lil red Express Aircleaner
[Re: Powerflow]
#3174023
09/09/23 01:01 PM
09/09/23 01:01 PM
Posts: 2,573 Fargo ND
moparphilll
Fargo ND
Lil Red Express AirCleaner $850 moparphillll@aol.com
Re:1979-1980-1981 S6 MAJOR TUNE UP KIT,PLUGS,TSU,OPS,WIRES,C
[Re: Joesixpack]
#3174620
09/12/23 10:31 AM
09/12/23 10:31 AM
Posts: 11,884 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
NORS USA MADE MAJOR TUNE UP KIT PLUS WILL FIT; 1979-1980-1981 DODGE TRUCKS, 225 SLANT SIX 2&4 WD D,W 100,150,200,250 INCLUDES;
ACCEL BRASS HD DISTRIBUTOR CAP KEM ROTOR NOS MOPAR PCV VALVE NIEHOFF HD IGNITION WIRE SET 6 CHAMPION GOLD SPARK PLUGS P&D VACUUM ADVANCE 1 TEMPERATURE SENDING UNIT 1 OIL PRESSURE SWITCH(FOR A LIGHT) MAGNETIC PICKUP RELUCTOR WHEEL(LOCATING PIN WAS NOT IN THE BOX WHEN I GOT IT) NIEHOFF IGNITION COIL NIEHOFF BALLAST RESISTOR NIEHOFF STARTER RELAY NIEHOFF VOLTAGE REGULATOR HEADLIGHT SWITCH HORN RELAY ALL USA MADE PARTS$100
cowgerwilliam035@gmail.com
Re:1950-1954 , 6, DODGE TRUCKS TUNE UP ,CAP,ROTO
[Re: Joesixpack]
#3174622
09/12/23 10:40 AM
09/12/23 10:40 AM
Joesixpack
APACHE JUNCTION AZ
NORS DELCO REMY, NIEHOFF,FILKO,AUTOLITE, KEM,MAJOR TUNE UP KIT, WILL FIT; 6 VOLT 1950(WITH THE AUTO-LITE DIST# IAT)-1951-1952-1953-1954-1955 DODGE FLATHEAD 6 TRUCKS
WONT FIT AUTO-LITE DIST#IAP NOR IGS
INCLUDES; A NORS FILKO COPPER INSERT HD DISTRIBUTOR CAP A NORS KEM IGNITION ROTOR A NOS DELCO REMY SET OF CONTACT POINTS A NOS DELCO REMY IGNITION CONDENSER A NORS SET OF KEM ES57 generator brushs&BUSHING A SET OF DELCO REMY D-751 STARTER BRUSHS AND THE BUSHING'S 6 NOS 295 AUTOLITE SPARK PLUGS A NORS NIEHOFF VACUUM ADVANCE 3 DISTRIBUTOR LEADS (YOU MAY USE 1,2,OR 3 DEPENDING ON THE YEAR&MODEL)
MADE IN THE USA NOS/NORS PARTS $70
Re:1966-1967-1968-1969 dodge trucks bb tune up kit
[Re: Joesixpack]
#3174624
09/12/23 10:45 AM
09/12/23 10:45 AM
Joesixpack
APACHE JUNCTION AZ
DODGE TRUCKS 1966-1967-1968-1969 SINGLE POINT TUNE UP KIT 383-440 FILKO TAN,BRASS INSERT MADE IN THE USA DISTRIBUTOR CAP USA MADE ROTOR,POINTS,CONDENSER, DISTRIBUTOR LEAD(WITH BLUE GROMMET) 90 DEGREE METAL PCV VALVE MADE IN USA ECHLIN OIL PRESSURE SENDER(FOR A GAUGE) 8 A52 AUTOLITE POWER TIP SPARK PLUGS
FOR AN ALUMINUM SINGLE POINT DISTRIBUTOR AND ANY 383-440 BIG BLOCK ENGINE$85 cowgerwilliam035@gmail.com
Re: For Sale - Truck / Van / Jeep Parts
[Re: moparts]
#3183929
10/14/23 02:04 PM
10/14/23 02:04 PM
Posts: 2,048 Byron, NY
W.I.N. Racing
Byron, NY
1984 D150 9.25" Rear axle assembly, 3.21 ratio, Limited slip. complete drum to drum. $400 BB Mopar Truck Pan and motor mounts - $75
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: For Sale - big block radiator
[Re: mopars4ever]
#3187925
10/31/23 07:24 PM
10/31/23 07:24 PM
birdtracker
factory 77-78 big block truck radiator. Very nice condition.$200 Located north of Dayton Ohio. PM if interested. Birdtracker
5.2/5.9 TBI
[Re: moparts]
#3192081
11/19/23 06:19 PM
11/19/23 06:19 PM
Posts: 1,574 westerly, ri. usa
440lebaron
westerly, ri. usa
magnum performance throttle body SOLD
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
