Re: e body console brackets
[Re: moparmarks]
#3203844
01/11/24 04:20 PM
01/11/24 04:20 PM
Posts: 21 Fredonia, NY
diesel
Fredonia, NY
That is an outstanding reference picture Moparmarks! Thank you very much! If I'm going to do something, I'm going to do it right. I already contacted the guy I bought it from and he was pretty good about it... said he was sure it came from a cuda, *but* it was stored a long time ago and its possible it came from a b body. He is taking it back. So, it is on its way back. Thank you all for your help. I have already purchased the now correct set up, pictured below. Now, I just need to buy the correct linkage. Don't know if I should just buy it from yearone or find original parts. While I have your attention... yearone lists 2 different part numbers for the shift linkage, one for 1970 and one for 1971-74 The pictures look exactly the same... could someone tell me why there would be a difference between the years? For example I know the consoles are different only because 70 has a seatbelt holder and the 71 to 74 has an ashtray.
[Re: IMGTX]
#3204361
01/13/24 03:13 PM
01/13/24 03:13 PM
diesel
Fredonia, NY
Awesome information! Thank you very much! Sounds like I am after 1971 or later. I think you are right that getting rid of the nub and shift indicator will look much better. I have't had to look at it on a daily basis yet, once I do I am sure it having them there will definitely annoy me. lol Is this the conversion kit you were talking about https://www.manciniracing.com/mretp25.html Can this be bought and just replace that part of the column with out replacing the rest of it?
[Re: diesel]
#3204440
01/13/24 08:09 PM
01/13/24 08:09 PM
Posts: 12,314 Looking for a way out of Middl...
IMGTX
Yes. That is one. There may be others. You can get those parts from floor shift cars, trucks,and vans into the late 80's I buy a whole column for about $40 and scavenge parts. They are getting harder to find in junkyards though. This one is specific to the 70 and I believe it will keep the interlock operational. Not a big deal in my book. https://www.manciniracing.com/mretp26.htmlWhat I have not tried is to swap a 71 up head onto a 70 tube. It should work it is just 4 screws holding all those parts to the column tube, almost everything else is the same. The only difference I know of for sure is the 70/71's used a bolt to hold in the ignition lock. In 1972 they started using a spring loaded pin on the lock cylinder to hold it in the column. Moving to a 71 column head may require a new lock cylinder.
