Re: OK I'm Shopping For a Lift!
[Re: Iron_Iceberg]
#31697
10/20/06 08:58 PM
10/20/06 08:58 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Don't know if I want to get under anything called "Bend Pack!" A friend was going to Eagleville today to look at some equipment. I guess they sell close out, used equipment etc. Lots of great info here! THANKS AGAIN!! ![](/ubbthreads/images/graemlins/laugh.gif)
[Re: Iron_Iceberg]
#31698
10/20/06 09:24 PM
10/20/06 09:24 PM
Posts: 7,843 Spring Mount, PA
MOPAULY
Spring Mount, PA
A guy up in Washington died awhile back under one.
And that would be? I am leary of the overseas made stuff. Thus far I've used my Gemini a few times and it doesn't make me nervous, looks a bit like the bend pak units from the pictures I've ssen of them.
[Re: Rug_Trucker]
#31706
10/21/06 08:25 AM
10/21/06 08:25 AM
MOPAULY
Spring Mount, PA
Wasn't there a lift somewhere that dropped a Corvette onto another Corvette? Eagle brand?
That was a 4 post unit that let go on one of the corners. Don't remember what broke.
[Re: no318]
#31709
10/21/06 11:20 AM
10/21/06 11:20 AM
Eagle is low on the list of the better quality certified lifts. Top of the list is Mohawk and I'd put Rotary next. The name Bend Pak come from the benders they also make. They've been in business for only 41 years. Double check the certs on the backyard stuff, I don't think they have the certs that the commercial pro stuff has.
#31710
10/21/06 01:43 PM
10/21/06 01:43 PM
Posts: 2,431 USA
SSAAHemiFan
USA
I have looked at practically every lift offered up close and here is my ![](/ubbthreads/images/graemlins/Twocents.gif) If you want a 2 post Mohawk is the choice. The wider base is a plus especially if the strength of your concrete floor is unknown. They also offer attatchments to convert the 2 post into a "wheel lift" design. Looking for a 4 post... Backyard Buddy all the way. Was copied directly from a military design for portable lifts in the field. Superior construction , best locking system, fully captured post (no cheesy C-channel posts w/internal slider), best engineered by far. Things like channel runways (instead of stamped), tool steel pins on locks and pulleys, machined pulley's(not cast or plastic), and the biggest lifting ram all cost more. Made in the USA , toured the plant when I picked mine up. My dad has had his over 12 yrs. w/no problems. Regardless what anyone will tell you ANY internal slider (C-channel) post lift is designed to be bolted down. Once you take the time to look at the "Good Ones" you can easily see where corners are cut on the cheap models. You get what you pay for. Got a Quaker Steak and Lube near you??? They have them in the resturants loaded with REAL cars and tables set under them for people to eat. I GUARANTEE the lawyers insisted some research be done on them for this.
[Re: AZ_A12_BEE]
#31711
10/21/06 02:39 PM
10/21/06 02:39 PM
The backyard buddy looks like a nice lift but I cannot find anything on their website attesting to independent certification from the ALI or ETL. Most all lifts are ANSI standard, this doesn't mean it is independently certified/tested. http://www.autolift.org/members.html
[Re: SSAAHemiFan]
#31713
10/21/06 05:01 PM
10/21/06 05:01 PM
Never asked them about certification once they told me they were copied from a US military design.. I figured the military specs would override any civilian tests????
some times "mil spec" = lowest bidder
[Re: MOPAULY]
#31716
10/22/06 02:42 AM
10/22/06 02:42 AM
Posts: 893 A-Town, CA
Iron_Iceberg
super gas
super gas
A-Town, CA
http://www.garagejournal.com/forum/showthread.php?t=5546
