Re: OK I'm Shopping For a Lift! [Re: Iron_Iceberg] #31697
10/20/06 08:58 PM
10/20/06 08:58 PM
Not2farfromNashville, TN
Rug_Trucker Offline OP
Don't know if I want to get under anything called "Bend Pack!"
A friend was going to Eagleville today to look at some equipment. I guess they sell close out, used equipment etc.
Lots of great info here!
THANKS AGAIN!!
Re: OK I'm Shopping For a Lift! [Re: Iron_Iceberg] #31698
10/20/06 09:24 PM
10/20/06 09:24 PM
Spring Mount, PA
MOPAULY Offline
MOPAULY  Offline
Spring Mount, PA
A guy up in Washington died awhile back under one.
And that would be? I am leary of the overseas made stuff. Thus far I've used my Gemini a few times and it doesn't make me nervous, looks a bit like the bend pak units from the pictures I've ssen of them.
Re: OK I'm Shopping For a Lift! [Re: MOPAULY] #31699
10/20/06 10:22 PM
10/20/06 10:22 PM
Wasn't there a lift somewhere that dropped a Corvette onto another Corvette? Eagle brand?
Re: OK I'm Shopping For a Lift! [Re: MOPAULY] #31700
10/20/06 10:37 PM
10/20/06 10:37 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
thats why I paid more for a Backyard Buddy made in Ohio and certified, my life is worth more than the $1500 I might save on a cheaper unit
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: OK I'm Shopping For a Lift! [Re: AZ_A12_BEE] #31701
10/20/06 10:45 PM
10/20/06 10:45 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
AZ_A12.....how high is the ceiling in that pic? Can you get another car under it set at that height?
Re: OK I'm Shopping For a Lift! [Re: JDMopar] #31702
10/20/06 10:51 PM
10/20/06 10:51 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
ceiling is 9ft 6in, just tall enough to get the front of my daughters car underneath and close the garage door, its a temp thing and lift will move to my new shop with 12 foot ceilings
Re: OK I'm Shopping For a Lift! [Re: AZ_A12_BEE] #31703
10/20/06 11:03 PM
10/20/06 11:03 PM
JDMopar Offline
JDMopar  Offline
Thanks.I'm hoping to start building my garage in the spring,and trying to make up my mind on ceiling height.I plan on buying a Backyard Buddy lift as well,and would like to be able to use it for stack parking.
Re: OK I'm Shopping For a Lift! [Re: JDMopar] #31704
10/20/06 11:10 PM
10/20/06 11:10 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
here is my thread on the shop Im building, 27x32 with a full basement using a commercial style concrete floor like parking garages over the basement
https://board.moparts.org/ubbthreads/show...rue#Post3002253
Re: OK I'm Shopping For a Lift! [Re: Rug_Trucker] #31705
10/21/06 02:56 AM
10/21/06 02:56 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I was impressed with Eagle lifts. I think the 9000lb assymetic lift is an excellent choice. I know several people with 4posts and they complain about the posts being in the way. Eagle was very friendly. They even sent me the installation instructions for the lift I wanted even though I had not bought one. They even discuss cutting down the tall lift 3" to accomodate my garage ceiling for only like $300. For under $2000 I think it is the lift for me. Only need 4" of concrete if I remember. I have the garage all wired for it, however, I am on pause right now. I am contemplating building a bigger garage out back as a shop. You may want to check out American lifts as well. I seem to remember they were competitive as well.
Re: OK I'm Shopping For a Lift! [Re: Rug_Trucker] #31706
10/21/06 08:25 AM
10/21/06 08:25 AM
Spring Mount, PA
MOPAULY Offline
MOPAULY  Offline
Spring Mount, PA
That was a 4 post unit that let go on one of the corners. Don't remember what broke.
Re: OK I'm Shopping For a Lift! [Re: MOPAULY] #31707
10/21/06 08:42 AM
10/21/06 08:42 AM
Then the next question is, are the Eagles certified?
I am going to go over all this stuff tonight. Got to head to work this morning.
Re: OK I'm Shopping For a Lift! [Re: Rug_Trucker] #31708
10/21/06 08:46 AM
10/21/06 08:46 AM
Nebraska
N
no318 Offline
no318  Offline
N
Nebraska
Rotary lift HANDS DOWN. Excellent quality and reasonable $$$. My 10,000 lb 2 post was like $3200. Options and different heights are available if clearance is an issue. We have had them in professional shops that I have worked in, and so that is what I wanted at home.
Re: OK I'm Shopping For a Lift! [Re: no318] #31709
10/21/06 11:20 AM
10/21/06 11:20 AM
Eagle is low on the list of the better quality certified lifts. Top of the list is Mohawk and I'd put Rotary next. The name Bend Pak come from the benders they also make. They've been in business for only 41 years. Double check the certs on the backyard stuff, I don't think they have the certs that the commercial pro stuff has.
Re: OK I'm Shopping For a Lift! #31710
10/21/06 01:43 PM
10/21/06 01:43 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I have looked at practically every lift offered up close and here is my
If you want a 2 post Mohawk is the choice. The wider base is a plus especially if the strength of your concrete floor is unknown. They also offer attatchments to convert the 2 post into a "wheel lift" design.
Looking for a 4 post... Backyard Buddy all the way. Was copied directly from a military design for portable lifts in the field. Superior construction , best locking system, fully captured post (no cheesy C-channel posts w/internal slider), best engineered by far.
Things like channel runways (instead of stamped), tool steel pins on locks and pulleys, machined pulley's(not cast or plastic), and the biggest lifting ram all cost more.
Made in the USA , toured the plant when I picked mine up. My dad has had his over 12 yrs. w/no problems.
Regardless what anyone will tell you ANY internal slider (C-channel) post lift is designed to be bolted down.
Once you take the time to look at the "Good Ones" you can easily see where corners are cut on the cheap models.
You get what you pay for.
Got a Quaker Steak and Lube near you??? They have them in the resturants loaded with REAL cars and tables set under them for people to eat. I GUARANTEE the lawyers insisted some research be done on them for this.
Re: OK I'm Shopping For a Lift! [Re: AZ_A12_BEE] #31711
10/21/06 02:39 PM
10/21/06 02:39 PM
The backyard buddy looks like a nice lift but I cannot find anything on their website attesting to independent certification from the ALI or ETL. Most all lifts are ANSI standard, this doesn't mean it is independently certified/tested.
http://www.autolift.org/members.html
Re: OK I'm Shopping For a Lift! #31712
10/21/06 02:48 PM
10/21/06 02:48 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Never asked them about certification once they told me they were copied from a US military design.. I figured the military specs would override any civilian tests????
Re: OK I'm Shopping For a Lift! [Re: SSAAHemiFan] #31713
10/21/06 05:01 PM
10/21/06 05:01 PM
some times "mil spec" = lowest bidder
Re: OK I'm Shopping For a Lift! #31714
10/21/06 05:30 PM
10/21/06 05:30 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
backyard buddy all the way
Re: OK I'm Shopping For a Lift! [Re: SSAAHemiFan] #31715
10/21/06 07:13 PM
10/21/06 07:13 PM
Spring Mount, PA
MOPAULY Offline
MOPAULY  Offline
Spring Mount, PA
Don't have any certs for my lift but I looked at it again after this thread and it's built pretty [Edited by Moparts - Keep it clean] solid.
Re: OK I'm Shopping For a Lift! [Re: MOPAULY] #31716
10/22/06 02:42 AM
10/22/06 02:42 AM
A-Town, CA
I
Iron_Iceberg Offline
super gas
super gas
I
A-Town, CA
http://www.garagejournal.com/forum/showthread.php?t=5546
66 Dodge Coronet (Race?) 69 Dodge Dart (Street?) 70 Plymouth Cuda 440-6 (Stock!) My Tech Web Page www.freewebs.com/iron-iceberg/index.htm
