plastic fuel tank repair? #32017
11/19/06 02:38 AM
11/19/06 02:38 AM
Kent, Wa
340SHORTY Offline OP
Truck Nut
Truck Nut
Kent, Wa
the main tank on my 76 dually that I bought 4 weeks ago has a gouge/hole in it. has anyone had any luck with the assorted repair kits out on the market ? results good or bad
I am truckless..
Re: plastic fuel tank repair? [Re: 340SHORTY] #32018
11/19/06 02:47 AM
11/19/06 02:47 AM
Ossineke, MI
Shian Offline
Shian  Offline
Ossineke, MI
I repaired a hole I could get almost my whole thumb in my aux tank aft of the rear axle and have been using it for almost two years now with no problem. It is call Pro Seal as far as I know you canít buy it on the civilian side, but if you donít find and thing else let me know I can get you some. I am a Blackhawk crew chief and we use it to seal just about everything on army aircraft. shian.huggler@us.army.mil
Re: plastic fuel tank repair? [Re: Shian] #32019
11/19/06 09:03 AM
11/19/06 09:03 AM
Alabama
78pwxpress Offline
78pwxpress  Offline
Alabama
Hey Shian, is this the same stuff your talking about?
http://epdtech.com/astro/astro.htm
Re: plastic fuel tank repair? [Re: 78pwxpress] #32020
11/19/06 01:50 PM
11/19/06 01:50 PM
Kent, Wa
Truck Nut
Truck Nut
Kent, Wa
Re: plastic fuel tank repair? [Re: 340SHORTY] #32021
11/20/06 01:15 AM
11/20/06 01:15 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I will say that I have patched holes in gas tanks, with fuel actually running out, with good ole JB weld.
Worth a try
Re: plastic fuel tank repair? [Re: dave571] #32022
11/20/06 01:22 AM
11/20/06 01:22 AM
Ossineke, MI
Shian Offline
Shian  Offline
Ossineke, MI
The stuff we use is a two part, but i have heard they make it in a tube. So it could be the same stuff.
Re: plastic fuel tank repair? [Re: Shian] #32023
11/20/06 01:33 AM
11/20/06 01:33 AM
dave571 Offline
dave571  Offline
Yes JB is a two part deal. Comes in two tooth paste tubes.
I prefer the "quick set" variety for all my on the road emergencies.
Saved another racers bottom last season.
Due to an install error, he had to ditch his tubes. It leaked like mad out of the wheel screws afterward. Mixed up some jb, and he didn't miss a round of qualifing.
Don't leave home without it.
