1966 B body steel wheels for hemi car #3149176
06/06/23 05:16 PM
06/06/23 05:16 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Can anyone post a picture of the correct steel wheel for such.
Oem part number ?
14x5.5" correct ?
Re: 1966 B body steel wheels for hemi car [Re: gtx6970] #3149188
06/06/23 06:53 PM
06/06/23 06:53 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
I don't know what they are Bill, but I'm going to take a shot at it and say they are station wagon HD steel wheels. Now I wait.. wink grin
Re: 1966 B body steel wheels for hemi car [Re: A12] #3149234
06/06/23 09:25 PM
06/06/23 09:25 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Im sure thats correct.
A friend of mine has a stock pile of NOS steel wheels. And before he starts liquidating.
I want to go thru and make sure none are the wheels I need. Some in the pile have OE part numer tags/labels. Most do not .
And Im pretty sure they are a 14x5.5 inch and would take the large center cap ( my car uses the full wheel cover )
I have some 14x6 wheels I got cheap I would use if I ever decided to put it back to outward stock appearance (not likely ) and wasnt really looking for the correct rim. BUT,,,,,,,, if he happens to have them ( with my luck not likely ) BUT,,,,just in case he does. I want them
Re: 1966 B body steel wheels for hemi car [Re: gtx6970] #3149294
06/07/23 08:34 AM
06/07/23 08:34 AM
VA
dragon slayer Offline
VA
What size tires did the car come with. The 66 parts book shows following options for RW cars. 14x 5.0, 5.5 and 15 x 5.5 With part numbers.
So if tire was an 8 series it would be the 14 x 5.5 2298523.
There was a deep dish 14x5.5 listed for charger, P, D and under the RW column. 2534702
Re: 1966 B body steel wheels for hemi car [Re: dragon slayer] #3149331
06/07/23 10:21 AM
06/07/23 10:21 AM
louisiana
musclecarman15 Offline
louisiana
early cars came with 5.0 and then 5.5...check buildsheet....14in.
Re: 1966 B body steel wheels for hemi car [Re: musclecarman15] #3149432
06/07/23 03:39 PM
06/07/23 03:39 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Sbd is April 1966.
I don't have buildsheet for the car
Re: 1966 B body steel wheels for hemi car [Re: gtx6970] #3149602
06/07/23 11:24 PM
06/07/23 11:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
AFAIK
the 1966 HEMI wheel is 14x5.5" wide
it has the 10-hole bolt pattern center
it is the same wheel that was STANDARD on every '66 Charger because of the STANDARD "deep dish" wheel cover w/spinner
a BROADCAST SHEET shows "14" for the wheel designation ---- the '66 Parts Catalog shows part # 2534 702
Re: 1966 B body steel wheels for hemi car [Re: 6bblgt] #3149708
06/08/23 01:34 PM
06/08/23 01:34 PM
VA
VA
What does that 10 hole pattern look like?
Re: 1966 B body steel wheels for hemi car [Re: dragon slayer] #3149742
06/08/23 03:04 PM
06/08/23 03:04 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
here's a 14x5.0" pair from 1966 scope
Re: 1966 B body steel wheels for hemi car [Re: 6bblgt] #3149799
06/08/23 07:24 PM
06/08/23 07:24 PM
VA
VA
Thanks Dan, so all 66 wheels look like that?
Re: 1966 B body steel wheels for hemi car [Re: dragon slayer] #3149857
06/08/23 10:00 PM
06/08/23 10:00 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes, I don't know when they started, but '66 was the last year - for '67 the centers look the same but only one of the extra holes for a total of 6
Re: 1966 B body steel wheels for hemi car [Re: 6bblgt] #3149863
06/08/23 10:57 PM
06/08/23 10:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’ll take a picture of original rims from my 66 Hemi car tomorrow. Painted silver just like car. The little holes were a hold over from when there was a small stud to line up wheel using studs that screwed into axel instead of a lug nut.
Re: 1966 B body steel wheels for hemi car [Re: cudaman1969] #3151078
06/13/23 07:36 AM
06/13/23 07:36 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Im curious to see how the backside is shaped
and are they 5 " or 5.5" ?
I have a set of later model 6" rims I planned to use IF I ever went for the OE stock look. and wasnt all that interested in the originals.
But a friend of mine has shelves of NOS steel wheels and If he happens to have one or two ,,or all 5 by chance ( very unlikely ) I want to get them before he liquidates the stack.
Re: 1966 B body steel wheels for hemi car [Re: gtx6970] #3151488
06/14/23 01:40 PM
06/14/23 01:40 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The stock 66 14” wheel wont accept the small dog dish hubcap also no 15” was made for that cap.
Re: 1966 B body steel wheels for hemi car [Re: cudaman1969] #3151990
06/16/23 10:06 AM
06/16/23 10:06 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Originally Posted by cudaman1969
The stock 66 14” wheel will accept the small dog dish hubcap later won’t, also no 15” was made for that cap.
I may not be following you , but the 66 wheels use the larger 67-back style dog dish cap. 1968 was the first year for the smaller diameter caps.
Matt
Re: 1966 B body steel wheels for hemi car [Re: mattsmopars] #3152220
06/17/23 07:33 AM
06/17/23 07:33 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Matt
Yes I read my post…totally got that backward! New centers that use the bigger cap are made for 15” rims plus they’ll do the whole wheel too.
