Re: wiring/terminals Q
[Re: Al_Alguire]
#3172563
09/03/23 12:22 PM
09/03/23 12:22 PM
RapidRobert
there was info about using something on the connection before you slide the heat sink sleeve over it (dielectric grease?)
[Re: moparx]
#3172588
09/03/23 02:21 PM
09/03/23 02:21 PM
RapidRobert
OK, does the marine grade tubing come with the sealing glue or is that a separate purchase? if so what/where to get it?
[Re: markz528]
#3172859
09/04/23 03:37 PM
09/04/23 03:37 PM
Posts: 8,225 Plymouth, MI
Blusmbl
Plymouth, MI
Biggest problem is cracking. The solder does not do well in vibration environments and a car is a vibration environment. x2. The wiring will typically crack where the solder ends, we have seen it over and over on durability routes. From what I understand, connections aren't supposed to be soldered on airplanes for the same reason.
[Re: Blusmbl]
#3172885
09/04/23 04:46 PM
09/04/23 04:46 PM
Posts: 10,611 Rittman Ohio
fourgearsavoy
Rittman Ohio
Biggest problem is cracking. The solder does not do well in vibration environments and a car is a vibration environment. x2. The wiring will typically crack where the solder ends, we have seen it over and over on durability routes. From what I understand, connections aren't supposed to be soldered on airplanes for the same reason. I must take longer than 30 years because my crimped and soldered connections that I made are still good. I think as long as you keep your wires from vibrations and run it in insulated clamps like I do there won't be an issue. I use crimp terminals for interior wiring or connections that aren't exposed to the weather. After 40 years as an Import technician I have seen my share of corroded crimped connectors here in the rust belt. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: CMcAllister]
#3172917
09/04/23 06:26 PM
09/04/23 06:26 PM
Posts: 4,745 On the parachute mount
n20mstr
The trick I use to protect solder joints is strain relief . I will put 2 sometimes 3 shrink tubes . Each one longer than the previous and always long to protect the solder so the wire doesn’t flex in that area . Also if it makes sense use as little solder as possible to keep the wicking up the wire to a minimum
....BAD A$$ STREET CAR.....
[Re: fourgearsavoy]
#3173014
09/05/23 02:19 AM
09/05/23 02:19 AM
Posts: 43,741 Bend,OR USA
Cab_Burge
Biggest problem is cracking. The solder does not do well in vibration environments and a car is a vibration environment. x2. The wiring will typically crack where the solder ends, we have seen it over and over on durability routes. From what I understand, connections aren't supposed to be soldered on airplanes for the same reason. I must take longer than 30 years because my crimped and soldered connections that I made are still good. I think as long as you keep your wires from vibrations and run it in insulated clamps like I do there won't be an issue. I use crimp terminals for interior wiring or connections that aren't exposed to the weather. After 40 years as an Import technician I have seen my share of corroded crimped connectors here in the rust belt. Gus I started working for a small telephone company in 1964, the cable splicers would skin and twist the smaller gauge wires and insulate them with small paper or plastic sleeves depending on what the cables were insulated with originally. They used insulators over the 20 GA or smaller cable wires when splicing the telephone cables together, they would twist and solder the 19 GA cables and slide the insulators over them. It didn't matter if the cables were on poles or in conduits underground, they used the same techniques on both I don't have a clue what they do now in this age of smart phones
