frame connectors or move leaf springs inboard first? #316305
05/12/09 08:24 PM
05/12/09 08:24 PM
Maryland
dduster73 Offline OP
Maryland
Getting ready to move the springs in 3" with the relocation boxes from Mopar. I am also going to install subframe connectors. Which one should i do first?The car is my 73 Duster 440/4 speed. Thanks for any advice, Dave
Re: frame connectors or move leaf springs inboard first? [Re: dduster73] #316306
05/12/09 08:32 PM
05/12/09 08:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do both while the car is down... the connectors dont
take much time at all to do, 2" X 3" box tubing
Re: frame connectors or move leaf springs inboard first? [Re: dduster73] #316307
05/12/09 08:33 PM
05/12/09 08:33 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I vote furr ... connectors first. And use the FULL square tube type.
Re: frame connectors or move leaf springs inboard first? [Re: dduster73] #316308
05/12/09 08:33 PM
05/12/09 08:33 PM
Connecticut
5126brl No more Offline
Connecticut
If you are set on doing this then frame connectors first.
Do you relly need that much tire room?
I wish my car was not tubbed!
Re: frame connectors or move leaf springs inboard first? [Re: 5126brl No more] #316309
05/12/09 08:39 PM
05/12/09 08:39 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
I wish I wouldn't have done mine, even more so after I read there are guys running in the 8's on a 275 radial.
Re: frame connectors or move leaf springs inboard first? [Re: Blown61] #316310
05/12/09 08:40 PM
05/12/09 08:40 PM
Connecticut
Connecticut
Thats the part I really hate now!
A tubbed car in the 10's when small tire cars are in the 8's.
Re: frame connectors or move leaf springs inboard first? [Re: dOc !] #316311
05/12/09 08:44 PM
05/12/09 08:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah... cut the floor pan and sink the whole tube
in there, dont contour it
Re: frame connectors or move leaf springs inboard first? [Re: 5126brl No more] #316312
05/12/09 08:50 PM
05/12/09 08:50 PM
Maryland
Maryland
I am using the 2x3 box tubing. I will be cutting into the floor and welding the floor to the frame connectors also.Thanks to everyone for their input. Dave
Re: frame connectors or move leaf springs inboard first [Re: dduster73] #316313
05/12/09 09:08 PM
05/12/09 09:08 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I did both at once. Here's a link to some pics:
http://www.rhphoto.com/leaf_spring.html
http://www.rhphoto.com/frame_connectors.html
Best of luck
Re: frame connectors or move leaf springs inboard first? [Re: 5126brl No more] #316314
05/12/09 09:45 PM
05/12/09 09:45 PM
Toronto
mshred Offline
mshred  Offline
Toronto
more tire helps consistency regardless if small tire guys are running in the 8's...plus, nothing beats the look of fatter meats out back if full on steam rollers arent an option
