[quote=skdmark]I'm running a sniper on a ld4b intake with a 1 inch phenolic spacer. It's worked really well.
The phenolic spacer also acts as an insulator.
Why would you need an insulator? It's a return system.
Insulate the ECU in the sniper from heat transfer. [/quot
Good point. The only thing I don’t like about the Snlper TB EFI is the ECU is in the throttle body. Wish they made it like the Atomic and FAST EFI with the ECU module separate, so it could be mounted inside the vehicle away from the heat.
