Re: Cam bearing bore shot in BB, how to fix? [Re: fast68plymouth] #3191653
11/17/23 06:09 PM
11/17/23 06:09 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I don't think you want roller bearings, you have enough troubles already. Look at the bright side. After you go thru all this trouble to go to 54mm babbit (or what ever the first popular size is) at least you can tell everyone you have a 54mm cam. That has to be worth something.
2011 Drag Pak Challenger
Re: Cam bearing bore shot in BB, how to fix? [Re: rickseeman] #3191716
11/18/23 05:39 AM
11/18/23 05:39 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Ok,have zero experience with the roller bearing cams. I believe the sleeving sounds like the wisest option, could use regular cam cores. This is a drag & drive style car after all, it might make life a lot easier in the future.
Plynouth VIP '67 TT IC EFI
Re: Cam bearing bore shot in BB, how to fix? [Re: jyrki] #3191736
11/18/23 10:13 AM
11/18/23 10:13 AM
Stuttgart, Arkansas
Stuttgart, Arkansas
Sleeving is pretty simple. You would only sleeve the damaged ones. I would use aluminum sleeves so it wouldn't loosen from dissimilar metal expansion rates. This has already been done thousands of times in bearing housings etc. Your man will bore them out to size, then make 2 sleeves which are a little small on the id, then drill the oil hole, then press them in and then bore to the proper size. It won't take him long.
Re: Cam bearing bore shot in BB, how to fix? [Re: rickseeman] #3191738
11/18/23 10:40 AM
11/18/23 10:40 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
From what I've found, the so-called 54mm bearings are really Ø2.125" BBF journal sizes. I spent a lot of time looking for 54mm roller bearings for my Hemi block and finally was told it was the BBF bearing size.
Floyd Lippencott IV
Re: Cam bearing bore shot in BB, how to fix? [Re: mr_340] #3192373
11/21/23 09:52 AM
11/21/23 09:52 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
A local machinist said he m0st likely can line bore the cam bearing holes big enough to make them straight and round, and then make custom oversize babbit bearings so that a regular cam can be used. I think I'll go that route.
Re: Cam bearing bore shot in BB, how to fix? [Re: rickseeman] #3192405
11/21/23 01:03 PM
11/21/23 01:03 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
What he said
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Cam bearing bore shot in BB, how to fix? [Re: jyrki] #3192483
11/21/23 06:11 PM
11/21/23 06:11 PM
up Glad you got it on its way bow up
The things we put ourself through for our hobbies and loves of cars work realcrazy whistling grin
Re: Cam bearing bore shot in BB, how to fix? [Re: Cab_Burge] #3192506
11/21/23 07:57 PM
11/21/23 07:57 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I have no help to offer but just wanted to mention your Fury is awesome and hope you make it overseas again for another drag and drive event!
