Re: Passon 5-Speed 833 Trans ? (Feedback) [Re: LimelightCuda] #3150869
06/12/23 02:17 PM
06/12/23 02:17 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I have had, and have both the OD and A833 in my 1970 Cuda, 440 with 4:10 gears.
I put the OD in while waiting for the A833 (yes I was on the list for four years, not a big deal to me). While the gear spread on the OD, from 1st to 2nd, is not an issue for my setup it could be for lower horse power or torque cars. I liked being able to cruise around town in 3rd gear, and then have 4th when I hit the highways. The OD was in the car for over three years and I never had an issue with it.
The A833, gives me the best of both worlds, stock gear ratios from 1st thru 4th and 5th overdrive. In 5th I am at 2200 RPM at 65 MPH. It was an easy install with no cutting. Sense mine was a later A833 there where no break in noises, like some have said. Shifting is more firm than a stock trans, in my words, a more positive feel when going into each gear. I have not raced mine, I have gotten on it hard in street driving and shifting between gears is fine.
I have never owned or driven a car with the other transmission, so I cannot speak on how the A833 differs from them.
My Monster are real!
Living within your means makes life pretty easy.
Re: Passon 5-Speed 833 Trans ? (Feedback) [Re: PhillyRag] #3150919
06/12/23 04:31 PM
06/12/23 04:31 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Originally Posted by PhillyRag
Originally Posted by ThermoQuad
I work in the world of dimensional metrology so i understand gears, gear sets manufacturing etc.
Noisy gears are from poor dimensional tolerancing meaning the parts are not made to print specifications so they are essentially wearing on each other hence the noise.
Wasn't the 833 18spline known to be noisier then the 23spline?
So by your statement: was the 18spline intentionally made "poorly"?
The 18 spline is noisier because of the pitch of the gear teeth is different than the 23 spline.
Re: Passon 5-Speed 833 Trans ? (Feedback) [Re: JohnRR] #3150961
06/12/23 06:57 PM
06/12/23 06:57 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Seems some think these metal gear boxes should be as quiet as say some nylon gear gismo.
Re: Passon 5-Speed 833 Trans ? (Feedback) [Re: JohnRR] #3151027
06/12/23 09:59 PM
06/12/23 09:59 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
[CTquote=ThermoQuad]I work in the world of dimensional metrology so i understand gears, gear sets manufacturing etc.
Quote
Actually it's the angle of the teeth not so much the pitch that makes the noise. Straight teeth are the strongest and that is what you will find in a dedicated race transmission like a Liberty or Jericho. It's stronger but sounds like an old dump truck. Oem style gears are angled to reduce noise. Since the 18 spline Hemi gear sets are expected to handle more torque than a 23 spline they were designed with less angle than the 23s which makes them slightly stronger but somewhat noisier.
