Re: Engine and Trans Lost & Found
[Re: daniel_depetro]
#3204
08/02/08 12:57 PM
08/02/08 12:57 PM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
Found:
1970 F 440 HP2 440 six pack engine.
Engine VIN pad # 0A166949
All original and never changed around. It looks very, very much like new on the inside. It is complete from air cleaner assembly to oil pan. Only items missing were the exhaust manifolds (probably ran headers) & it had M/T aluminum valve covers instead of the correct 1970 only HP units it was born with. Right after I got the engine home I re-installed the correct 1970 only HP valve covers and a set of HP exhaust manifolds back in place. I bought it 3 years ago in Pittston, PA which is half way between Wilkes-Barre & Scranton. The seller told me it was a 1969 six pack engine and came out of a Roadrunner that was his buddies car. They both raced it and it ran low 13's. It is obviously a 1970 engine, but I do not doubt the rest of his claims due to the missing manifolds & changed valve covers.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
#3205
08/02/08 03:10 PM
08/02/08 03:10 PM
daniel_depetro
FOUND:
1970 F 440 HP2 "six pack" block & main caps.
Engine VIN pad # 0G219932
I bought this block & caps in Racine, WI. The previous owner pulled it down and had it hot tanked and discovered a couple of casting lines that he thought were cracks. He decided to just get another block and kept all the original six pack stuff and sold the empty block to me. I bought it thinking it was cracked, but planned on just using it as a 'dummy' engine to have set-up on a stand. We finally made our way down there to pick it up and my father said it doesn't look cracked to him, more like an odd casting marks. My father kept saying it would be a shame to have that block just lay around if it was a good block and convinced me to at least have it checked out. I decided to get it fixed (if it could be) so I brought it to my welder so he could work his magic. He mag'd it and used his mirrors and magnifying glasses to check everything out and said it wasn't cracked at all, they were indeed just casting markes that were not that good looking. He said he could cover them if I wanted but said it would be a waste as just painting the block would make them disappear.
Looking for 70 440 Engine # OG177062
[Re: TripleTX9]
#3210
08/31/08 06:09 AM
08/31/08 06:09 AM
Posts: 606 Mass
charge70
Mass
Looking for the original engine or block for my 70 Charger R/T. VIN # is OG177062 I purchased the car from Ed Wilson in Lynchburg,VA.in 1982.I was told the car originally came from No.Carolina.Hope someone can help me out.Please PM me here or e-mail me at charge70@msn.com Thanks in advance,John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
Found
[Re: charge70]
#3211
09/04/08 05:12 PM
09/04/08 05:12 PM
Posts: 1,952 Olympia, Washington
tallzag
Olympia, Washington
Found - 1970 HP 440 - 0G226927
Found - Big Block 727 Tranny - 1968 - 8G137263
Probably originally from Missouri area.
Rocket Restorations
Re: looking for 440 and 727 for XS29U0G198796
[Re: 1965_PLYMOUTH]
#3215
09/09/08 07:47 PM
09/09/08 07:47 PM
Posts: 73 Qc, Canada
moparguy55
Qc, Canada
Hi all looking for the 440 block for my 70 charger along with 727. Car was sold originally in canada then spent quite some time in Mass. Where i heard the engine was taken out. XS29U0G-198796 Pm me or raoul55@yahoo.comThanks
[Re: Alaskan_TA]
#3217
09/26/08 12:05 AM
09/26/08 12:05 AM
Posts: 4 New Zealand
UCODE NZ
New Zealand
Looking for the Engine and Trans for my 70 440RT Challenger 0E142796. Thanks
[Re: ChrisD]
#3220
10/17/08 12:39 PM
10/17/08 12:39 PM
Posts: 4 kuUSAmo FINLAND
Haapakowalski
kuUSAmo FINLAND
WANTED: I looking for my -70 Challenger 340 engine VIN# 0B234993, i have matching # trans but not correct engine block. Car came from PA couple of months ago to here Finland. It has now 340 engine VIN# 9B319325. I also lookin for 440 engine and 727 transmission for my -69 300 Convertible. Vin# 9C203870. Car is from Michigan (St. Clair, 48079). rauno.haapakoski@gmail.com
