seen my car in its early life, please PM me!
Many thanks in advance if anyone can help!
Looking for 70 440 Engine # OG177062 [Re: TripleTX9] #3210
08/31/08 07:09 AM
08/31/08 07:09 AM
Mass
charge70 Online content
charge70  Online Content
Mass
Looking for the original engine or block for my 70 Charger R/T.
VIN # is OG177062
I purchased the car from Ed Wilson in Lynchburg,VA.in 1982.I was told the car originally came from No.Carolina.Hope someone can help me out.Please PM me here or e-mail me at charge70@msn.com Thanks in advance,John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Found [Re: charge70] #3211
09/04/08 06:12 PM
09/04/08 06:12 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
Found - 1970 HP 440 - 0G226927
Found - Big Block 727 Tranny - 1968 - 8G137263
Probably originally from Missouri area.
Rocket Restorations
Re: Found [Re: tallzag] #3212
09/04/08 09:07 PM
09/04/08 09:07 PM
naples fl
70 v code Offline
70 v code  Offline
naples fl
8a216009 4speed
Re: Found [Re: 70 v code] #3213
09/06/08 12:55 AM
09/06/08 12:55 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
I've got somebody's 23 spline 4 speed tranny. 9G224091.
Re: Found [Re: 1965_PLYMOUTH] #3214
09/07/08 01:53 AM
09/07/08 01:53 AM
CENTRAL MINN
CENTRAL MINN
I have somebody's bare 340 block dated 6-70. as far as I can tell, it's from an E body. 1B234119. scarfed it up from California.
Re: looking for 440 and 727 for XS29U0G198796 [Re: 1965_PLYMOUTH] #3215
09/09/08 08:47 PM
09/09/08 08:47 PM
Qc, Canada
moparguy55 Offline
moparguy55  Offline
Qc, Canada
Hi all
looking for the 440 block for my 70 charger along with 727.
Car was sold originally in canada then spent quite some time in Mass. Where i heard the engine was taken out.
XS29U0G-198796
Pm me or raoul55@yahoo.com
Re: looking for 440 HP '69 charger engine [Re: moparguy55] #3216
09/10/08 02:41 PM
09/10/08 02:41 PM
CENTRAL MINN
CENTRAL MINN
I'm in search of my original 1969 charger 440 HP engine VIN # 9G112792. car was purchased in 1979 near MAPLE LAKE, MINNESOTA. the car is a copper or bronze metallic with tan vinyl top. any help is appreciated. gregATclassiccarsplus.com
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #3217
09/26/08 01:05 AM
09/26/08 01:05 AM
New Zealand
U
UCODE NZ Offline
UCODE NZ  Offline
U
New Zealand
Looking for the Engine and Trans for my 70 440RT Challenger 0E142796. Thanks
71 HEMI BLOCK [Re: Alaskan_TA] #3218
10/11/08 04:38 PM
10/11/08 04:38 PM
ORANGE PARK,FL
gdmusclecar Offline
gdmusclecar  Offline
ORANGE PARK,FL
I HAVE AN ORIGINAL 71 HEMI BLOCK VIN# 1G163026 ,IF ITS YOURS CALL ME.
E-MAIL: GDMUSCLECARPARTS@YAHOO.COM
SHOP# 904-272-1803 DANA OR GLENN
Re: 71 HEMI BLOCK [Re: gdmusclecar] #3219
10/16/08 06:19 PM
10/16/08 06:19 PM
Colorado
CuriousYella70 Offline
Colorado
I'm looking for the original 340 for my 71 Demon
LM29H1E101585
Build date was August 28th, 1970
Re: Engine and Trans Lost [Re: ChrisD] #3220
10/17/08 01:39 PM
10/17/08 01:39 PM
kuUSAmo FINLAND
Haapakowalski Offline
kuUSAmo FINLAND
WANTED: I looking for my -70 Challenger 340 engine VIN# 0B234993, i have matching # trans but not correct engine block. Car came from PA couple of months ago to here Finland. It has now 340 engine VIN# 9B319325.
I also lookin for 440 engine and 727 transmission for my -69 300 Convertible. Vin# 9C203870. Car is from Michigan (St. Clair, 48079).
rauno.haapakoski@gmail.com
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #3221
10/24/08 05:21 PM
10/24/08 05:21 PM
Washington State
70_FY1_N96_BEEP Offline
Washington State
Have complete 1969 Road Runner 383HP engine pulled from my '70 RR:
RM23N9G110442
Looking for my original '70 motor: Boise area?
RM23N0E118630
alchristensen@gmail.com
Re: Engine and Trans Lost & Found [Re: Alaskan_TA] #3222
10/27/08 10:04 PM
10/27/08 10:04 PM
N. Ca.
floorit426 Offline
floorit426  Offline
N. Ca.
Hi,
I have a 426 that was swapped out of an original'69 Hemi Superbee over thirty years ago.
I will only be willing to do this if it is the exact car. VIN on the engine, at least what I can read, is 9A243823. The 8 might be a 6.
(925)454-5131-Bill
Re: Engine and Trans Lost & Found [Re: floorit426] #3223
10/28/08 11:26 PM
10/28/08 11:26 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Looking for my original engine.
1968 RR 383
Block ID 8A258153
PM me if found
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
