Re: Help, E Body Side Mirror [Re: cataclysm80] #317117
05/15/09 04:09 PM
05/15/09 04:09 PM
cataclysm80 Offline OP
Correct, Through the center of both screws straight to the front edge of the door. (17 1/4 & 20 1/4 in this picture)
Re: Help, E Body Side Mirror [Re: cataclysm80] #317118
05/15/09 04:15 PM
05/15/09 04:15 PM
Wrong way to measure...
From center of screw hole level to front edge of door. (17 5/8 in this picture) (note you can't even see the second screw hole)
Re: Help, E Body Side Mirror [Re: 318 Stroker] #317119
05/15/09 05:28 PM
05/15/09 05:28 PM
I just measured the mirrors on my 73 Challenger. I've owned the car since it was 6 mos. old, so I know the history on the car. It has the original doors & skins. Car came equipped with dual chrome sport mirrors, which I've replaced with painted sport mirrors, using the original screw hole mounts.
From the front leading edge of the door to the centerpoint of the front screw, both mirrors measure 15 3/4".
From the top edge of the door to the front screw centerpoint, the drivers side measures 7/8", and the passenger side measures 3/4".
Hi Allen, glad to see you here! You didn't post the measurement for the rear screw hole. Could you tell me if your mirrors have the same 3 1/8 inch spacing between the screw holes as gtxncuda reported on his 71? (should be the same mirrors, so I think it will match)
Tav
Re: Help, E Body Side Mirror [Re: cataclysm80] #317120
05/15/09 05:40 PM
05/15/09 05:40 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Tav
Hi Tav, yes I'll measure it when I get home from work. They are the 71-74 style rallye mirrors, which have a different spacing between screw holes vs. the 70 style with the shorter bases.
Re: Help, E Body Side Mirror [Re: cataclysm80] #317121
05/28/09 06:52 AM
05/28/09 06:52 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Both of my 74 cars have the front screws 16" from the front of the door edge and 1" down from the body line on the drivers side. Both cars were 15 3/4" from the front door edge and 1" down from the body line on the pass side. I didn't get a chance to check my 71 but I will.
Re: Help, E Body Side Mirror [Re: cataclysm80] #317122
05/28/09 11:10 AM
05/28/09 11:10 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I just wanted to post some pics of how to measure, just to make sure we're all on the same page, comparing apples to apples...
Correct, center of screw to top bodyline. (3/4 inch in this picture)
My 15/16 measurement was done with the same method. My AAR is also Lemon Twist.
logan426
Re: Help, E Body Side Mirror [Re: MLR426] #317123
05/28/09 11:40 AM
05/28/09 11:40 AM
logan426
Good to see you here. I corrected the quote earlier in the thread. thanks for the info.
Tav
