'98 Dakota 2wd upper control arms?
#3149596
06/07/23 10:51 PM
06/07/23 10:51 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Asked on the Q&A board first but probably should have come here instead. Are 2wd and 4wd upper arms the same? Need to replace them on my sons Dak and only find listings for 4wd. Google brings up one site saying they are the same and the next one says no. And no, I don't feel like fighting them to just replace bushings unless I absolutely have to. Did it on the QC Dak I had and it was a PITA. TIA Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: '98 Dakota 2wd upper control arms?
[Re: bobby66]
#3149654
06/08/23 09:42 AM
06/08/23 09:42 AM
I_bleed_MOPAR
Buford, GA
First place I checked. All they show are 2wd lowers. Same with parts houses. A990 answered me over on Q&A that they are different. Guess I'll just have to dust off the press and go a few rounds with it. Thanks. Tim
[Re: JDMopar]
#3152010
06/16/23 11:22 AM
06/16/23 11:22 AM
I_bleed_MOPAR
Buford, GA
Thanks, JD. Been busy out in the garage. Surprisingly, the old bushings came out way easier than the ones on the QC did. Taking the upper arms off wasn't too bad. Maybe because you have a 4.7? Found several other things to take care of while I've got it (leaking crank seal, radiator). Always something. Tim
