Detroit Locker on the Street #315076
05/11/09 05:15 PM
05/11/09 05:15 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
How brutal are they on the street? I've heard they are noisy and clunk, that doesn't bother me at all.
What I'm concerned about is cornering. There are pretty much no straight roads where I live. The dragstrip is going to be the only straight section of pavement the car will be on.
The kicker is that I plan on driving my car to the dragstrip, which is Barona, which happens to be down a very twisty, narrow, winding mountain road.
I've heard you have to coast through corners with them. If that's the case, it will take me forever to get there, it's nothing but corners on the way there!
So any opinions about running one on a street/strip car? Thanks!
Re: Detroit Locker on the Street [Re: 67Satty] #315077
05/11/09 05:31 PM
05/11/09 05:31 PM
SD
4spdJohnny Offline
4spdJohnny  Offline
SD
I have had one in my car last several years. You can feel it "lock" up when getting back on the gas during low speed corners. Never have noticed anything at highway speeds on curves. The newer ones, got mine from Strange 4 years ago, or really quite. Every once in a while hear a click but once again only at low speeds.
Re: Detroit Locker on the Street [Re: 4spdJohnny] #315078
05/11/09 06:04 PM
05/11/09 06:04 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
i've been using one on the street for over five years now. no problems at all. mine also came from Strange installed in the complete rear.
the only clunking happens when going from forward to reverse, or vice versa.
Re: Detroit Locker on the Street [Re: jughed] #315079
05/12/09 12:15 AM
05/12/09 12:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have had one in 63 for over a year now. I just put over 120 miles 2 weeks ago on a trip in PA that had some twisty roads. No problems for me. Sure sometimes you can feel a little clunk when it locks back up but nothing much to me. Ron
Re: Detroit Locker on the Street [Re: 67Satty] #315080
05/12/09 02:18 AM
05/12/09 02:18 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
do you have a dana 60 in the rear?
I have a limited slip for you.....
Re: Detroit Locker on the Street [Re: 70blackfish] #315081
05/12/09 07:53 AM
05/12/09 07:53 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Don't sweat it it will be fine and well worth the performance over a limited slip. I don't run detroits but my Jeep that I drive everyday has lockers front and rear with no bad side effects. If you think one locker clicks alot you should here two .
68 Barracuda Formula S 340
Re: Detroit Locker on the Street [Re: Bad340fish] #315082
05/12/09 09:16 AM
05/12/09 09:16 AM
Barboursville, VA
belvedere383 Offline
Barboursville, VA
I have run a detroit locker in my Belvedere for almost 6 years now. The only time you can feel it is after you drive really slow around a corner or after backing up you can feel it click back into place. But i have never heard mine make any noise other than that. And i abuse mine with the best of them and it has never given me one single issue, probably the best diff i have ever had.
65' Belvedere
496'' Stroker
Indy Heads
Re: Detroit Locker on the Street [Re: 67Satty] #315083
05/12/09 10:04 AM
05/12/09 10:04 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what kind of power level are we talking here? what kind of traction? (street tires? drag radials? slicks?)
another option to look at is the detroit tru-trac's...they're a torsen style (helical gear) limited slip.
2017 Grand Cherokee Overland
Re: Detroit Locker on the Street [Re: patrick] #315084
05/12/09 02:31 PM
05/12/09 02:31 PM
P
Paul_Fancsali Offline
P
Detroit 4.56 in a 8.75 rear end no noise at all. In fact one of the quietest rear ends I have ever used. Occasionally a slight nudge in a sharp turn. I also used older limited slip gear Mopar gear oil from the 70s and a additive don't know if that helped or not?
Re: Detroit Locker on the Street [Re: Paul_Fancsali] #315085
05/12/09 07:44 PM
05/12/09 07:44 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I love mine, first of all about the noise, if your car is so quiet that you can hear it, you don't need a Locker
Like everyone else said, the only time I even notice mine is if I get in the gas a little to early around a SLOW corner. If you nail the throttle while going around a slow corner and have any kind of power you'll be in for an "interesting" ride
Go for it
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
