Re: NGK Plugs.....
[Re: mopar dave]
#3170806
08/27/23 01:16 PM
08/27/23 01:16 PM
Posts: 2,137 Byron, NY
W.I.N. Racing
Byron, NY
I use 80+ NGK's yearly...so far so good
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: NGK Plugs.....
[Re: fbs63]
#3170896
08/27/23 07:12 PM
08/27/23 07:12 PM
Posts: 10,611 Rittman Ohio
fourgearsavoy
Rittman Ohio
There are counterfeit NGK plugs circulating. Not sure how to check for origin on them but I bet that's what you have there. Some of the larger chain parts stores buy plugs from some jobbers that sell the counterfeit junk NGK and Denso user for 38 years without failure. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: NGK Plugs.....
[Re: mopar dave]
#3170983
08/28/23 08:52 AM
08/28/23 08:52 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
NGK only for me for the past 20+ years. No issues ever. Nothing against other brands really, just more familiar w/ the NGK numbers.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: NGK Plugs.....
[Re: GY3]
#3173723
09/08/23 09:24 AM
09/08/23 09:24 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
I prefer NGK vs champion plugs What are your other options?
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: NGK Plugs.....
[Re: fourgearsavoy]
#3173774
09/08/23 12:31 PM
09/08/23 12:31 PM
Posts: 16,936 NC
440Jim
NC
There are counterfeit NGK plugs circulating. Not sure how to check for origin on them but I bet that's what you have there. Some of the larger chain parts stores buy plugs from some jobbers that sell the counterfeit junk That is the last thing we need. Real businesses buying conterfeit parts and selling them to us. It is bad enough that illegal crap manf exist in the first place. Just trying to change spark plugs turns into a nightmare.... It would be nice if somebody knows how to spot them, if possible.
Re: NGK Plugs.....
[Re: fbs63]
#3173856
09/08/23 07:40 PM
09/08/23 07:40 PM
Posts: 28,717 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
There are counterfeit NGK plugs circulating. Not sure how to check for origin on them but I bet that's what you have there. I called NGK and gave the numbers on the plugs. He told me wgat plant and when made amd if real. Also said they do not copy-fake copper or nickel one's. But plenty of fake iridium ones. To buy from a real place. That Summit Racing is authorized source, and Rockauto gers them from one and is also safe. I like how the coating NGK puts is easy to read. Ford spects NGK so does Honda. The Honda small engine stuff i have us Ho da boxes with NGK If i can't get NGK it is Autolite
Re: NGK Plugs.....
[Re: 340SIX]
#3174668
09/12/23 01:53 PM
09/12/23 01:53 PM
Posts: 1,443 NW Chicago suburban area
Mopar Mitch
Just an FYI... NGK is likely going to buy-out DENSO for spark plug future production... according to certain business news. DENSO forsees the future of internal combustion engines declining.. so their potential exit from that market.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: NGK Plugs.....
[Re: Leigh]
#3175014
09/13/23 05:26 PM
09/13/23 05:26 PM
Posts: 19,544 Las Vegas
Al_Alguire
Las Vegas
Only NGK for me in all the racecars for the last 20+ years.
Re: NGK Plugs.....
[Re: Al_Alguire]
#3175114
09/14/23 08:33 AM
09/14/23 08:33 AM
Posts: 1,326 Loudoun County, VA
Brad_Haak
Loudoun County, VA
NGK is the factory plug for all the Japanese motorcycle manufacturers. Never saw an issue such as the OP posted over decades of experience with them.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: NGK Plugs.....
[Re: Brad_Haak]
#3175153
09/14/23 12:37 PM
09/14/23 12:37 PM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
I saw a "reel" on Instagram that showed how to unscrew and replace the tip on the ignition wire end with a solid core tip. They said their example is specifically for a Mopar. The replacement tips can be re-used again and again in fresh plugs. Not sure where they get them, but figured some of you guys know.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
