Leaf link/ladder link rear suspension...
#3173248
09/06/23 04:17 AM
09/06/23 04:17 AM
Posts: 10,308 A Red State
SNK-EYZ
A Red State
I just got a 70 Cuda that has the old school leaf link/ladder link rear suspension. I know that it's old school stuff.
The plan is to make it mainly a street car that will occasionally go to the track.
What are opinions on that type of rear suspension?
Re: Leaf link/ladder link rear suspension...
[Re: Cab_Burge]
#3173251
09/06/23 04:31 AM
09/06/23 04:31 AM
SNK-EYZ
A Red State
The springs are obviously moved in, they are in the frame rails in the front. They used regular spring hangers in the back with what looks like added homemade mounts to attach them to the frame rail area..
My concern is that they literally touch the rear valance.
Trying to decide how to deal with that.
Sliders on the rear may be a good option for clearance, but is that a good choice for a mainly street car?
[Re: SNK-EYZ]
#3173270
09/06/23 08:24 AM
09/06/23 08:24 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Ditch the leafsprings, weld in a shock crossmember, and add coilovers.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3173285
09/06/23 09:38 AM
09/06/23 09:38 AM
Posts: 4,806 Wichita
GY3
Wichita
Ditch the leafsprings, weld in a shock crossmember, and add coilovers. This! Things like this were done primarily to fit a rules package back in the day.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: cudaman1969]
#3173326
09/06/23 12:19 PM
09/06/23 12:19 PM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Old school. It will work. Clean and lube the springs and sliders so they can move freely.
[Re: SNK-EYZ]
#3173342
09/06/23 01:13 PM
09/06/23 01:13 PM
Posts: 4,114 Yes
sixpakdodge
Yes
Sliders on the rear may be a good option for clearance, but is that a good choice for a mainly street car? It sounds like it has the wrong springs on it? Possibly a longer rear segment than normal, or the spring has flattened out. I would leave the ladder/floater. It will work just fine. One of my cars is still set up that way. As mentioned, keep it greased. The only thing I see that I would change is how they have the rear shocks mounted to the axle. I don't see that lasting long under any kind of stress.
[Re: SNK-EYZ]
#3173420
09/06/23 05:42 PM
09/06/23 05:42 PM
Posts: 4,807 Moved to N.E. Tennessee
GomangoCuda
My concern is that they literally touch the rear valance. . Probably has B body springs on it. E body springs are 1" shorter in the rear segment. E Body 35" vs B body 36".
[Re: GomangoCuda]
#3173445
09/06/23 07:34 PM
09/06/23 07:34 PM
SNK-EYZ
A Red State
It'll be a couple weeks before I get it up on jack stands so I can start measuring the spring lengths.
I want to get through the Holley Moparty before I dive into it and the other project Cuda (a 72) that I have to work on.
After the Moparty hopefully I can get some of the stuff figured out so I know what I'll be doing with it suspension wise.
[Re: SNK-EYZ]
#3173482
09/06/23 09:49 PM
09/06/23 09:49 PM
Posts: 6,163 Melbourne , Australia
LA360
What does it drive like? I bought a car with a similar set up, for a street car, I didn't like it. I went back to normal leaf springs.
Alan Jones
[Re: SNK-EYZ]
#3173483
09/06/23 09:50 PM
09/06/23 09:50 PM
Posts: 43,743 Bend,OR USA
Cab_Burge
[Re: LA360]
#3173493
09/06/23 11:28 PM
09/06/23 11:28 PM
SNK-EYZ
A Red State
What does it drive like? I bought a car with a similar set up, for a street car, I didn't like it. I went back to normal leaf springs. At this point the car is just a body, no drive train in it so it's not drive able.
[Re: cudaman1969]
#3173545
09/07/23 11:28 AM
09/07/23 11:28 AM
Posts: 19,544 Las Vegas
Al_Alguire
Las Vegas
Step into the 90's and ditch the leafs and put coil overs on it personally.
[Re: GomangoCuda]
#3173687
09/08/23 04:56 AM
09/08/23 04:56 AM
SNK-EYZ
A Red State
My concern is that they literally touch the rear valance. . Probably has B body springs on it. E body springs are 1" shorter in the rear segment. E Body 35" vs B body 36". I climbed under it to measure the rear segment of the leaf springs, if I measured it right going from the spring centering bolt to the center of where the rear spring hanger I was coming up with 35.5 inches. when you say E Body 35" vs B body 36" exactly where are the measurement points? Assuming spring centering bolt but what point at the rear of the spring?
[Re: DusterKid]
#3173688
09/08/23 05:01 AM
09/08/23 05:01 AM
SNK-EYZ
A Red State
How fast is the car going to be?
If your going to keep the ladder bar, make sure the front heim joint has the safety loop, Seen to many cars tore up without having one. Realistically, 11's is the goal. The engine plan is 472 BB (440 with a 3.90 stoker crank that I have) , nothing radical just lots of torque for the street. I looked at the front of the ladder bars, they have the safety loops on them.
[Re: SNK-EYZ]
#3173706
09/08/23 08:58 AM
09/08/23 08:58 AM
Posts: 3,177 Michigan
A727Tflite
My concern is that they literally touch the rear valance. . Probably has B body springs on it. E body springs are 1" shorter in the rear segment. E Body 35" vs B body 36". I climbed under it to measure the rear segment of the leaf springs, if I measured it right going from the spring centering bolt to the center of where the rear spring hanger I was coming up with 35.5 inches. when you say E Body 35" vs B body 36" exactly where are the measurement points? Assuming spring centering bolt but what point at the rear of the spring? Measure on the spring radius. Not in a straight line. Lay the tape on the main leaf from the center pin to the center of the rear eye. Sounds like you have 36”.
