Re: Info on this 64 Plymouth??
[Re: ro23car]
#319859
05/18/09 12:00 AM
05/18/09 12:00 AM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
yea actually he did put 770's on it, all done up by BIGS. Firsy time this weekend
After talking to him some more, he is only shifting that car at 6200 goin through at 6500. He says it has 8.40's in it real easy, but if any of you know tank he doesnt run his stuff very hard. ![](/ubbthreads/images/graemlins/laugh2.gif)
On other note he has a buy into the semi's today
wellok i knowhe had 950 hp's from bigs with vacum secondaries
Not only is he fast but also good with a buy going into the semis...sounds like a low reaction time in the prior round? Impressive.
[Re: moparmattkos]
#319860
05/18/09 12:03 AM
05/18/09 12:03 AM
proshiftcharger
Pennsylvania
That is Tank Crosswhite I have his number if you want to pm me ill send it to you. He is a great guy. The motor that is in my car now the shortblock i bought from him.
Matt, If you dont mind when you send Bob Tanks contact info could you PM me the info as well ?? thanks!!
[Re: proshiftcharger]
#319861
05/21/09 10:17 PM
05/21/09 10:17 PM
proshiftcharger
Pennsylvania
Matt, got your pm, thanks..greatly appreciated.
I spoke with Tank yesterday for a while on the phone. He didnt mind that I share this info for those of you that had questions regarding his 64 Plymouth. Well...I found out why he's running 8.66's and not the 9.20/9.80 range. Heres the scoop: 605 FHO HEMI, Millenium heads, 15;1, Hogan tunnel ram, (2) 1050 Bigs, car weighs 3300 lbs, ATI 4800 stall speed, straight cut 1st & 2nd, alum drums, shifts at 6800. Cam...he said he didnt know. His car sits somewhat lower than what you would expect a Super Stock B-body to sit. The doors and hood are fiberglass. 4 link, F/C cage. His best is 8.66 @ 158mph. He said its capable of 8.50's. He broke his car in the semis at CC. He was on a big wheels up run shifted into second while front was in the air and broke the front input shaft.
He's currently building a stock eliminator b-body. This means the 64 Super Stocker Outlaw in question is up for sale. Tank gave me permission to post his number should anyone be interested. Its available turn key or will separate. He asked that I not disclose any $ figures.
Tank Crosswhite 276-944-5761 or 276-492-3247
Hope this helps ! Doug
