Page 5 of 6 1 2 3 4 5 6
Re: For Sale - Big Block Engine [Re: moparts] #3182393
10/09/23 09:57 AM
10/09/23 09:57 AM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
water pump housing from a motorhome
high flow casting 3751216
$50 plus ship
PM for info
water pump.jpg (1931 downloads)
Remember when cars were FUN?
Re: For Sale - 1972 440 HP Block [Re: moparts] #3182880
10/10/23 06:54 PM
10/10/23 06:54 PM
St. Louis, Missouri
69F8C500 Offline
69F8C500  Offline
St. Louis, Missouri
For Sale: 1972 440 HP block. What you see is what you get. It’s got a casting date of 1-6-72. Originally out of a C body built at Jefferson plant (C). $500 OBO located in Millstadt, IL (just outside St. Louis) please email if you are interested: sethdegenhardt@gmail.com
Re: For Sale - 1972 440 HP Block [Re: 69F8C500] #3183312
10/12/23 10:05 AM
10/12/23 10:05 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
MOPAR BIG BLOCK DUAL POINT TUNE UP KIT&EXTRAS
FITS 1966-1967-1968-EARLY 1969 361-383-413-426W-440 DODGE&PLYMOUTH CAST IRON DUAL POINT DISTRIBUTORS
INCLUDES 3 BLACK DUAL POINT DISTRIBUTOR CAPS, 1 copper insert
2 NORS DUAL POINT ROTOR'S
2 NORS STRAP TYPE CONDENSER'S
3 NORS SET OF DUAL POINTS
A NORS USA MADE DUAL POINT NIEHOFF VACUUM ADVANCE#9.5 ON ARM
1 ECHLIN OIL PRESSURE SENDER FOR A GAUGE
NOS 2889472 AAUJ NEUTRAL SAFETY SWITCH(FITS 66 THRU EALRY 69 727S
VALLEY FORGE NORS INSTRUMENT CLUSTER VOLTAGE REGULATOR REPLACES 2258413 MOPAR
$200 mailed/boxed and ready to mail priority mail
cowgerwilliam035@gmail.com
4406PACKDP 001.JPG (1691 downloads)
4406PACKDP 026.JPG (1689 downloads)
4406PACKDP 019.JPG (1686 downloads)
4406PACKDP 012.JPG (1688 downloads)
Re: For Sale - Big Block Engine [Re: moparts] #3183931
10/14/23 02:08 PM
10/14/23 02:08 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
RB connecting rods, used -$10 ea
RB cast crank used - $150
RB Steel crank used - $250
Cylinder heads 906 and 452 - used - $75ea
Box of BB stuff
  • Rocker assys
  • Water pump housings
  • Power steering pump
  • oil pump drive
  • Timing covers
  • motor mounts
$200
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
383-400 aluminum intake manifold. [Re: Joesixpack] #3184191
10/15/23 03:52 PM
10/15/23 03:52 PM
San Jose,CA
migsBIG Offline
migsBIG  Offline
San Jose,CA
Weiand plane B engine aluminum intake manifold in good condition. $150 plus shipping. paypal friends and family.
Re: For Sale - Big Block Engine [Re: moparts] #3186933
10/27/23 08:38 PM
10/27/23 08:38 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
New set of 8 Mopar Performance Wedge 4.500 bore pistons, pins and clips. Part # P4876023. Mopar claims 10.5 compression. Uses std 6.760 rod. $750.00 plus shipping from 34957. PM me if interested.
Re: For Sale - Big Block Engine [Re: moparts] #3187735
10/30/23 08:32 PM
10/30/23 08:32 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1 Pr. vintage Cal Custom big block 6 bolt valve covers, excellent condition $250.00 for the pair (708) 288-2879
parts 10-30-2023 022.JPG (903 downloads)
parts 10-30-2023 023.JPG (899 downloads)
parts 10-30-2023 024.JPG (902 downloads)
parts 10-30-2023 025.JPG (900 downloads)
1968 D 440 HP 2 Short Block 2536430 VIN [Re: moparts] #3187763
10/30/23 10:46 PM
10/30/23 10:46 PM
GA
68gtxdave Offline
68gtxdave  Offline
GA
1968 D 440 HP 2 Short Block 2536430 VIN 8G1174120
Forged crank 1968 440 HP block. This has been stored in my nice dry garage for the last 19 years. The cam and crankshaft are still in it. The rocker arms and shafts, lifters are still there too. I bought it and several other parts 19 years ago from Mike Vath in Marietta, GA who intended to build it and put it in a C-body. It's in the exact same condition as when I bought back then. I also have done nothing with it, which is sad, but I got into other hobbies and my '68 GTX and 2009 Viper are enough at this point in my life. This could be an absolute Mopar beast in the right hands!
Here are the numbers:
Casting 2536430-10 (440 mold #10)
Date cast 3.14.67 (March 14, 1967)
D 440 HP 2 (1968 440 HP motor)
7 19 = Assembled July 19, 1968
A = 0.020" oversize cylinder bores
B = ?
Car VIN 8G117410 (1968 St. Louis assembly plant)
In 1968 Chrysler built Chargers, Coronets, and Belvedere platforms in St. Louis so this motor came out of either a Charger R/T, Coronet R/T, or GTX. It would be correct for any Mopar built in the 2nd half(?) of 1968. Ready for restoration and build! If you need the engine stand then it's included! Bring your pick-up, I also have an engine hoist to load it. This is too heavy and awkward for one person. I have lots of additional photos, just ask. Located north of Atl GA. $1250
IMG_E4035 cu.JPG (880 downloads)
"Manny, get the yea yo."
Pair 1967 2780915 HP Closed Chamber Heads [Re: moparts] #3187764
10/30/23 10:53 PM
10/30/23 10:53 PM
GA
68gtxdave Offline
68gtxdave  Offline
GA
These have been stored in my nice dry basement for the last 15 years. They were rebuilt by the previous owner and are in very nice condition and include the valves and springs. They're in the exact same condition as I bought them back then as I had good intentions but have done nothing with them, which is sad, but I got into other hobbies and my '68 GTX and 2009 Viper are enough at this point in my life. One is date coded 01107 (Jan. 10, 1967) and the other three days later 01137 (Jan. 13, 1967) so these originally came off of the same motor which is a rarity. They would be correct for virtually any Mopar built in 1967. And, yes, they've been painted Mopar engine orange so were intended by the previous owner for a 69-70 build. I have lots more photos. Located north of Atl, GA, pickup only. $1500
Pair 1968-69 383/440 HP 2843906 Heads [Re: moparts] #3187767
10/30/23 11:04 PM
10/30/23 11:04 PM
GA
68gtxdave Offline
68gtxdave  Offline
GA
These have been stored in my nice dry garage for the last 16 years. Even though they are in very nice condition and include the valves and springs, they should be gone through especially if you're doing a restoration or engine build. Both are date coded 12028 (Dec. 2, 1968) which is not seen very often. So they came off of the same motor. They would be correct for any Mopar built in 1969 or very, very late 1968. I have many more photos. Located north of Atl GA for pickup. $259
Re: Pair 1968-69 383/440 HP 2843906 Heads [Re: 68gtxdave] #3187877
10/31/23 02:53 PM
10/31/23 02:53 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1 set of original 1969 A12, 440 SIX PACK 4-speed carbs, front carb list #4393 with a date code of 0929, center carb list #4391 and a date code of 0729, rear carb list #4394 with a date code of 0929 selling as is, selling as cores to restore $2500.00 for the set (708) 288-2879
parts 10-31-2023 008.JPG (1164 downloads)
parts 10-31-2023 010.JPG (1166 downloads)
parts 10-31-2023 009.JPG (1164 downloads)
parts 10-31-2023 2 009.JPG (1166 downloads)
Re: For Sale - Big Block Engine [Re: moparts] #3187942
10/31/23 09:07 PM
10/31/23 09:07 PM
Out of the State of Confusion
blue_stocker Online content
blue_stocker  Online Content
New, in-the-box Edelbrock Performer intake manifold for low deck B-engine (361-383-400), still in the bag with gaskets and 12 pt bolts, plus the paperwork, $300 plus shipping from the Savannah, Tn area. PM me here if interested, thanks for viewing my ad...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Stromberg 2BBL Carburetor 1965-1967 361 & 383 [Re: blue_stocker] #3188495
11/03/23 01:26 PM
11/03/23 01:26 PM
Northern CA
streetkit Offline
streetkit  Offline
Northern CA
Stromberg 2BBL Carburetor. 3-363, 1965-1967 361 & 383 2BBL engines. Has been sitting on a shelf for a while so it will need to be rebuilt.
$40 shipping anywhere in the USA included in the price.
Stromberg 1.jpg (1009 downloads)
Stromberg 2.jpg (1007 downloads)
1973 Dodge D100
Re: BB timing cover, new [Re: moparts] #3188524
11/03/23 03:27 PM
11/03/23 03:27 PM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a new, never used BB timing cover. This cover was originally a chrome piece but it sat in a shed for a long time and the cheap Chinese chrome rusted. We cleaned it very well and put a coat a primer on it so it can now be painted any color. There are no marks at all where the attaching bolts go so it’s clear that it’s never been used. I would like to get $20.00 for it plus the shipping.
Edison, NJ
rider1454 at aol.com
Re: 58-78 BB NON-AC water pump pulley [Re: PHYSIXX] #3188525
11/03/23 03:30 PM
11/03/23 03:30 PM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a used 58-78 BB NON-AC water pump pulley that’s in excellent shape, has been cleaned and painted. It measures 5 ¾” in overall diameter and 2 ¾” deep. I would like to get $24.00 for it plus the shipping.
Edison, NJ
Complete OEM 440-6 Six Pack Setup, intake, carbs, ba [Re: moparts] #3189739
11/08/23 11:17 PM
11/08/23 11:17 PM
GA
68gtxdave Offline
68gtxdave  Offline
GA
**SOLD**SOLD** This has been stored in my nice dry garage for nearly 15 years. Carbs rebuilt by previous owner. It's in the exact same condition as I bought it back then as I have done nothing with it, which is sad, but I got into other hobbies and my '68 GTX and 2009 Viper are enough at this point in my life. I have many more photos. Located north of Atl, GA, pickup only. $4995. **SOLD**SOLD**
- Chrysler 2946276 1970-1972 Cast iron intake dated 10/27/69
- OEM 1970 Holley 3462373 Both outboard carbs 4365-1 (0126)
- OEM 1970 Holley 3418550 Center carb 4144-1 (2945)
- Base plate no markings I can find, some scratches and needs to be cleaned
- Fram CA332V Air filter
- Lid no markings I can find, small minor ding on lip (I can provide a photo)
Six pack 1.jpg (771 downloads)
Re: For Sale - Big Block Engine [Re: moparts] #3190471
11/12/23 03:07 PM
11/12/23 03:07 PM
ct.
moparlouie Offline
moparlouie  Offline
ct.
Very nice passenger side exhaust Dated 7-18-69 383/440 Part# 2899879. Has Heat riser shaft and spring that spins freely but has no internal butterfly. Near mint shape. $300 plus shipping. lafrancebiglou@aol.com
Have been a member for years!
NOS 1968-69 340 383 440 Magnum Unsilenced Air Cleaner Wrinkl [Re: moparts] #3190549
11/12/23 10:28 PM
11/12/23 10:28 PM
GA
68gtxdave Offline
68gtxdave  Offline
GA
**SOLD**SOLD** NOS 68-69 OEM unsilenced black wrinkle finish air cleaner. This is new from Mopar Performance - never used, never put on a motor. I think I bought this at the 2000 Mopar Nationals in Columbus, OH 23 years ago and it's been stored in my nice dry basement since then. Show car / high dollar restoration worthy. $545 + shipping. **SOLD**SOLD**
2806301 383 4 BBL Intake [Re: 68gtxdave] #3190587
11/13/23 09:51 AM
11/13/23 09:51 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Original 383 intake for a 1968-1969 engine. Will also fit 400 engines. Asking $100 + shipping or can be picked up in Keymar, MD.
FS hemi,440,KB,Mopar,edelbrocks,comp rollers [Re: moparts] #3192234
11/20/23 03:30 PM
11/20/23 03:30 PM
ca,usa,garden grove
cameron Offline
cameron  Offline
ca,usa,garden grove
hope im doing this correctly?? , but here goes, moderator can move it if Im doing this wrong??
mopar Keith black water block machined for a wedge..needs final machining and sleeves, it has hemi main caps and cross bolting, was pulled off the assembly line of keith black back in the day before they closed down, this block takes dry sleeves and was made under mopars consent and sold through mopar connection dealers. The block needs a small TIG weld on one of the bores 1/2 way up about an 1" long then sleeves can be installed...$2500
One set of edelbrock 440alloy rpm heads with comp cams roller rockers, have very low time,removed from a customers car from a hot rod shop that closed down during covid $2100
Oem set of oem iron 426 hemi heads, not ported and recently magnafluxed, no orings or cracks or welds......contact for pics...$1500 obo
1970 rebuilt 440 engine with 915 closed chambered heads, was rebuilt by orange engine in 1990, then its been sitting inside dry garage covered, super clean but I'd pull apart and reclean and reseal....long block...$4000 obo
Im in so cal, i had to buy a collection of stuff to get the hemi parts out of the batch...text me for more pics and details, name is cameron,
cell # seven one 4, eight eight 3,six one seven one
is my cell,coded to hide from scammers..
