aeromotive pro fuel pump
[Re: moparts]
#3189950
11/09/23 08:37 PM
11/09/23 08:37 PM
Posts: 1,574 westerly, ri. usa
440lebaron
westerly, ri. usa
model 11102 12an fittings, up to 2000 hp, new never had fuel in it, summit $1009.95 $450 shipped lower 48 prefer check/money order pay/pal friends/family pm, call 401-787-1180, email garycastagna@gmail
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
leaf spring clamps
[Re: moparts]
#3189953
11/09/23 08:42 PM
11/09/23 08:42 PM
440lebaron
westerly, ri. usa
(4) spring clamps new $40.00 shipped lower 48 prefer check/money order pay/pal friends/family pm, call 401-787-1180, email garycastagna@gmail
cloyes chain b/b
[Re: moparts]
#3189954
11/09/23 08:49 PM
11/09/23 08:49 PM
440lebaron
westerly, ri. usa
sold
Re: For Sale - Race Parts
[Re: moparts]
#3190135
11/10/23 07:34 PM
11/10/23 07:34 PM
Posts: 256 Toledo,Ohio
360DOUG
Toledo,Ohio
Used MSD 2-Step Part#8739. Works only with analog system. Asking $45.00 plus shipping. Located in Ohio 43612. PM if interested
[Re: moparts]
#3190142
11/10/23 08:02 PM
11/10/23 08:02 PM
360DOUG
Toledo,Ohio
Used AutoMeter Sport-Comp Monster Tachometer, Part #3903, 0-10,000 RPM, 5 inch, Analog with shift light. Asking $125.00 plus shipping. Located in Ohio 43612. PM if interested
[Re: 360DOUG]
#3190324
11/11/23 07:35 PM
11/11/23 07:35 PM
KOS
572 all aluminum Eddy Maxwedge Victor headed 740HP@6k 760ft lbs @ 4600rpm New with only 250 easy street miles.Info in pix pm for more if interested.Carb(gen3 1150)to pan 25k
[Re: dan345]
#3191173
11/15/23 03:59 PM
11/15/23 03:59 PM
Posts: 11,884 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
NEW JR #4216 EXHAUST HEADERS, 1967-1974 b&e BODY 340-360 STOCK&SUPER STOCK 1 7/8S, MULTI PIECE,32-38 INCH TUBE LENGTH, ALL TUBES EXACT LENGTH,WITH 3 INCH COLLECTORS, AND EXTENSIONS(TUNEABLE), WILLL FIT MOPAR DODGE PLYMOUTH 340-360 WITH STANDARD HEADS(NOT W2), BOUGHT FOR B&E BODY, Exterior Ceramic Coating
A silver matte finish applied to the steel surface to protect against rust, corrosion and withstands temperatures up to 1200°F. Exceeding this temperature will result in discoloration of the header tubes.
.$500 cowgerwilliam035@gmail.com
[Re: rickseeman]
#3192041
11/19/23 02:20 PM
11/19/23 02:20 PM
Posts: 2,510 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
10 titanium valves 2.25" head 5.30" long 11/32 stem 99.4 grams .250" tip P4120064 $60 each. You can take only 8 if you want. Rick 501-519-7425
2011 Drag Pak Challenger
oil pump shaft,pins etc
[Re: moparts]
#3192095
11/19/23 06:57 PM
11/19/23 06:57 PM
440lebaron
westerly, ri. usa
magnum performance throttle body SOLD
b/block oil pump shaft SOLD charging lugs kickdown levers 4.2-3.8-3.2 (all 3) sale pending!! aluminum hood pins champion SOLD each items $25.00 shipped lower 48
pm, email garycastagna@gmail.com, call 401-787-1180 prefer check/moneyorder paypal friends/family O/K
RB main Bearing set
[Re: dsd70bee]
#3193494
11/26/23 08:20 PM
11/26/23 08:20 PM
Posts: 1,787 North Dakota
Azzkikrcuda
North Dakota
Mopar Big-Block RB main bearing sets. Both sets were installed bearing clearances checked and removed. PM me here if interested. -Clevite MS-1795 V - Standard bearing size, $75 shipped King MB5116HP 001 - .001 undersize Standard bearing size $75 Shipped
The only Carbs I care about are under the hood!
