Installing Trans
#3186700
10/26/23 05:45 PM
10/26/23 05:45 PM
Posts: 398 Milan Ohio
ct440rod
Milan Ohio
Ready to install 727 trans in 70 440 challenger and was wondering that when I took it out had a hard time breaking loss top bolt on starter can you install starter before you put trans in ?
thanks
Re: Installing Trans
[Re: Cab_Burge]
#3186831
10/27/23 01:02 PM
10/27/23 01:02 PM
Posts: 26,522 Rio Linda, CA
John_Kunkel
Rio Linda, CA
the converter lugs should have at least 3/4 inch clearance to the bell housing flat edge that goes up against the block !/2 inch is plenty.
[Re: ct440rod]
#3187481
10/29/23 08:59 PM
10/29/23 08:59 PM
Posts: 43,741 Bend,OR USA
Cab_Burge
When installing trans cross member there was 2 bolts with nuts towards engine and 2 the other way. is that how they were installed from factory ? I don't think so, all the OEM stock cars I have removed the trans. from had all the bolts install the same way with the nuts install on the tranny side of trans cross members :shruggy I don't think you can install the two inner bolds from the front do too not having enough room for them to fit into the tranny cross member bolt holes Maybe they will
[Re: stumpy]
#3187691
10/30/23 05:24 PM
10/30/23 05:24 PM
ct440rod
Milan Ohio
Transmission cross member the 2 outside bolts face different direction
[Re: ct440rod]
#3187822
10/31/23 11:45 AM
10/31/23 11:45 AM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
Transmission cross member the 2 outside bolts face different direction That underside shot is far from factory stock, unless someone has a photo of the underside of the car as it rolled off the assembly line there is no knowing how it was originally built, though they SHOULD have all faced the same direction ...
Mainstream Media is the new Pravda
[Re: ct440rod]
#3187825
10/31/23 11:52 AM
10/31/23 11:52 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
I always use a stud for the top starter mounting hole. Makes it easier to stab the starter in and let hang in place on that stud.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: JohnRR]
#3187837
10/31/23 12:13 PM
10/31/23 12:13 PM
ct440rod
Milan Ohio
Transmission cross member the 2 outside bolts face different direction That underside shot is far from factory stock, unless someone has a photo of the underside of the car as it rolled off the assembly line there is no knowing how it was originally built, though they SHOULD have all faced the same direction ... Its not that far from stock as I owned cars since 74
[Re: ct440rod]
#3187842
10/31/23 12:34 PM
10/31/23 12:34 PM
JohnRR
A gulag near you.
Transmission cross member the 2 outside bolts face different direction That underside shot is far from factory stock, unless someone has a photo of the underside of the car as it rolled off the assembly line there is no knowing how it was originally built, though they SHOULD have all faced the same direction ... Its not that far from stock as I owned cars since 74 It's current state is incorrectly overestored, that is what I meant from far from stock. The last year I judged 68-70 B body factory stock at Englishtown I was scoring 0 points for an underside that looked like that ... sorry , pet peeve of mine. So you have had the car since 1974 , if the trans had never been out of it the in the few years you didn't own it, and that is how it has always been, then there is your answer. To answer your question on the starter bolt , I used a universal on a 6" extension to get a ratchect past the end of the original starters ... this was before the advent of .. to me ?... wobble drive extensions. I'd be a little weary of trying to put the trans on with the starter sticking that far forward of the trans.
