Re: Lowering an '85 pickup......
[Re: TooMany62s]
#3200171
12/26/23 10:15 PM
12/26/23 10:15 PM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
I used dropped lower control arms and flipped the springs on the rear to lower my '84. Sharp looking truck ... and the wheels are NOT FUGLY
Mainstream Media is the new Pravda
[Re: JohnRR]
#3200269
12/27/23 02:22 PM
12/27/23 02:22 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I had a lowered 91 back in 2003/2005 era. It was not done correctly and I was always looking for new posts by Cheeto to update up on the best ways to lower the trucks, before they had any aftermarket support.
Cheeto had a killer truck with little alien heads or something similar incorporated into the flamed pinstripes.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: JDMopar]
#3203841
01/11/24 04:13 PM
01/11/24 04:13 PM
Posts: 8,884 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
That's the best way to lower a Dodge truck of that era. I like short beds lowered, but not long beds. If I were to do one for myself, I would use a C or E body 8 3/4 on top of the springs as it's a bolt in and I have several, and I would change the front rotors to 4 1/2 in bolt pattern so I could use Year One 17" Rallye Wheels. a ebody rear is not a bolt in
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#3204036
01/12/24 11:58 AM
01/12/24 11:58 AM
Posts: 8,567 Candler,NC / Myrtle Beach, SC
JDMopar
That's the best way to lower a Dodge truck of that era. I like short beds lowered, but not long beds. If I were to do one for myself, I would use a C or E body 8 3/4 on top of the springs as it's a bolt in and I have several, and I would change the front rotors to 4 1/2 in bolt pattern so I could use Year One 17" Rallye Wheels. a ebody rear is not a bolt in Well..... with a Wal Mart socket set, no it ain't! I shouldn't have assumed that the vast majority of folks that would attempt it would know that you need to move the spring perches in to the proper width after you take the center pin out of the leaf springs and flip it over to be on the top of the springs instead of the bottom. There's a lot of wiggle room in the rear wheel well area of the D series trucks and C or E body 8 3/4's fit great.
[Re: volaredon]
#3205746
01/17/24 08:08 PM
01/17/24 08:08 PM
Posts: 15,487 Florida
scratchnfotraction
well..on my 88-440/727/8 3/4 d-100 swb truck I used a rear shackle flip... then flopped axle on top of springs... tubed the bed...bolted in a A-body 8 3/4...added a set of 15x12 - 4.5 BS rims & M/T 29x15x15 SR radials...then used a 11" stock front coil spring with a 235/75/15 on a 7" rim 4.5 BS so the swaybar clears a parking stop by a 1/4"
IMHO this gives the best handling, stance, traction for a street truck.
looks same as tomany62 but yellow/black paint.
still scratchinfotraction with it since 2010
hey TM62 hit me up I have a few old wire harness for trucks.
FYI..A body 8 3/4 bolts in on the truck 43" centers & tucks a 12" rim with 29x15x15 M/T bed tubbed flush o frame rails 1.5 stock tubs my 85 step side runs a 67 C-body 8 3/4 relocated perches tucks a 10x15 4.5bs rim 275/60/15 tire real nice...mine is tubbed but do think it fits without tub work. mid 90 jeep/mopar 8 1/4 axle have 43" perch centers and are real close to A-body measurements & add gear choices. I just scored a jeep 8 1/4 with 3.73 gears and one with a 4.10 gear
[Re: scratchnfotraction]
#3205747
01/17/24 08:13 PM
01/17/24 08:13 PM
Posts: 16,096 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It's about time you returned!!!!
Facts are stubborn things.
[Re: hp383]
#3216522
02/27/24 03:58 AM
02/27/24 03:58 AM
Posts: 1,982 ID/MT
Cheeto
ID/MT
Cheeto had a killer truck with little alien heads or something similar incorporated into the flamed pinstripes. Thank you. I still have it. In fact I actually visited it in it's "storage hell" a couple weeks ago. The flames and skulls are airbrushed though not pinstripes.
Cheeto It's not perfect. It's not correct. It's not yours!
