Re: For Sale - Race Cars - 3rd Quarter
[Re: moparts]
#3160816
07/19/23 01:34 AM
07/19/23 01:34 AM
Posts: 3,516 pacific northwest
Stroker Scamp
pacific northwest
73 Plymouth Scamp stroked SB best ET 10.10 @ 132 message me for photos, 408,built 727, 8 3/4 caltracs etc etc $21.000 * price reduced*
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#3162452
07/23/23 05:06 PM
07/23/23 05:06 PM
Posts: 656 st.louis,mo.
dart games
st.louis,mo.
1970 dodge dart drag car.,all fiberglass except roof and quarters.removeable doors.removable front end.has parachute mount on rear and cable.comes with powerglide.with one transbrake cover and one foot brave coverati 5500 stall,hipster trans brake.recent last year nhra 850 cert.arm front end,4 link rear,ford 9 inch with strange aluminum carrier .486 richmond pro gear..40 spline mw axles,5/8 studs,coil overs at all 4 corners,disc brakes all 4 corners,aluminum drive shaft .hurst quarter stick,electric shift.delay box.msd 7al box,msd cil,aluminum radiator with fan,trans cooler,2 new batters,.holley pro max full pump.alston switch panel.all aluminum interior.sqare tube chassis.paint is ok from a distance.no vin,no title.bill of sale onlycar was built at chassis technolgy in ohio in 2000.which is no longer around.phoenix f/s 14.5x32-15 slicks.near rear weld wheels.runs,starts,moves.somethings wrong with the carb,price,20,000.00.,pm me here.WILL SELL AS ROLLER.5K,LESS ENGINE,TRANS,BATTERYS,FUEL PUMP,RADIATOR,TRANS COOLER.SHIFTER Engine Details: - 400 Cold Weather 230 Block (.030 overbore) - This is strongest Mopar production block, very hard to come by as they only made them in the summer of 1971. - Molnar Forged Crank and Rods - Ross Pistons (10.5 to 1 Compression for pump gas) - TRICK FLOW 270 HEADS!! (very hard to find right now) flow 353 cfm on the intake at .700 inch lift. - Comp Solid Roller Cam and lifters( see picture for specs) - Smith Push Rods - Harland Sharp Roller Rocker Arm (1.5 ratio) - Indy Max Wedge Port Intake (4500 flange) - ATI Harmonic Balancer - 1020 Holley Dominiator Carb Built by Dominic at Thumper Carbs (Dominic is know for building Dominator's that run well on the street and strip) - BLP Racing Fuel Log - MSD Billet Distributor - Taylor 9MM Fire Power Spark Plug Wires - All new or rebuilt front accessories ( has a single serpentine belt running all accessories including Power Steering Pump) - Electric Water Pump
[Re: moparts]
#3163539
07/26/23 10:20 PM
07/26/23 10:20 PM
Posts: 2,390 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
***sold*** thanks Moparts
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: moparts]
#3167464
08/12/23 12:48 PM
08/12/23 12:48 PM
Posts: 1,763 York,Pa
Slap Shot
York,Pa
listing for my friend call him do not message me
Real deal authentic 1970's Vintage Pro Stocker for sale. the original Ramchargers team Dodge Challenger only pro stock car they had acid dipped light weight body,built by Logghe then sold to Bill Flynn and named the Yankee Peddler. Needs cosmetic restoration and motor/trans. very easy restoration project still has the original and unique cage in it. located in Lothian,Md $130,000 obo may take a partial trade and cash call Marco at 240 375 4329
[Re: Slap Shot]
#3171944
08/31/23 07:52 PM
08/31/23 07:52 PM
McCandlessboy
Sold!!
1970 Stock Eliminator Challenger for sale. After running the car the first half of the year, we’ve decided it’s time to part ways with it. I made 38 runs with it and pulled the transmission out to swap to a new converter, It was at that moment that I noticed the crank had .045” of endplay. I went ahead and pulled the motor apart to freshen it but the crank had multiple cracks in it where it was welded up and it had one bad piston that was .014” undersized compared to the rest of them. I took the block to the machine shop anyway and he said we would have to bore it to 4.400 to get the cylinder walls to clean up. So what we thought was going to be a light hone, rings, and bearings to get us to the end of the year ended up turning into pretty much a whole new motor. With all that being said, we will be selling the car rolling and all the details are below. We have other race car projects that we’ll be lucky to have done by the end of the year, so we just don’t have the time to invest into this car. The car will come with the complete disassembled engine. Aluminum heads and intake with the 1/4 inch spacers to go between them, 6 pack carburetors, complete rotating assembly, etc. Fresh Pro-trans with 2 converters. We built the Dana this January with all Mark Williams parts, lightweight spool and 4.56 ratio. Calvert mono leafs, caltracs, and 9 way rear shocks. Double adjustable Afco shocks on the front. Weld alumistar front wheels, I think it has bogarts on the back but I could be wrong. Dawson headers with EGT bungs on every tube, no sensors included. Champion aluminum radiator. 2 XS 16volt batteries. MSD 7AL2. Racepak data logger. Berry Grant fuel pump and regulator. The car last ran at A/SA weight and can get about 10 lbs light with a 150lb driver. It will be sold with multiple weight bars and also has a weight box in the trunk. Aluminum Kirkey seats were installed this spring with Pro 1 seat belts, it will come with the stock seats which add about 50lbs. The complete 8 3/4 rear end that came out of it will be included with leaf springs, “Hal-lees” QA1 shocks, and wheelie bars. The hood took flight at zmax earlier in the year and now it does not fit very good or look good, it will probably need a new one. The fastest run I ever made with it was 10.237 at 3195lbs (A/SA is 3185) and it definitely had a little left in it.
Plymouth Valiant Street/Race
[Re: moparts]
#3172927
09/04/23 07:22 PM
09/04/23 07:22 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
I think many of you know of this car as its build was detailed extensively on this Forum. It was bought from Ron Silva the origional owner/builder of this incredible car. Featured in Popular Hot Rodding along with a few others. This car is BEAUTIFUL and was built with some very high end parts such as Mark Williams complete disc to disc 9” differential, ProTrans 904 transmission, Mark Williams Brakes and Spindles, Calvert Split monoleaf springs and Weld Alumastar Wheels front and rear. The Factory rear wheel tubs were widened all the way to the stock frame and the leaf springs were relocated on center of the frame and a cromoly roll bar was installed. It currently has a 380hp crate engine and runs mid 11’s and can drive anywhere. This car is turn key and absolutely beautiful. $45000 OBO. I have many more pictures as well.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
1974 Duster all steel street/strip
[Re: moparts]
#3178033
09/25/23 11:45 AM
09/25/23 11:45 AM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
For sale 1974 Plymouth Duster tubbed out pro street or drag car. The car is a 100% steel car, full glass, full dash and lights. It has spent most of its life on the strip and was built right. I have had the car for rougly 6 years and have not done much with it as we have just been too busy so I have decided to let someone else enjoy it. It is more of a street car than a stipped down race car and that is what I liked about it. The previous owner told me it ran routinely ran 10's and the car is built very nicely. The car is tubbed out with leaf spring suspension, dana 60 and a very very stout low deck stroker with a reverse manual valvebody 727. PM me for my # and I will call with more details. Car has clean Nebr title in my name. Car located in Norfolk, Nebr. $23,500 Can't build one with nice for close to that price. Thanks
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
