Removing dash in an 88 #3175341
09/15/23 10:24 AM
09/15/23 10:24 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Looking to see how hard and how to remove the dash in a 1988 dodge pickup. There’s a red one at Pic-a-part that’s in great shape.
Re: Removing dash in an 88 [Re: cudaman1969] #3175347
09/15/23 10:37 AM
09/15/23 10:37 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Easy. there's 4 or 5 screws in the top of the dash, one just above the radio. The rest is clips, if a tilt wheel, lower it, pull carefully and it'll come right out. If you have a helper you might have them pry the top of the bezel down from the dash so it'll release easier.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Removing dash in an 88 [Re: 3hundred] #3175356
09/15/23 11:15 AM
09/15/23 11:15 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
There are a series of screws under the windshield seal...the rest is cake.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Removing dash in an 88 [Re: W.I.N. Racing] #3175392
09/15/23 01:47 PM
09/15/23 01:47 PM
fredericksburg,va
fredericksburg,va
Does the windshield have to come out to get to the screws?
Re: Removing dash in an 88 [Re: cudaman1969] #3175460
09/15/23 05:47 PM
09/15/23 05:47 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
No but you really have to cut small sections out of the gasket to expose the screws, you can feel them under the rubber when you push on the gasket. It might be possible to do by prying the gasket up but I doubt it because of the angle of the screws.
Re: Removing dash in an 88 [Re: 440newport] #3175475
09/15/23 06:43 PM
09/15/23 06:43 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Need a good dash? I got a couple
Re: Removing dash in an 88 [Re: volaredon] #3175516
09/15/23 10:40 PM
09/15/23 10:40 PM
fredericksburg,va
fredericksburg,va
If I mess up the one in scrap yard we might need to talk.
Re: Removing dash in an 88 [Re: cudaman1969] #3175719
09/16/23 07:32 PM
09/16/23 07:32 PM
Byron, NY
Byron, NY
I find it easier to remove the windshield...
'60 Willys CJ5
