Re: trailer break away system Q
[Re: Cab_Burge]
#3172617
09/03/23 04:04 PM
09/03/23 04:04 PM
Posts: 23,295 Here
jcc
Here
I'd suggest a maybe 30a breaker if wire size is larger than 14g, being this is only potentially for intermittent use during breakaway. and 14g+ will handle short periods of 25A as breaker resets.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: jcc]
#3172799
09/04/23 12:15 PM
09/04/23 12:15 PM
Posts: 631 Ct
Wirenut
Ct
I'd suggest a maybe 30a breaker if wire size is larger than 14g, being this is only potentially for intermittent use during breakaway. and 14g+ will handle short periods of 25A as breaker resets. Was thinking the same
[Re: dvw]
#3172800
09/04/23 12:15 PM
09/04/23 12:15 PM
Posts: 631 Ct
Wirenut
Ct
One more trick. Get a second dead man switch. Mount it under the trailer close to the axle. Run the pull cable through the wheel. If the wheel ever rotates it'll pull the pin. The brakes will be on. Good theft device. Doug Very smart
[Re: jcc]
#3172812
09/04/23 01:04 PM
09/04/23 01:04 PM
Posts: 9,982 MI, usa
dvw
MI, usa
Until you forget it's hooked up and drive away, not that I would ever do that. That's how I know it works. You don't move very far. Doug
