440 six pack, six barrel set up NEW
[Re: moparts]
#3165996
08/06/23 02:35 PM
08/06/23 02:35 PM
Posts: 79 Central Ohio
DavesSledshop
Central Ohio
NEW 440 six pack, never bolted on. Complete set up.
Includes intake, carbs, choke, fuel line, throttle bracket, and throttle return spring and bracket, throttle cable, coil bracket, and all steel air cleaner with filter.
Can deliver to the Nats on Friday. SOLD
Send me a PM for pics and contact info.
Thanks Moparts for the ad!
1967 440 block and 915 heads $1,800
[Re: 52savoy]
#3167490
08/12/23 03:00 PM
08/12/23 03:00 PM
Posts: 238 Southwest Missouri
eenloe
Southwest Missouri
I have a 1967 "C 440" engine block that had been sitting in a car port for many years, still standard bore. I have chased all the threads, cleaned out all the cob webs and bug nests. Build date is Feb 15, 1967. comes with a set of HP 915 heads I have owned for 40 years thinking I would use them on a my roadrunner, but after all this time I am just going to leave the 906 heads on it. $1800 obo See last photo for contact information. Thanks for the add space MOPARTS. ERIC
Re: For Sale - Big Block Engine - 3rd Quarter
[Re: moparts]
#3168462
08/17/23 09:51 AM
08/17/23 09:51 AM
Posts: 15,816 oak park, il.
dsd70bee
oak park, il.
1969 1/2 440 SIX PACK intake & carbs setup for 4-speed cars, front carb List-4393, date code 1229, center carb List-4391, date code 1229, rear carb List-4394, date code 0929, I am selling the carbs on this setup as cores to restore $4000.00 for what you see in the pictures (708) 288-2879
[Re: moparts]
#3168492
08/17/23 12:04 PM
08/17/23 12:04 PM
Posts: 874 West Virginia
B1Frank
West Virginia
*********RUNNING CARB ******* 1966 383-440 carter AFB for a automatic trans cars , # 4131S with tag, it was ran #2 months ago, DOES NOT NEED A REBUILD ! very good carb, $175 + shipping from 26264 THANKS MOPARTS !!!
[Re: moparts]
#3172586
09/03/23 02:06 PM
09/03/23 02:06 PM
Posts: 15 Utah
dartmeister
Utah
SOLD. 440 mild bracket or street/strip engine for sale. I had it in my Duster bracket race car for 3 seasons (1 season on heads) and ran a best of 11.17@118 at 4400' elevation. Ran great when pulled, I removed it for a bigger race engine in attempts to get low 10's out of the car. Engine is disassembled at this time as I was going to do rings/bearings/gaskets and put it in my Dart Swinger street car. I only made about 4 races a year so the short block has approx. 60 1/4 mile passes and the heads have approx. 20 passes on them. With all the parts and pieces I have for it, someone could set it up to be a hot street/strip engine or a good solid bracket engine. I have most everything needed to assemble it either way.
Specs on engine are: 1971 block bored .030 over with TRW 2355 flat top pistons (10.5 to 1 compression), stock steel crank turned .010 under, Edelbrock RPM heads w/84cc closed chambers, Torker 2 RB intake(have both Holley 650dp gas and Holley 750 E-85 carbs if needed) 440 Source 1.6 roller rockers, two different oil pans to choose from(one chrome 6qt and Milodon 8qt with custom diaper to clear steering on A-body), 2 cams with matching lifters one is hydraulic and one solid lifter, new Accel electronic distributor, new rings and rod bearings(had to use mains on different engine) and new HV oil pump new valve covers $3800 and price is negotiable depending on what parts a person wants. many more pics available, only four allowed for ad call four three five- eight five one-2834 with any questions
Re: 1966-1970 DODGE&PLYMOUTH 383-440 DUAL POINT TUNE UP KIT
[Re: Joesixpack]
#3173322
09/06/23 12:05 PM
09/06/23 12:05 PM
Posts: 11,858 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
NOS DUAL POINT TUNE UP KIT FITS 383-426-440-440+6 DODGE&PLYMOUTH 1966-1967-1968-1969-1970 WITH CAST IRON DUAL POINT DISTRIBUTOR INCLUDES A TAN,NOS IBK-1003 INSIDE, MADE IN U.S.A. ON TOP, HD BAKELITE DISTRIBUTOR CAP,W/CARBON BRUSH, A NOS AUTOLITE IBK-1016 ROTOR A NOS AUTOLITE 2-42 STRAP STYLE CONDENSER A NOS AUTOLITE SET OF DUAL POINTS 1-42-V$sold cowgerwilliam035@gmail.com
Motor Mounts- Conversion/Stock A B Engine BEAC Body
[Re: Joesixpack]
#3173952
09/09/23 09:16 AM
09/09/23 09:16 AM
Posts: 1,537 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Many sets of Motor Mount Brackets, some with good insulators- Make Offer $15 Ship in US
SOLD-340-360 Challenger 73-74 Brackets SOLD 340 360 MOTOR MOUNT BRACKETS 73 74 CUDA CHALLENGER MOPAR SET of CORRECT ORIGINAL SOLD
Shumacher 318 into Slant 6 Spool 73 up A body $150 no bolts '73+ A, B, C, F, M, J-Body Slant 6 to 273/318 or 340/360
318 Brackets- pre 72 Biscuit $125 set A B C Body 73 up Spool - $150
383-440 66-72 B E and C Body $100 for brackets or $120 with good insulators Mopar 383 440 Big Blk Motor mounts 66-72 B Body Charger 70-74 E Body Cuda RT | eBay
Big Block Spool- $100
Turck- Some 72-93 LA 4x4, 1 Set Big Block 4x4, Early Sweptline Big Block ask
Make offers. Prefer to sell here first.
Carter AFB 4BBL Carburetor 4200s, 1964-1967 383
[Re: Memongo]
#3174736
09/12/23 04:20 PM
09/12/23 04:20 PM
Posts: 1,454 Northern CA
streetkit
Northern CA
Carter AFB 4BBL Carburetor 4200s, 1964-1967 383 Carb. Used and it has been sitting for a while so it will need to be rebuilt. It is not frozen and moves freely.
$40 + shipping
Located in Northern CA
My email is glolas@comcast.net
1973 Dodge D100
[Re: moparts]
#3177931
09/24/23 10:24 PM
09/24/23 10:24 PM
Posts: 97 pa
gregcharger72
pa
I'm selling my spare 440 back up engine . It is complete carb to oil pan. Starting at the bottom . A 6qt hemi oil pan with 1/2in pickup and oil inlet modifications Forged crank stock stroke, lined honed w/ ARP studded main caps ,LY rods shot peened and sized with ARP rod bolts, balanced rotating assembly Block has been decked and bored .030 over. Has Keith Black quench dome pistons. 11to1 compression Mopar Performance Stage 5 cylinder heads prepped by Hughes engines with 2.14 intake 1.81 exhaust valves and Hughes engines stage one porting. I have flow bench testing sheet. Cam is a Hughes engines solid flat tappet 264/268 @ .050 .594I/.610E lift w/1.5 rocker Crane roller rockers.1.5 ratio. Modified factory valve covers with added baffles Edelbrock victor intake 850 Holley DP carb #4781 Modified factory electronic distributor with mechanical advance limiter Moroso 8.5mm spiral core plug wires. Engine made 460 rwhp on a chassis dyno. Asking $6500.00 Call or Text Greg @ 717 858 2271
