trick flow 240 cyl head question.
#3175906
09/17/23 08:05 PM
09/17/23 08:05 PM
Posts: 101 pa
gregcharger72
pa
What is the horsepower potential of this head on a .030 over 440? Given max effort cam and intake selection using Flat top pistons, roughly 11.5 to 1 compression.
Re: trick flow 240 cyl head question.
[Re: gregcharger72]
#3175926
09/17/23 09:04 PM
09/17/23 09:04 PM
Posts: 30,639 Oregon
AndyF
700+ hp with a drag race type solid roller cam. You'll need the matching parts of course. Ported intake, really good carb, correct valve train parts, correct size headers, good oil pan, etc.
Most street/strip guys pick parts that give them 600 hp with those heads and compression, but you can add another 100 hp if you know which parts to use.
[Re: AndyF]
#3175936
09/17/23 09:36 PM
09/17/23 09:36 PM
Posts: 42,462 Bend,OR USA
Cab_Burge
[Re: gregcharger72]
#3176043
09/18/23 12:16 PM
09/18/23 12:16 PM
Cab_Burge
What size carb are you running now?
[Re: Cab_Burge]
#3176059
09/18/23 01:08 PM
09/18/23 01:08 PM
Posts: 101 pa
gregcharger72
pa
What size carb are you running now? A 1000 cfm pro systems 4150
[Re: gregcharger72]
#3176077
09/18/23 02:41 PM
09/18/23 02:41 PM
AndyF
Thanks for the replies, I'm trying to decide on what would be the best approach to reducing my ET. I want to run a 10.50 index class and I am now consistently running 10.70's. Was considering a cylinder head swap from 240 to the 270 head but a cam change may get me there if 650 hp is doable with the 240 head. My current cam is a flat tappet 254 int and 260 exh @ .050. Looks like I would need about a 40 hp increase to get me there. Would need a little more information before I could provide specific advice. Car details, engine details, etc. If you're making 600 hp today then it should be possible to increase the engine to 700 hp with a well matched solid roller. You'll need a really good intake to hit 700 hp. Good intakes are hard to find for the standard port heads so you'll most likely need to have an intake ported which could cost $1000 just for the porting. You'll also need a set of good 2 inch headers and the oiling system needs to be correct for that much power. It is probably cheaper to swap over to a set of 270 heads since then you can buy a better intake. Sell the 240 heads and 4150 carb and intake and buy a set of 270 heads with the good roller springs. Then get a solid roller in the 260/270 range (talk to Dwayne), a good intake and a 1050 Dominator. If you get decent prices for your existing parts you won't be out a ton of money. Especially if you can buy the intake and carb used.
[Re: B1duster]
#3176174
09/18/23 08:23 PM
09/18/23 08:23 PM
Posts: 101 pa
gregcharger72
pa
How many runs on the short block ? What’s in it ? Have you thought about adding a stroker kit and using the top end you have ? So my thinking or wondering is, how much horsepower is left in the cylinder heads? What is the most cost effective way to get where I want to be? Perhaps I should have opened the thread with that question. The combination is a 3700 lbs. with me in it.72 charger. 4.30 gears . 30x9 slick .5200 flash stall converter, footbrake car. The engine is a .030 over 440 with flat top pistons, total seal gapless top rings. 11.7 to 1 compression..ootb 240 heads deep port match trick flow intake by Hughes engines. 1.6 rockers. a 1000 cfm pro systems calibrated carb. A Hughes engines flat tappet cam 254 int,260 exh @ .050 . 640 lift int 656 exh. My best et in very good weather is a10.57 @ 127mph. avg et is 10.73 @125. The engine has 110 runs on it. I'm a lot closer to 10.5 index than the 11.5 index. Can I get 40 hp with a cam change?
[Re: gregcharger72]
#3176211
09/18/23 10:32 PM
09/18/23 10:32 PM
AndyF
127 mph @ 3700 lbs puts you right around 600 hp which is what I'd expect from those parts.
If you have good headers and a good oiling system then an upgrade to a solid roller will pick up some power. Fully porting the intake will pick up power too but it is expensive. I used a fully ported M1 4500 on my pump gas 470 and we made over 700 hp but it was a very expensive intake. Probably cost $2000 to duplicate it these days since it was cut open and then welded back together. There are more choices for an RB intake. Maybe the std port version of the Super Victor for example. Sticking with the 4150 carb will cost you some power. Are you willing to put a scoop on the car? Do you have fresh air to the carb?
The cam I used was a custom 264/268 that Dwayne had ground. That same cam should work for you or he might have something that would work even better. You will probably need a looser converter to keep the engine in the power band all the way down the track. Something in the low 6000 range for the shift fall back should work but you would need to spend some time with a converter rep.
I think the 4.30 gear would work since the engine should make peak power right around 7000 rpm. The converter will probably slip around 10% so driveshaft speed is 6300 which works out to roughly 130 mph.
[Re: AndyF]
#3176354
09/19/23 02:55 PM
09/19/23 02:55 PM
Posts: 14,374 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Sounds like the current combo is a good candidate to try the roller cam swap first and see how it pans out. If you pull the heads off to swap the springs/retainers/etc, then I’d have them milled a bit to sneak it closer to 12:1. Post a pic of a representative time slip. Cool car
[Re: fast68plymouth]
#3176490
09/19/23 07:31 PM
09/19/23 07:31 PM
Posts: 101 pa
gregcharger72
pa
Sounds like the current combo is a good candidate to try the roller cam swap first and see how it pans out. If you pull the heads off to swap the springs/retainers/etc, then I’d have them milled a bit to sneak it closer to 12:1. Post a pic of a representative time slip. Cool car This is a time slip from last weekend. I didn't mention but the car has 2' hooker super comp headers, and a hood scoop. I put a fiberglass hood on last year.
[Re: gregcharger72]
#3176501
09/19/23 07:48 PM
09/19/23 07:48 PM
Posts: 2,939 Md.
carnut68
Md.
Put that thing on a diet. That's impressive for a big car.
America First!
[Re: gregcharger72]
#3176577
09/20/23 07:35 AM
09/20/23 07:35 AM
Posts: 956 Loudoun County, VA
Brad_Haak
Loudoun County, VA
What type of converter do you have now? At what RPM do you launch? Have you calc'd the slippage? Are you running bias or radial slicks? What's your trap RPM at 125 MPH? At what RPM do you shift? Have you sealed the carb to the scoop? ----------------------------------- How do you like the UNSS series? I've been looking at getting into it if/when my old car is running again.
2021 Challenger 6.4L Scat Pack 1320 (2022) 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008) pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3176585
09/20/23 08:19 AM
09/20/23 08:19 AM
Posts: 101 pa
gregcharger72
pa
What type of converter do you have now? At what RPM do you launch? Have you calc'd the slippage? Are you running bias or radial slicks? What's your trap RPM at 125 MPH? At what RPM do you shift? Have you sealed the carb to the scoop? ----------------------------------- How do you like the UNSS series? I've been looking at getting into it if/when my old car is running again. I launch the car between 2800 to 3200 depending on rt . The converter is from dynamic it's a 9inch. Never calculated the slippage. Not sure how to do that without a data logger. I'm running Goodyear radial slicks. BTW they don't work as well as the hoosiers I was running My trap RPM is 6600 and I shift at 6400 The scoop is sealed to the hood I attached a picture The UNSS series is good, I enjoy the competition. There was a large turn out last week almost 70 cars competing.
