Re: What is the best helmet?
[Re: Hemi_Joel]
#3200418
12/28/23 09:31 AM
12/28/23 09:31 AM
Posts: 10,095 MN
JERICOGTX
MN
Did you forget you just bought a new helmet 2 years ago???
How could I forget? A tech official on Death Week informed me that it is a motorcycle helmet and not fire resistant. Plus the spots where the Nexgen fitting go have thick, non removable hard foam, so I can't mount them. So I need a new one. What size helmet does that big melon of yours take? You can try on my HJC if your head will fit.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3200425
12/28/23 10:32 AM
12/28/23 10:32 AM
Posts: 8,225 Plymouth, MI
Blusmbl
Plymouth, MI
I dug through the rulebook just for some clarification, and motorcycle helmets (like the RF1400 I have) are ok provided they are Snell M2015/2020 rated, with a couple exceptions. If you go 9.99 or quicker in an open bodied car with a power adder (or open bodied electric) it needs to be an SA rated helmet, not M. Pro mod, top alcohol dragster, top alcohol funny car, top fuel and funny car also all require SA rated helmets instead of M. Everything else, the M designation is ok per the rulebook.
That being said I don't know enough about the differences in helmet ratings to know which would be better if your head contacts a rollbar in an accident, as an example.
[Re: Blusmbl]
#3200497
12/28/23 01:58 PM
12/28/23 01:58 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
I have a carbon fiber helmet from Speedway, I am sure it is made by the same people that make G-force because that is what it looks like. It is nice and light weight and fits my big melon well. Has all the appropriate ratings.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3200536
12/28/23 07:02 PM
12/28/23 07:02 PM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
M rated helmets are rated and tested for your head hitting an object or hard surface. SA is tested and rated for having something hit you in the head. Fire rating is also included in SA as well as eye port size.
The SA standard was designed for competitive auto racing while the M standard was for motorcycling and other motorsports. The K standard was released to accommodate helmets used in karting. There are three major differences between them:
The SA standard requires flammability test while the M and K standards do not. The SA and K standards allow for a narrower visual field than the M standard (Some SA and K certified helmets may not be street legal). The SA and K standards include a rollbar multi-impact test while the M standard does not.
[Re: Hemi_Joel]
#3200842
12/30/23 04:41 AM
12/30/23 04:41 AM
Posts: 43,744 Bend,OR USA
Cab_Burge
[Re: Hemi_Joel]
#3200857
12/30/23 08:39 AM
12/30/23 08:39 AM
Posts: 23,295 Here
jcc
Here
How does a vented helmet prevent fire from entering the vents? That is a scary thought. One method might be the use of a low melt temp air supply hose to self disconnect to assist with vehicle exit and also terminate any path for hot pressurized air being forced inside the helmet. Additionally, a crash sensor electrical cutoff switch on the helmet air supply fan might be another precaution.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: jcc]
#3200932
12/30/23 02:57 PM
12/30/23 02:57 PM
Posts: 21,510 A collage of whims
topside
A collage of whims
This got me to thinking about a new helmet, and Speedway is having a sale of sorts. The inner liners - often Nomex, or what's called a Nomex blend - are fire-retardant, but yeah, helmet vents supply oxygen... So, hard to quantify, but that's what head socks are supposed to do. But those have their limits too, as anyone who knows who Niki Lauda was can tell.
Anyway, I see Speedway's selling Zamp helmets - never heard of them, but the company has a Meridian, ID address...a couple miles from my new place. Supposedly a Euro-centric helmet maker, owned by Bell.
[Re: topside]
#3200984
12/30/23 06:43 PM
12/30/23 06:43 PM
Posts: 23,295 Here
jcc
Here
A few decades back at a Miami Beach hotel Niki sat down for breakfast at the adjacent table. It was rather sobering. I have incredible respect the man/driver. My concern with supplied air helmets is not so much fire, as it is breathing superheated air into the lungs, which a head sock cannot prevent.
[Re: jcc]
#3200985
12/30/23 06:46 PM
12/30/23 06:46 PM
Posts: 7,526 Minnesota
Hemi_Joel
Minnesota
Some say they have liners of nomex and some have liners of EPS. What is EPS? The EPS that I know of is expanded polystyrene foam. But that couldn't be a liner, the liner is cloth right?
I was looking at the impact 1320 on their website. You can pay extra to get your helmet with NextGen mounts on it. But I couldn't figure out if you don't buy them next-gen mounts, if the threaded inserts are already in there. I suppose I'll have to call them.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3200986
12/30/23 06:49 PM
12/30/23 06:49 PM
Posts: 23,295 Here
jcc
Here
By all means call them, but I believe most upper end helmets have the area reinforced and the screw inserts already installed, which makes a lot of sense rather than run the risk of the buyer yanking out the liner/padding and drilling holes. The EPS is basically Styrofoam, covered by fabric (nomex?). The padding is best if it does not rebound, causing more brain injury, and helmets in hard hits are one time use.
[Re: jcc]
#3201020
12/30/23 10:18 PM
12/30/23 10:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
By all means call them, but I believe most upper end helmets have the area reinforced and the screw inserts already installed, which makes a lot of sense rather than run the risk of the buyer yanking out the liner/padding and drilling holes. The EPS is basically Styrofoam, covered by fabric (nomex?). The padding is best if it does not rebound, causing more brain injury, and helmets in hard hits are one time use. If you wreck a car at an NHRA race, two things happen immediately. They pull the cert sticker off the chassis and they pull the Snell sticker out of the helmet.
[Re: CMcAllister]
#3201033
12/30/23 11:33 PM
12/30/23 11:33 PM
Posts: 23,295 Here
jcc
Here
Does the driver first get to take his helmet off? I did not know that. edit: In further reflection taking off the chassis cert I can understand, but delabeling my helmet starts to be an issue, unless that is agreed to in some small print somewhere in advance. Not being able to prove a helmet was Snell approved post crash post Snell tag removal. seems to be problematic for me,
