Pull Trans #3178167
09/25/23 05:02 PM
09/25/23 05:02 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
70 Challenger 440 727 Trans
Do I have to loosen motor mount to pull trans ?
Rod
Re: Pull Trans [Re: ct440rod] #3178211
09/25/23 06:56 PM
09/25/23 06:56 PM
Kirkland, Washington
Pacnorthcuda Offline
Normally no, but sometimes access to a certain bolt requires just a bit of movement….
Re: Pull Trans [Re: ct440rod] #3178333
09/26/23 11:00 AM
09/26/23 11:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do I have to lossen motor mount to pull trans ?
Rod
you're probably going to have to tip the motor to get at the top bolts and to clear the firewall so you will need to decide how much twist your motor mounts can handle.
Re: Pull Trans [Re: ct440rod] #3178341
09/26/23 11:31 AM
09/26/23 11:31 AM
No you don't HAVE to loosen them but it wouldn't hurt to have a little slack on them so I do remove the two lower long bolts through them, up don't forget to put them back in when buttoning up the work when your done wrench up
I do put a short piece of 2x4 soft wood in between the oil pan and the steering drag link and oil pan between the idler arm and the steering box arm to support the middle of the motor while the trans is out wrench up
Re: Pull Trans [Re: JohnRR] #3180555
10/03/23 11:10 AM
10/03/23 11:10 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
How much tranny fuild will come out when I pull drive shaft ?
thanks
Rod
Re: Pull Trans [Re: ct440rod] #3180563
10/03/23 11:44 AM
10/03/23 11:44 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A bunch. Best bet is drop the pan to drain the fluid where you can keep the mess small.
Re: Pull Trans [Re: stumpy] #3180567
10/03/23 11:56 AM
10/03/23 11:56 AM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
^^^ That, and pop a plastic/styrofoam cup or a tie-wrapped baggie over the output.
Re: Pull Trans [Re: ct440rod] #3180584
10/03/23 12:44 PM
10/03/23 12:44 PM
I would put a oil drain catch pan under the drain plug on the tail shaft housing and drain the tail shaft before pulling the trans up scope wrench twocents
Re: Pull Trans [Re: topside] #3181063
10/04/23 05:25 PM
10/04/23 05:25 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
About ready to drop trans but the long bolt going thru rubber transmission mount at back does not wamt to turn. Am I missing something ?
Re: Pull Trans [Re: ct440rod] #3181205
10/04/23 10:51 PM
10/04/23 10:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
More muscle.
Re: Pull Trans [Re: stumpy] #3181214
10/05/23 12:28 AM
10/05/23 12:28 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Like stated more grunt on bolt but use spray on threads. In a small block car when titling motor make sure you do not ruin the distibuter
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Pull Trans [Re: stumpy] #3181316
10/05/23 10:56 AM
10/05/23 10:56 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Looks like it might ruin bushing - - -
Re: Pull Trans [Re: ct440rod] #3181321
10/05/23 11:03 AM
10/05/23 11:03 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Pull the 2 bolts that attach the mount to the trans and drop the crossmember out.
Re: Pull Trans [Re: slantzilla] #3181456
10/05/23 05:03 PM
10/05/23 05:03 PM
iagree scope wrench
