Re: modern alternator swaps for BB, highest amp at idle
[Re: AndyF]
#32045
11/21/06 12:28 AM
11/21/06 12:28 AM
moparpollack
Lil Herman
Lil Herman
85086
Andy are you doing these for small blocks?
[Re: AndyF]
#32047
11/21/06 09:28 AM
11/21/06 09:28 AM
Posts: 3,920 n.e. pa.
65rbdodge
n.e. pa.
i got a 1 wire powermaster alt. and brackets from www.magnumhp.com it was a really easy swap. my car used to not charge at idle now it charges great.
Re: modern alternator swaps for BB, highest amp at idle?
[Re: challengermike]
#32048
11/21/06 10:44 AM
11/21/06 10:44 AM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
So is it ok to leave the factory amp gauge hooked up?I see in the diagram it is.I have heard that the connection at the bulkhead connector and the amp gauge couldn't handle that may amps?Or is it OK because you have another wire going to the battery also?
challengermike The way that is wired it effectivily bypasses the factory amp guage, which is a must on any alternator upgrade, the factory wiring and bulkhead connector will not tollerate any of these late model higher output alternators for even a short time. That diagram was done that way (keeping existing wire to alternator) so as not to hack up a factory harness for those that may want a better charging system, but have the option to return everything to stock with little effort.
Rick
[Re: Blown71X]
#32049
11/21/06 11:32 AM
11/21/06 11:32 AM
Posts: 150 Arkansas
defiance
Arkansas
I'm using a 150A stinger GM style big case alternator. Works perfectly with the March Perf serpentine kit. The only think I had to do differently is the adjuster bar for the alt - I had to move the mounting point to one of the timing chain cover bolts. The spacer is pretty close to the harmonic balancer (around 5mm clearance at the top), but that hasn't been a problem so far. I've got an MS, A/C, 1400W (RMS) stereo, alarm, aftermarket lights (soon to be HID), 4 (ran 5 for a while) electric fans (2 for a/c condenser, 2 for radiator) etc.etc. and I can idle with everything on @ 800rpms at 14.5v. Here's some pics of the alternator, brackets, pulleys, etc... http://www.cardomain.com/ride/2324498/4Unfortunately, the changed rod mounting point isn't really visible in the pics... I'd take a pic of the changed bracket, but everything's all apart right now for a rebuild.
[Re: whiplash]
#32050
11/21/06 03:30 PM
11/21/06 03:30 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've got a link at home to someone that makes a kit for 100+ amps out of a square back and round back alternator. What's wrong with doing that and keeping the stock looking unit?
[Re: defiance]
#32051
11/21/06 03:32 PM
11/21/06 03:32 PM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
I had a big issue with needing a good amount of amps at idle. I currently run a 8mm cog system with GM 100amp unit over driven 2:1 with a 8mm cog pulley from these guys http://productengr.com/alternators.htmand a BDS blower pulley cut down to 0.75 wide for the crank and a low mount bracket from Jegs for a BBC....Works very well even with a 100amp alternator. See attached pic
[Re: feets]
#32053
11/21/06 07:19 PM
11/21/06 07:19 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
I would love to do that, but if that alt [Email]cr@ps[/Email] out, I have to sideline my daily and only car and borrow one while i mail order another. If I can fine the correct vehicle application for a cs130, it is:
-a direct bolt in -available at 90% of parts stores across the US -capable of providing the amps I need -allows me to remove the voltage regulator -simplifies the wiring harness -I can relocate my ignition box (really only my concern)
on top of that, it was my understanding that most of the "rebuilds" that promise more amps accomplish it but at the sacrifice of idle amps, which is where I really need it.
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
[Re: feets]
#32054
11/21/06 10:07 PM
11/21/06 10:07 PM
Blown71X
super gas
super gas
A tad North of Indy
Show me one of those that actually will have ANY idle output amperage and i`ll go back in my hole, as I said before THE only way any of the old style mopar alternators will do anything worthy of getting excited about is if lightening hits them....You can put perfume on a pig....it`s STILL a pig.
challengermike The original feed for the inside of the car comes from the fuse link at the starter relay stud, which is hooked to the positive battery cable, in the wiring diagram you will notice there is a 8 guage wire from the alternator output stud to the battery positive, With the original amp guage wire ALSO hooked to the alternator stud you have now essentially jumped across the 2 amp guage wires eliminating current flow thru the guage but giving you 2 wires and close to double the current carrying capability to feed the inside. THE sole reason it is wired this way is to give the owner a option to have a better charging system and NOT have to hack up a factory harness should it be needed to be returned to stock. It is NOT necessary to hook it up this way if you either prefer to do an internal guage bypass at the cluster and feed it directly from the battery/starter relay, or don`t care about keeping things so they can be returned at some point. All that is required and mandatory is the 8 guage from the alternator to the battery positive. No matter which way you choose, PLEASE make sure this wire is protected either by fuse link or a proper sized fuse/breaker.
Rick
[Re: Blown71X]
#32055
11/21/06 10:21 PM
11/21/06 10:21 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
I understand now,Thanks,So instead of all the current going through the inside of the car and back out it can split the current to half in the car and half directly to the battery.But because the 8 gauge wire is directly to the battery the inside of the car isnt alternating current anymore its direct.
[Re: feets]
#32056
11/21/06 10:49 PM
11/21/06 10:49 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I installed on of those kits and yes it does increase output, I measured a peak of 94 amps. The downside is it DROPS idle output by .5V and this is with a 10Ga wire running direct to the battery, amp gauge bypassed, bulkhead connector eliminated.
[Re: Skeptic]
#32057
11/22/06 01:28 AM
11/22/06 01:28 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What brand of alt are you talking about?
Im looking at going with a tuffstuff 100 amp, single wire unit, stock case style. The alt is rated for 58 amps at a idle speed of 750, assuming a 3 to 1 pulley ratio. Just wondering what brand you have.
[Re: 70blackfish]
#32059
11/22/06 08:26 AM
11/22/06 08:26 AM
whiplash
Summit, NJ
I have a 140 amp 1 wire, that fit with my stock big block alt brackets.
want a picture?
absolutely, plus who makes it, if its a stock application, etc. thanks.
[Re: whiplash]
#32060
11/22/06 09:39 AM
11/22/06 09:39 AM
whiplash
Summit, NJ
Blown71x, I found an auction for a cs130, parts stores around here are only selling remans. Is this the one I need to fit the stock brackets?
[Re: Von]
#32061
11/22/06 10:35 AM
11/22/06 10:35 AM
Skeptic
The Pale Blue Dot
read the quote in my post
[Re: feets]
#32062
11/22/06 11:05 AM
11/22/06 11:05 AM
Skeptic
The Pale Blue Dot
Re: modern alternator swaps for BB, highest amp at idle? *DELETED*
[Re: Skeptic]
#32063
11/22/06 11:27 AM
11/22/06 11:27 AM
Posts: 302 Middle of the US
Verga
Middle of the US
Post deleted by Verga
