no pressure in #4 ... lots of ?'s... UPDATED #315350
05/11/09 08:14 PM
05/11/09 08:14 PM
Medford OR
FrankenScamp Offline OP
Medford OR
So my new 340 decided to do the unthinkable...bent valve?? Thats my only guess.
Question #1: Will poor oiling to the top end contribute to a bent valve? I have oil to 6 of my 8 rockers(passenger side). Oil does make it to the other 2 but no where near as much. Very slight. What would cause this??
Question #2: If the cam bearing was improperly installed would I have any oil at all to the right side? The left side lubes up just fine.
Question #3: Will bending a valve ruin the seat? Or can I just replace the valve if no damage was done to the piston/walls.
All other cylinders have 150 psi and all the rockers move as they should. I watched them to make sure the are all moving the same distance up and down.
Thanks for taking time to read my post and any info is greatly appreciated.
Re: no pressure in #4 all others good. lots of ?'s [Re: FrankenScamp] #315351
05/11/09 08:54 PM
05/11/09 08:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would say if you have oil to the rest of the rockers on that side you have an obstruction in the shaft.
Lots of luck with the bent valve. Guide possibly seized the stem. Probably damaging the piston along with the valve and guide and very possibly the seat. I would never try to put in a new valve with out at least touching up the valve on valve refacer to check for true. I would also make sure to lap the valve in and see where it is seating. Don't try to cut corners.
Re: no pressure in #4 all others good. lots of ?'s [Re: MoparforLife] #315352
05/11/09 09:12 PM
05/11/09 09:12 PM
That valve siezed in the guide & it hit a piston? I would pull the dist/inter shaft, turn the crank to the right spot & prime the pump w your drill & see exactly how much flow/distribution you do have & go from there.
Re: no pressure in #4 all others good. lots of ?'s [Re: MoparforLife] #315353
05/11/09 09:17 PM
05/11/09 09:17 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Question #2: If the cam bearing was improperly installed would I have any oil at all to the right side? The left side lubes up just fine.Probably not. Especially if you have six that are ok.
Pull the plugs out of the shaft and clean it up. Lots of luck with the bent valve. Guide possibly seized the stem. That's be my guess too. Expecially if a valve has a lot of lash. Probably damaging the piston along with the valve and guide and very possibly the seat. Depends. I would never try to put in a new valve with out at least touching up the valve on valve refacer to check for true. I would also make sure to lap the valve in and see where it is seating. Don't try to cut corners. Without a doubt.
Re: no pressure in #4 all others good. lots of ?'s [Re: FrankenScamp] #315354
05/11/09 09:24 PM
05/11/09 09:24 PM
Queens, NYC
Racer413 Offline
Racer413  Offline
Queens, NYC
how new was the 340? if the valve was too tight in the guide it could seize when it heated up.
Re: no pressure in #4 all others good. lots of ?'s [Re: 6PakBee] #315355
05/11/09 09:24 PM
05/11/09 09:24 PM
Medford OR
Medford OR
What is acceptable lash(I have gauges)? Maybe the rocker is worn and there's too much slop where the shaft goes through the rocker hence creating too much play while the valve opens and closes.
Am I on the right track? Thanks for the replies guys...
Re: no pressure in #4 all others good. lots of ?'s [Re: Racer413] #315356
05/11/09 09:27 PM
05/11/09 09:27 PM
Medford OR
Medford OR
its a fresh rebuild. The machine shop assembled the heads, I just bolted the motor together. I'm not looking to place blame as the shop is top notch...but they are human and they would b more than willing to help out im sure.
Re: no pressure in #4 all others good. lots of ?'s [Re: FrankenScamp] #315357
05/11/09 09:31 PM
05/11/09 09:31 PM
w more thought I think V/P collision from overrevving or from not enough V/P clearance to begin with or(MUCH)less likely the valve siezing in the guide. I think your oiling system is fine.
Re: no pressure in #4 all others good. lots of ?'s [Re: RapidRobert] #315358
05/11/09 09:40 PM
05/11/09 09:40 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Is it a mechanical or hydraulic cam? If hydraulic you should have no lash, if mechanical what does your cam card call for? How close are you to that number? If the valve is seized chance are it won't move. If actually bent, it probably won't return to closed but it should move towards more open. As a rough guide, take a steel rule and measure the installed height of the spring retainers. That should tell you how your valves compare.
Re: no pressure in #4 all others good. lots of ?'s [Re: RapidRobert] #315359
05/11/09 09:41 PM
05/11/09 09:41 PM
Medford OR
Medford OR
the engine was in no way over-rev'd. clearance was not checked by me. THe pistons do have reliefs so I assume(yea I know) that wasn't the issue. I'll be checking that upon re assembly for sure.
Thanks.
Re: no pressure in #4 all others good. lots of ?'s [Re: FrankenScamp] #315360
05/11/09 09:42 PM
05/11/09 09:42 PM
Joplin, MO
734x4PW Offline
734x4PW  Offline
Joplin, MO
As I see it you have no compression in #4, but are watching all rockers move up and down the same?
Remove the valve train for #4 (the whole shaft if you have that setup). MEASURE your installed valve height. Or, get a straightedge and check the installed height of the valve.
Anytime I have NO compression from a hole, I isolate the cylinder by removing the rockers and pressurize it with air. Then you know FOR SURE if it is an exhaust valve, intake valve, or a ring/piston problem, head gasket, etc. Just follow the air.
Mark
Re: no pressure in #4 all others good. lots of ?'s [Re: 6PakBee] #315361
05/11/09 09:59 PM
05/11/09 09:59 PM
Medford OR
Medford OR
Hydraulic RV cam. The engine is almost stock, nothing fancy. I'll go measure/compare them now.
Re: no pressure in #4 all others good. lots of ?'s [Re: FrankenScamp] #315362
05/11/09 10:07 PM
05/11/09 10:07 PM
Medford OR
Medford OR
yea its the #4 exhaust valve. I can see the difference and confirmed it by laying a length of unused brake line across the top of the valves.
Re: no pressure in #4 all others good. lots of ?'s [Re: FrankenScamp] #315363
05/12/09 08:38 PM
05/12/09 08:38 PM
Joplin, MO
734x4PW Offline
734x4PW  Offline
Joplin, MO
Well, obviously the head has to come off, but you need to find out why that valve failed to close. It could have been hit or seized as others have already mentioned.
Myself, I'm wondering if you used new or used valve springs - a weak spring could have let the valve remain open a tad too long and *bang*.
If you pop the spring off, you can tell a lot. If you can move the valve easily until the last, it's probably just bent. If it's stiff, you have too little clearance, and it was seizing. This will help steer you clear from these troubles next time.
Let us know what you find.
Mark
Re: no pressure in #4 all others good. lots of ?'s [Re: 734x4PW] #315364
05/13/09 12:22 AM
05/13/09 12:22 AM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
Although it's uncommon, I recently had a valve seat drop on #6 exhaust valve. My problem came from a poor head gasket seal between #4 and #6 cylinders from the chambers being clearanced for larger exhaust valves. On #4 and #6 the exhaust valves face each other. If that area got too hot due to a poor fire ring seal it could have heated it enough for a seat to come loose. You could have a piece of seat ring hanging the valve open. Pull the head and check it out.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: no pressure in #4 all others good. lots of ?'s [Re: rexus31] #315365
05/13/09 12:43 AM
05/13/09 12:43 AM
Medford OR
Medford OR
Head is off and on its back to the shop tomorrow. I had to double check the seat after seeing the second photo that was just posted cause that's exactaly what my valves/springs look like fron the top.
Thanks for all the help guys.
Re: no pressure in #4 all others good. lots of ?'s [Re: FrankenScamp] #315366
05/13/09 01:04 AM
05/13/09 01:04 AM
rexus31 Offline
rexus31  Offline
So what did it look like? Did the piston look like it took a hit from the valve?
Re: no pressure in #4 all others good. lots of ?'s [Re: rexus31] #315367
05/13/09 07:21 AM
05/13/09 07:21 AM
Upper Midwest
Upper Midwest
When I dropped a valve seat it took out 3 pistons by pieces crossing to other cylinders through the intake. Also totaled the heads and had to sleeve one cylinder.
Re: no pressure in #4 all others good. lots of ?'s [Re: MoparforLife] #315368
05/13/09 12:17 PM
05/13/09 12:17 PM
Joplin, MO
734x4PW Offline
734x4PW  Offline
Joplin, MO
Yea, that kind of damage was similar to my old 318 engine when it dropped a valve on #8 cylinder. NOT pretty!
Mark
Re: no pressure in #4 all others good. lots of ?'s [Re: 734x4PW] #315369
05/15/09 08:42 PM
05/15/09 08:42 PM
Medford OR
Medford OR
Guide clearance was what did it in...no real damage ~wipes brow~.
Problem solved....thanks for all the helps guys
Story here:
https://board.moparts.org/ubbthreads/show...e=0#Post5232374
